Tacoma Tail light out and fuse blows
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trinimd, Jul 31, 2008.
  1. Jul 31, 2008 at 5:21 PM
    Trinimd
    Trinimd [OP] Member
    Just realized that not only is my Gages out but my tail light is as well and corner lights
    The brake light works fine, just the tail light.
    The fuses inside the cab (gage and stop light) have been replaced (they were ok before replacement)
    There is a tail light fuse under the hood that is broken. I replaced it but when I move the headlight switch to park it blows.
    MY QUESTION IS: I can hear the relay for "Tail Light" clicking when I turn the headlight switch on. Is that normal?
    Any other suggestions?
  2. Aug 1, 2008 at 5:22 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Now that I think about it when I turn my lights on I hear something click that sounds just like a relay over in the right side of my engine so it may be. But do your tail lights even have a relay?
  3. Aug 1, 2008 at 11:40 AM
    Trinimd
    Trinimd [OP] Member
    Yea it has relay. SO far my research has pointed to my cd player that I put in 2 months ago. Did you recently replace a cd player?
  4. Aug 1, 2008 at 11:49 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I had a similar problem a few years back. It turned out the trailer wire plug had corroded and shorted the lights out. If you have trailer lights, check them for corrosion.
  5. Aug 1, 2008 at 11:52 AM
    Trinimd
    Trinimd [OP] Member
    Yes I thought that could be my problem, however I isolated that problem by disconecting both tail lights from the harness, its still blowing the fuse
  6. Aug 1, 2008 at 3:33 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Bad ground somewhere I'm thinking. Do you have a trailer harness hooked up? If so, it may be not wired correctly or not grounded properly.
  7. Jun 3, 2014 at 6:03 AM
    revwilliec
    revwilliec New Member
    Willie
    Fayetteville NC
    01 Prerunner
    I disconnected both tail lights and fuse did not blow. What does that mean?
  8. Jun 3, 2014 at 9:19 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Holy thread revival, good on you for searching. That tells you that your short is somewhere in one of the taillights. Maybe try hooking one back up at a time to isolate which side it's on.
