Flatbed,35’s and Mainly Parked For Repairs
Discussion in '2nd Gen. Builds (2005-2015)' started by tacoma16, Feb 6, 2012.
  1. Nov 5, 2017 at 3:50 PM
    #321
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    step one of getting the flatbed is getting rid of the current setup. Sad to see the cap go as me and my GF put alot of time and effort into designing it, and lots of memories were made using it. Step one has commenced.
    Little bit of a difference
    and without
    Also took advantage of the BAMF sale and got me some HD shackles and new HD hangers. I have officially gone full retard
    uurx, Kemosabe and Bocsy44 like this.
  2. Nov 5, 2017 at 6:05 PM
    #322
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
  3. Nov 6, 2017 at 3:49 PM
    #323
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Flat bed has officially been ordered!
  4. Nov 22, 2017 at 8:13 AM
    #324
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Putting this here so I don't loose the list. This is going to be a working list......
    Things on order/To install
    -BAMF HD SHACKLES
    -Frame plates
    -GM bumpstops
    -TMR Customs order (tabs, d-ring shackles, bellow kit, gussets)
    -Flat bed
    Things to do:
    Flat Bed install-->http://www.uteltd.com/PDF/gm/UteBedB6GM-QLinstructions.pdf
    -Remove truck bed
    -Remove wiring from tail lights and splice into new tails for flatbed
    -Design/build rear bumper (tire carrier?)
    -box frame
    • need to keep in mind shackle and bumper mounts either need to be accessible or tubed so longer bolt can be used and not crush frame)
    • reinforce bump pad with internal gusset
    • X brace to replace tire carrier crossmember
    • tabs for lights on x brace
    • tabs for zip ties to tidy up wiring
    • need weldable primer and paint
    Fitting 35's
    -Cut and trim front fenders.
    -Cab mount chop
    -beat inner fender
    -Paint with seam sealer (rustoleam has leak proof rubber stuff)
    Shell install and EAF electrical install
    -Things to get (inverter, solar controller, fuse panel, circuit breaker X2 OR master cutoff switch, 7 pin trailer wire for running electronics from inside to outside, make new switch panel)
    Maintence
    • spark plugs
    • throttle body clean
    • t-case, diff fluid change
    • need to buy: crush washer, drain/fill plugs all around, spark plugs...
    Other:
    Bocsy44, uurx and Manfred like this.
  5. Nov 22, 2017 at 8:49 AM
    #325
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    *lose
    *maintenance
    p.s. when you decide to do your spark plugs let me know we can do them the same day
    Bocsy44 and tacoma16[QUOTED][OP] like this.
  6. Nov 22, 2017 at 10:09 AM
    #326
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Have 5k till I do them lol.
  7. Nov 22, 2017 at 10:10 AM
    #327
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    can't recall the last time I did mine. how often do we need them done?
  8. Nov 22, 2017 at 11:48 AM
    #328
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    60 000km. Some do them earlier as they can be known to seize....I use anti seize and have been pretty good.
    Manfred[QUOTED] likes this.
  9. Nov 25, 2017 at 5:52 AM
    #329
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    If you are going to only have one set of lights for break and blinker you will have to tap into the trailer harness.
  10. Nov 25, 2017 at 6:07 AM
    #330
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  11. Nov 25, 2017 at 6:40 AM
    #331
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
  12. Nov 25, 2017 at 6:40 AM
    #332
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    It’s the plan for now. If not it’s cut and solder. Lol
  13. Nov 27, 2017 at 6:15 AM
    #333
    Kemosabe
    Louis
  14. Nov 27, 2017 at 6:20 AM
    #334
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Here for the Ute
    llamasmurf likes this.
  15. Nov 27, 2017 at 6:51 AM
    #335
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    llamasmurf and Kemosabe[QUOTED] like this.
  16. Nov 27, 2017 at 6:52 AM
    #336
    Kemosabe
    Louis
    but worth it!
  17. Nov 27, 2017 at 6:52 AM
    #337
    Kemosabe
    Louis
    Did you got the gears too? or later?
  18. Nov 27, 2017 at 6:54 AM
    #338
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah I hope so lol
    Going to get those in a month or so. Now that the lockers are purchased everything else should be smooth sailing as the lockers were the most expensive part.
  19. Nov 27, 2017 at 8:16 AM
    #339
    R09ster
    R09ster Well-Known Member
    Josh
    OK
    06 SSM DCSB TRD Sport
    debadged, Bilstein 5100 all around (fronts at 1.75" sport coils), Skyjacker softride 1.5" AAL, Firestone Ride Right Airbags, 17X8.5 Method NVs, 285/70/r17 Falken Wildpeak AT3W, US Offroad hidden winch mount, grillcraft grill, Sypder Auto projector headlights, blackedout LED taillights, bed extender, bedrack w/CVT Mt Shasta tent,
    sub'd for the flat bed. Should be fun! Sweet rig so far.
  20. Nov 27, 2017 at 12:50 PM
    #340
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Picking up the bed tomorrow and then hopefully the tare down can begin.
