Tacoma Shock Relocation - Trail Series - 2.0 x 12 - 2nd/3rd gen
Discussion in 'Archive Garage' started by ARCHIVE, Feb 22, 2021.
  1. Nov 2, 2022 at 12:55 PM
    #381
    Slidoomz
    Slidoomz Well-Known Member
    David
    Riverside,CA
    Ford F150
    crashngiggles and ARCHIVE[OP] like this.
  2. Nov 2, 2022 at 12:59 PM
    #382
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    What in the bubba's backyard body shop is going on with that gas tank strap @EatSleepTacos !?
  3. Nov 2, 2022 at 12:59 PM
    #383
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s the trailtoys gas tank skid. It’s held on with straps.
  4. Feb 6, 2023 at 10:34 AM
    #384
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    If I am understanding correctly, it sounds a lot like running 17x8.5s with 4.3" BS and 285s should clear with these.
    Is anyone running this configuration? Is it clearing? I know there is a lot of variation on these trucks, maybe I should ask has anyone had clearance issues with the aforementioned combo?
    DoulosXP likes this.
  5. Feb 6, 2023 at 10:43 AM
    #385
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    That is the exact setup I am running and have zero clearance issues. Fully flexed out I can still fit my fingers between the shock body and tire.
    Specifically 17x8.5 4.3" BS SCS Ray 10s and 285/70r17 Duratracs.
  6. Apr 6, 2023 at 2:34 PM
    #386
    StevieD21
    StevieD21 Active Member
    NorCal
    2016 TRD Off Road
    N-fab nerf bars Method Roost Wheels BF Goodrich KO2
    I want to verify if anyone is running this setup and clear with no spacers. 17x9 -12mm with 4.5 backspacing on 285’s
  7. Apr 6, 2023 at 2:38 PM
    #387
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I did on 16x8 -12 4.5
  8. Apr 12, 2023 at 7:38 AM
    #388
    asanelli
    asanelli Well-Known Member
    Tony
    Golden CO
    3rd Gen Tacoma TRD Offroad
    What is the recommended leaf pack for this kit?
  9. Apr 12, 2023 at 7:50 AM
    #389
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Works with any including stock packs, just stock packs are limited to about 10" travel.
  10. Apr 12, 2023 at 8:01 AM
    #390
    asanelli
    Tony
    Golden CO
    Can I use hammer hanger with a stock leaf pack to get to 12" or 14"?
  11. Apr 12, 2023 at 9:37 AM
    #391
    ARCHIVE
    Eric
    Stock packs are stuck about 10" travel no matter what you do
  12. Apr 12, 2023 at 9:53 AM
    #392
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Did anyone ever find a Bilstien shock that will work with these mounts? I'm to lazy to go page by page to find out.
  13. Apr 12, 2023 at 2:29 PM
    #393
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    7100. Valving depends on your intended use
  14. Apr 13, 2023 at 9:02 AM
    #394
    Maxx
    Maxx Well-Known Member
    For 7100s, start with the 255/80 valving and revalve from there.
    CemenTRDgen and LOLLY like this.
  15. May 26, 2023 at 2:55 PM
    #395
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Anyone with experience on running 285/75-17s on a 17x8.5 with 4.75 BS Method wheel with this kit?
  16. May 26, 2023 at 3:04 PM
    #396
    ARCHIVE
    Eric
    I'd say it would be close, but you'd probably need a small wheel spacer like 3/4"
    Hilborn[QUOTED] likes this.
  17. May 26, 2023 at 3:08 PM
    #397
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I run 285/75r17 on 7.5 wide and I believe they are 4.75 bs (sequoia wheels) and 1.25" spacers. Plenty of room for activities.
    mach1man001 and Hilborn like this.
  18. May 26, 2023 at 5:16 PM
    #398
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Do you even "NEED" the spacers? Have you ever tried that setup without the spacers?
  19. May 26, 2023 at 5:22 PM
    #399
    Hilborn
    Michael
    Utah
    If you have any pics of the amount of room for activities, it would help me out some
  20. May 26, 2023 at 6:00 PM
    #400
    TacoFMS
    Justin
    Louisa County, VA
    I don't "need" all of the 1.25" spacers to clear, but I HAVE to run them to clear in the front so it was just as easy to get 2 pair of spidertrax instead of 1 of them and 1 pair of 3/4" bora.
    mach1man001[QUOTED] likes this.
