Tacoma starting issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by KLIEBERT, Nov 2, 2009.
  1. Nov 2, 2009 at 7:00 AM
    KLIEBERT
    KLIEBERT [OP] Member
    Prerunner SR5
    2002 V-6 Prerunner sometimes will not start, engine turns over but will not start unless depress on gas pedal , this happened several times in the past months, can someone shed some light to what may be wrong? Thanks...Kliebert
  2. Nov 2, 2009 at 8:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    Simple things first, look for any vacuum leaks. Clean the IAC and throttle body.
    Was anything done to the truck (mods, wheeling, etc) before this started?
    Did you have any recent work done?
    Is the CEL on?
  3. Nov 2, 2009 at 9:08 AM
    KLIEBERT
    Prerunner SR5
    No work or mods to the truck, what is the CEL ?, this hapens every now & then, truck runs great besides this. This morning it would only run with the gas pedal depressed, after a while the truck started running good. Thanks
  4. Nov 2, 2009 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When was the last time the fuel filter was changed?
  5. Nov 2, 2009 at 9:30 AM
    KLIEBERT
    Prerunner SR5
    The fuel filter was never changed.
  6. Nov 2, 2009 at 9:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Might be worth it to change it out, and see. Its cheap, and easy to DIY.
  7. Nov 2, 2009 at 9:33 AM
    KLIEBERT
    Prerunner SR5
    Good Idea, where can I get one online ? Thanks....Kliebert
  8. Nov 2, 2009 at 9:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you need one fast, you should be able to get one at a local auto parts store. Otherwise, I would try TRD Parts 4 U, or some other online retailers.
  9. Nov 2, 2009 at 9:38 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Ya, your truck wont start all the time...
    JK man, have you changed spark plugs, cap and wires or the battery lately?
    How many miles do you have on it?
    When was the last time you did change the spark plugs? Have you checked the throttle cable to make sure it's within spec travel?
  10. Nov 2, 2009 at 9:44 AM
    KLIEBERT
    Prerunner SR5
    169,000 miles, Plugs & wires never changed, if plugs were bad wouldn't it run bad all the time, she runs great, just that sometimes , about once a month this happens.
  11. Nov 2, 2009 at 10:18 AM
    Masada
    Taylor
    Laveen, AZ
    WOW maintenance 101 bro, change those plugs and while your at it do the wires too...
    If it can't spark it can't start, might be getting just enough spark to turn it over. But they are pretty bad if they have never been changed. Have you done any of the regularly scheduled maintenance?
    When was the last time you changed the oil?
  12. Oct 27, 2013 at 8:33 PM
    dooleyreilly
    dooleyreilly Member
    4 banger
    fog lights
    Hello, I'm brand new to this forum. Desperate for some help before I drop hundreds in a local shop.
    My husband's 1999 Tacoma runs like a champ and is well maintained with 160K. A couple years ago, after driving hundreds of miles on a road trip, the engine would not start, wouldn't turn over or make any clicking noises. All the instrument lights come on. Wouldn't start even if shifted into neutral or another gear. This problem was rare but has become more and more frequent. Now it happens on a bi-weekly basis, and it's always when the truck has been driven over 60 mph for at least ten minutes. Stop to get gas, and he'll be stranded for 45 minutes. New battery, new keys, new starter. When that didn't solve the problem, we took it back, and the shop that installed the starter said it could be the after-market alarm (from the previous owners) screwing things up. They said they disconnected the alarm but also managed to disconnect the PIIA fog lights we installed the previous winter, so now we're looking at chasing some wires to get this thing functional again.
    We are thinking maybe a bad connection between the ignition and starter? What are your thoughts?
    Any help is most appreciated. THANK YOU!
  13. Oct 27, 2013 at 8:54 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    dooleyreilly, start your own thread instead of invading someone elses. People can comment on your issue instead of getting it mixed up with the OP's
  14. Oct 28, 2013 at 9:22 AM
    dooleyreilly
    dooleyreilly Member
    4 banger
    fog lights
    Couldn't figure it out last night. Started a new thread elsewhere.
