Tacoma tonneaus
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nikita23, Jul 15, 2007.
  1. Jul 15, 2007 at 1:07 PM
    nikita23
    nikita23 [OP] Member
    California
    07 PreRunner SR5
    Hi there,
    Just wondering if anyone have an opinion about EXTANG TRIFECTA TONNEAUS.
    I'm about to get one of them for my Tacoma 2007.
    Are they good?
    Greetings from California.
  2. Jul 15, 2007 at 1:43 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I do not know personally, I have always prefered rear hinged soft covers, but I believe that the general consensus on here a while back was that the tri-fold soft covers like the trifecta over time puts too much stress on the cover material itself (you are after all folding it 180 degrees back on itself) causing cracks and over time leaks.
    I use an extang full-tilt hinged at the cab, no bending at all of the cover itself, and it sits high enough that that you still retain use of the factory tie down system.
  3. Jul 15, 2007 at 5:02 PM
    Panama Red
    Panama Red Well-Known Member
    Or you can get something like the Access Limited Edition that rolls up and still allows use of the factory cleats too.
  4. Jul 15, 2007 at 9:59 PM
    nikita23
    California
    07 PreRunner SR5
    Thank you Maverick89 and Panama Red, for your response to my question about the exang trifecta.
    I was ready to buy the cover, but after reading your responses, I changed my mind. I wil buy instead, a hinged one.
    Thank you again.
    Have a good one.
    nikita23
    (Nick)
  5. Feb 15, 2009 at 4:03 PM
    garbal
    garbal Member
    I've had mine through two winters and have had no problems with cracking etc. This is a pretty good cover.
    It's the only one I've ever had and so far so good. Keep em' clean and they should last a while!
    My 2cents worth.
    Garbal.
  6. Feb 15, 2009 at 4:24 PM
    Fishpig
    Fishpig Well-Known Member
    Lexington, VA
    2020 TRD OFF ROAD DCLB
    Mine is 1 1/2 years old and works great
  7. Feb 15, 2009 at 4:44 PM
    AK27
    AK27 Well-Known Member
    my trifold soft cover (i think its an extang) is crap. the material is stretched and flaps in the wind at high speeds, has several small tears that turned into big rips, the sides that sit on the box are up and down like a yo yo, and it is tearing at all the corners from movement against the frame. just my $.02
