Tacoma v6's, 6 speed or 5 speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ne0tas, Feb 8, 2012.
  1. Feb 8, 2012 at 8:28 PM
    ne0tas
    ne0tas [OP] Well-Known Member
    Erick Iglesias
    Duarte, California
    None. :[
    Sup guys, i plan on buying a truck with the TRD off-road package in the next few to six months and i am just trying to gather as much info as I can right meow.
    So I am trying to see which is better, a 5 speed Automatic or a 6 speed stick shift. I live near LA and will probably be working near Fontana if all goes according to plan. Gas mileage isn't an issue but higher is always better.
    I can drive a 10 speed (commercial licensed driver) and I am used to shifting and whatnot. I used to drive a nissan Frontier with an Automatic and now I am driving a Honda Civic Automatic and I absolutely hate them! but on the convienience level they are really good for when I feel lazy. I am baffled. Any help? :3
  2. Feb 8, 2012 at 8:36 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    There have been many threads on this. The consensus is that it comes down to personal preference. Test drive both and see what you like.
  3. Feb 8, 2012 at 8:51 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I've had both. My opinion is to get the auto. Driving around the Fontana area during rush hour traffic sucks with a manual.
  4. Feb 8, 2012 at 8:51 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    what he said.
  5. Feb 8, 2012 at 9:09 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I've been driving nothing but stick shifts for the last 17 years. The Tacoma's six speed is by far the most difficult one to drive that I've ever had. Many folks on this forum would agree with me on that. Given the amount of traffic you are going to see, do yourself a favor and get the automatic. Being able to drive a 10 speed does not mean you HAVE to suffer with a six speed in traffic. I have a friend who is quite fond of saying "just because you can dig a ditch, doesn't mean that you have to, or that you should!"
  6. Feb 8, 2012 at 9:13 PM
    ne0tas
    Erick Iglesias
    Duarte, California
    None. :[
    What is so difficult about the six speeds?
  7. Feb 8, 2012 at 9:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    These trucks use a two piece rear driveshaft and have soft rear springs. The combination of axle wrap and a sloppy center support bearing on the rear shaft result in a vibration at takeoff. While this is present on the automatics, it just makes it that much harder to take off smoothly from a stop with a manual trans. That's always been the struggle for me.
    I also can never seem to get comfortable with the position of the clutch pedal. You absolutely have to have the pedal on the carpet to shift without grinding, not much margin for error. Combine that with the geometry of the pedal and the limited space for your feet in that area, and I find it physically uncomfortable to drive in traffic for very long.
    Definitely go drive one. The new ones may be different, mines six years old now. But I suggest that you be very critical of it, and really pay attention. I test drove two different trucks and both of them drove the same. I figured I would get used to it and learn how to handle the quirks. 20K later and I'm still not used to it. It's nothing like the Dakota V6 5 speed I had before, and the 09 Tacoma regular cab 5 speed I have at work is much more forgiving and less stressful to drive.
  8. Feb 8, 2012 at 9:34 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Again ?
  9. Feb 9, 2012 at 5:16 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    I find the 6-speed as easy to drive as any other truck (with a few exceptions)...drive both for at least an hour and vary the conditions so you can get a feel for both transmissions...
  10. Feb 9, 2012 at 5:21 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
    Its that time of the year I guess. :confused:
  11. Feb 9, 2012 at 7:50 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I have heard many bad things about the 6 speed, so I went with the 2.7 4 banger and 5 speed manual, I love it! Even if I do upgrade to a V6 in the future, it would be a 6 speed either way, there is nothing on them that cannot be fixed if they break.
  12. Feb 9, 2012 at 11:24 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    its not personal preference. Its clear that the 6-speed manual is the superior choice. DUH! Way better than auto in all ways.
  13. Feb 9, 2012 at 11:31 AM
    OZ-T
    Peter North
    British Columbia
    Uh no
  14. Feb 9, 2012 at 11:33 AM
    forana
    Kaneohe, Hawaii
    yes
  15. Feb 9, 2012 at 11:44 AM
    OZ-T
    Peter North
    British Columbia
    OK boss
    For you , in your opinion , that's how it is .
  16. Feb 9, 2012 at 12:27 PM
    forana
    Kaneohe, Hawaii
    im just joshing you man, this has been beat to death.
    but the 6speed is better.
  17. Feb 9, 2012 at 12:32 PM
    2004TacomaSR5
    Jon
    Montana
    :popcorn: I has a feeling this is gonna get interesting!
  18. Feb 9, 2012 at 1:19 PM
    forana
    Kaneohe, Hawaii
    This thread should actually end. I settled it once and for all.
  19. Feb 9, 2012 at 2:21 PM
    ne0tas
    Erick Iglesias
    Duarte, California
    None. :[
    :eek: Link please!
  20. Feb 9, 2012 at 2:27 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    The auto ..
    Fuck it. I'm tired of typing about MT vs. AT. They both suck, go buy a Ranger.
