Tacoma Spring refurbishing
Discussion in 'Suspension' started by 4WD, Dec 22, 2011.
Thread Status:
Not open for further replies.
  1. May 30, 2013 at 7:55 PM
    #1581
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I go Saturday for drop out to full compress fitting, I told them the drop out will make you scratch your head for a basically stock spring...
  2. May 30, 2013 at 8:51 PM
    #1582
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hmmmm, let me kick it around my empty head Erik, i'm sure something will fall out....
  3. May 31, 2013 at 10:52 AM
    #1583
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    would 1/2 ton chevy springs be worth picking up for cheap?
  4. May 31, 2013 at 12:59 PM
    #1584
    4WD
    Doug
    2004 DC TRD 4x
    Absolutely , older 1/2 ton Chevy springs is what I use
  5. May 31, 2013 at 7:19 PM
    #1585
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    ok so i picked them up and there a tiny bit wider than the toyota ones, the u-bolts go on with some taps with the hammer but then they dont line up with the bolt holes on the lower shock mount what do you do?
  6. May 31, 2013 at 7:45 PM
    #1586
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    If they aren't too far off, you can take a large set of channel locks or a c-clamp and squeeze the ends back together until you can get the plate on. Then it's just a matter of tightening the nuts down.
  7. May 31, 2013 at 9:08 PM
    #1587
    cepadams
    cepadams Well-Known Member
    Adam
    Goodyear Az
    07 double cab 4x4
    Volant cai, flowmastets, 884's with adjustable 5100 front, 2" aal & 5100 rear. Pro Comp light bar and trailer park custom bed rack!
    Ok so I just pulled the trigger on this one like a year later than I wanted to. Needless to say love the ride and firmness. Ill post up more pictures and a review once I wheel it a little more. Only questions to the peeps that have done this is will the springs settle a little as I'm riding a little higher than wanted in the rear. I used oem main and second spring and put 2 Chevy (mid 80's) under that.
    Options
    1- put a 1/4-1/2 inch plate above my 5100/885(due to a 1/2 sag I developed over a year and get it to a decent rake.
    2-the leafs settle a little and all is good.
    3-change the leafs around-ie. take out the second Yota spring or only use 1 Chevy?
    Thoughts?
  8. May 31, 2013 at 9:11 PM
    #1588
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    ive tried that i got them to go in but the they were so tight on the plate it wouldnt tighten down and settle on the axle, i think im just going to grind a little bit off right where the u-bolts sit just enough to make it easy to get them on ill post pics tomorrow
  9. May 31, 2013 at 9:21 PM
    #1589
    cepadams
    Adam
    Goodyear Az
    07 double cab 4x4
  10. May 31, 2013 at 9:24 PM
    #1590
    cepadams
    Adam
    Goodyear Az
    07 double cab 4x4
    Sorry I was unable to get it all on one post I just got this iPhone thing and I'm hatting it!
  11. May 31, 2013 at 9:27 PM
    #1591
    4WD
    Doug
    2004 DC TRD 4x
    You can grind just enough off each side to let U bolts loop over, grind the springs as a pack & not seperately ( I know, but some have:D) This is not uncommon, I've used springs that fit exactly & some that need shaved a hair....
  12. May 31, 2013 at 9:28 PM
    #1592
    SoCaltaco65
  13. May 31, 2013 at 9:29 PM
    #1593
    SoCaltaco65
  14. May 31, 2013 at 9:37 PM
    #1594
    Taco No Baka
    Lee
    Tampa, FL
    Wow, that sounds like they were pretty far off then.
    Oops, Doug answered while I was posting a reply. Ignore me...what he said! :D
  15. May 31, 2013 at 9:56 PM
    #1595
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, I was going to suggest blending it really well to help with that, but I was just thinking that having the springs be narrower there, they would tend to flex more at that point than they would where they were wider, thus work-hardening at that point and eventually cracking, but Doug says it should be fine and I believe him.
    BTW, Doug, how much difference, length-wise is the Ranger or Chevy S-10 main spring? Is it close enough that I could grind down the hanger end to fit in the front spring hanger and maybe just run a longer rear shackle to use them? Or are they too long/short to be even close?
  16. May 31, 2013 at 10:16 PM
    #1596
    4WD
    Doug
    2004 DC TRD 4x
    Looks good !! How much lift you figure you got out of it ?
    Ha, my sister inlaw lives in Goodyear warming up there i bet
  17. May 31, 2013 at 10:45 PM
    #1597
    cepadams
    Adam
    Goodyear Az
    07 double cab 4x4
    Hot as hell already! Ugh. And I'm thinking in or around 3" but ill recheck my numbers tomorrow.
  18. Jun 1, 2013 at 6:50 AM
    #1598
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    doug in case you missed it tyler and i stopped by at different times yesterday lololol
    im surprised i didnt wake you up haha
  19. Jun 1, 2013 at 6:58 AM
    #1599
    SoCaltaco65
    WTF is this BS at Doug's place? First Greg does his impression of a monkey climbing all over his truck, now the foreground finger with Doug's and perps vehicle in the back ground...
    Thats it, im coming over with a crew and doing a Harlem Shake video around Dougs truck with mine in the back ground.....
    http://www.youtube.com/watch?v=iD7lfLy-THY
  20. Jun 1, 2013 at 7:03 AM
    #1600
    Leoffensive
    Leo
    San Diego, CA
    cornhole margarita!!!!!!
    DA DA DA dadada DA DA DA DA DA DA DA!!!
Thread Status:
