Tacoma Spring refurbishing
Discussion in 'Suspension' started by 4WD, Dec 22, 2011.
Thread Status:
Not open for further replies.
  1. Jan 5, 2014 at 5:43 PM
    #1941
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well, you know what to do, clue him in & I'm sure it won't take as long as yours did...:eek::)
  2. Jan 5, 2014 at 7:32 PM
    #1942
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    You still making and selling them
  3. Jan 5, 2014 at 8:21 PM
    #1943
    4WD
    Doug
    2004 DC TRD 4x
    Yeah, but ya know you guys could just as easily do it yourself if you wanted to, I can walk you guys thru it..
  4. Jan 5, 2014 at 8:33 PM
    #1944
    LSC15
    Logan
    2008 TRD D-Cab
    Dont have the equipment
  5. Jan 5, 2014 at 8:49 PM
    #1945
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You know people. *Backwoods, and I. I can translate "Old man talk" too ;-) .
  6. Jan 5, 2014 at 8:58 PM
    #1946
    LSC15
    Logan
    2008 TRD D-Cab
    True
  7. Jan 5, 2014 at 9:04 PM
    #1947
    4WD
    Doug
    2004 DC TRD 4x
    What is this Old Man talk you speak of ???
  8. Jan 5, 2014 at 9:08 PM
    #1948
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Doug, you may have answered/stated this before, but what do you use for a center pin?
    That the only thing that has me stumped , the leaf clamps are very simple and straightforward
  9. Jan 5, 2014 at 9:25 PM
    #1949
    4WD
    Doug
    2004 DC TRD 4x
    Well you can go to National Spring or ORW, both are in El Cajon, or you can go to home depot, get 3/8"' dia. fine thread bolts with nuts to match (grade 5) knock the corners off the head of the bolt & your good (bolt should be 3" long)
    The ready made ones from National Spring are probably your best bet, they're about $5 for 2, tell them you need the 3/8" thread size
  10. Jan 5, 2014 at 9:32 PM
    #1950
    LSC15
    Logan
    2008 TRD D-Cab
    I think I still have a little lean on my drivers side
  11. Jan 6, 2014 at 8:18 PM
    #1951
    4WD
    Doug
    2004 DC TRD 4x
  12. Jan 6, 2014 at 8:33 PM
    #1952
    Sandman614
    Tim
    '06 SR5 Off Road
    Just kidding
    I used a socket cap bolt/screw from Lowes, it's got a round head. Like so. [​IMG]
  13. Jan 6, 2014 at 8:42 PM
    #1953
    4WD
    Doug
    2004 DC TRD 4x
    Haha no worries dude , I figured as much...:D
    I know it doesn't matter probably but the reason I don't use those is because of the lack of material in the center (hollowed out), just takes away sheer strength from not having solid head into perch, but no biggie..;)
  14. Jan 7, 2014 at 3:17 PM
    #1954
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    could i order just the leaves from you? i can cut and do all that nonsense but i can't find the right width leaves anywhere.
  15. Jan 7, 2014 at 8:31 PM
    #1955
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    What about leaves that don't really offer lift? I don't really plan on lifting my truck. Running stock suspension w/ 31's. Really would just like to replace the old toyota ones. They have some miles, so just going back to stock would probably offer more then enough lift for me.
  16. Jan 7, 2014 at 9:22 PM
    #1956
    4WD
    Doug
    2004 DC TRD 4x
    Check out some Dodge Dakotas, they were 3/4 ton & sat pretty low which would indicate a thicker , slightly wider spring (still within specs) with little ARC to its radius
  17. Jan 8, 2014 at 6:45 PM
    #1957
    4WD
    Doug
    2004 DC TRD 4x
    Sure,
  18. Jan 8, 2014 at 6:52 PM
    #1958
    Boogyman
    Phoenix
    Corpus Christi, TX
    i just saw your post about dakota leaves, i think i can find some of those :spy:
  19. Jan 13, 2014 at 2:19 PM
    #1959
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Ever tried to find a set of jeep commanche(cherokee pickup) springs to use, my old one was 2wd and spring under but the truck set up high to be 2wd almost like a prerunner.
    Also some of them came with a big ton package with somewhere around a 1700 payload.
    The jeep trucks arent as common as a s10 or dakota though and Ive only saw one of the hd package ones.(they have bedside decals)
    Edit, I remember the leafs seemed to have a ton of arch.
  20. Jan 14, 2014 at 6:02 PM
    #1960
    4WD
    Doug
    2004 DC TRD 4x
    As is the nature of SUA, sometimes they make good donors for SOA, but usually too much ARC
Thread Status:
