Tacoma won't start
Discussion in 'Technical Chat' started by SPiNRiX, Dec 13, 2010.
  1. Dec 13, 2010 at 1:45 PM
    SPiNRiX
    SPiNRiX [OP] Member
    1995 Toyota Tacoma 3VZE
    Stock
    When I try to start my 95 Tacoma, the engine does not try to crank and no clicking can be heard. It is just quiet. It is a manual transmission so the clutch does need to be pressed. Even with the clutch down it doesn't do anything. I checked all the fuese and they are all good. Maybe something is wrong with the clutch? Electrical power still works.
  2. Dec 13, 2010 at 1:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    did you try the clutch start cancel switch?
  3. Dec 13, 2010 at 1:47 PM
    DrewH
    DrewH Well-Known Member
    Maybe your battery is dead.
  4. Dec 13, 2010 at 1:54 PM
    SPiNRiX
    SPiNRiX [OP] Member
    Stock
    I have heard of the clutch start cancel. If I am correct, it helps start the car in uphill situations or something. How would I try the start cancel switch? Do I have to hold the button down or can I just press it once and try?
  5. Dec 13, 2010 at 1:54 PM
    SPiNRiX
    SPiNRiX [OP] Member
    Stock
    Sorry I forgot to add that all electrical power works.
  6. Dec 13, 2010 at 3:25 PM
    Barnone
    Barnone Guest
    Still could be the battery. How about trying to jump start it?
  7. Dec 14, 2010 at 2:38 PM
    SPiNRiX
    SPiNRiX [OP] Member
    Stock
    I took in the battery to be charged as the car hasn't been on for about a month now. They told me the battery is bad. I was going to buy a new batter but my dad said to just find a new engine for it. I doubt it needs a new engine but what I don't doubt is that my dad only WANTS a new engine. The truck is basically my dads. He bought it with his money but after my brother was the one driving it when it broke, he is kind of just handing it to us and saying, do what you want, fix it, junk it, or just get rid of it. I was going to try hooking the dead batter up and try jump starting it with a F150 (the 6 wheeler) and try the cancel clutch start to see if it'll start. But what I am wondering before I try it is, will the F150have enough voltage to atleast start the Tacoma?
  8. Dec 14, 2010 at 2:42 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    any running vehicle with a good battery will work. you don't need the clutch cancel switch when jump starting (make sure it's out of gear if you do use it).
    swapping in a new engine because the battery's dead seems a bit overkill. (and by "a bit," i mean "a lot"!)
  9. Dec 14, 2010 at 2:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    It will also bypass the switch that is activated when you depress the clutch pedal so if it starts with the button in (you don't have to hold it, just press it once with the ignition on) then you know the clutch switch down by the pedal is bad.
  10. Dec 15, 2010 at 12:15 AM
    SPiNRiX
    SPiNRiX [OP] Member
    Stock
    I do have it. The button in in the left side of the steering wheel on the dash.
  11. Dec 15, 2010 at 4:05 PM
    SPiNRiX
    SPiNRiX [OP] Member
    Stock
    I tried jump starting the tacoma using a 6 wheeler F150. The electrical system still works but this time the gauges where flickering on and off while making the clicking noise that you hear when your signaling. I tried the cancel clutch start anyways and still nothing. Still quiet and still not trying to crank. So I know the battery is bad, Im starting to think maybe the starter now.
  12. Dec 15, 2010 at 4:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yup, its the starter. You can try smacking it with a hammer a few times first and see if that frees it up. If that doesn't work then pull it out and bench test it.
