Tail Gate question
Discussion in 'Technical Chat' started by rob99vmi04, Sep 17, 2008.
  1. Sep 17, 2008 at 6:19 AM
    rob99vmi04
    rob99vmi04 [OP] Member
    Fairfax
    SR5
    New Member here...
    I have an 06 Tacoma and the tail gate no longer works do the bar on the inside and the supports buckling. Somebody said this was an on-going problem and it maybe a recall anybody know anything about this.
  2. Sep 17, 2008 at 6:24 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Yes sir check this out. I do however believe the TSB is for the tailgate bending under weight. However check it out. TSB stands for Technical Service Bulletin.
    TSB List for 2005 - 2008 Toyota Tacoma
    Oh yeah and welcome to the site. rob99vmi04
  3. Sep 17, 2008 at 6:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There is a TSB for the tailgate (bent tailgate TSB).
    It's TSB number BO018
    Click here, scroll down and look for BO018. Then download it!
    Damn luk, you beat me to it!
  4. Sep 17, 2008 at 6:33 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    As Luke & Janster said ^^
    Welcome to TW & your first post! Good luck w/ the replacement!
  5. Sep 17, 2008 at 6:38 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    if your tailgate isn't bent, don't bother trying to get them to replace it. You know what you need to do before you go in there.
  6. Sep 17, 2008 at 6:39 AM
    rob99vmi04
    Fairfax
    SR5
    O Its bent.
    Sorry really dumb question am I going to pay for this?
  7. Sep 17, 2008 at 6:40 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    only if you are out of warranty.
  8. Sep 17, 2008 at 7:18 AM
    rob99vmi04
    Fairfax
    SR5
    Just called the dealership. Found out the warrenty is 3/36K I'm at 2 years and 35.204. YOU GUYS ARE AWESOME... I just saved close to $1,200.
    This happened last year and actually I took it into them to get it fixed and the guy told me that they would replace it for IIRC $1,200. I was like forget that I'm getting a net. But this is AWESOME set up an appointment tommorrow.
  9. Sep 17, 2008 at 7:23 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Even if you had been over, some dealerships will do the work as long as it is documented that this problem occured while it was under warranty. This has happened a few times with the rear spring TSB.
    BTW, have you gotten your rear springs and shocks replaced?
  10. Sep 17, 2008 at 7:25 AM
    rob99vmi04
    Fairfax
    SR5
    Nooooooo I have not.....are their more TSB's I should know about?
  11. Sep 17, 2008 at 7:27 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Check out that link I gave you It should list all the TSB for your truck.
  12. Sep 17, 2008 at 7:27 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    yes! You want the rear suspension TSB. You'll get stiffer springs and the TRD shocks all around.
  13. Sep 17, 2008 at 7:28 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
  14. Sep 17, 2008 at 7:30 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    The rear spring TSB will save you 1300 bucks. Or add that value to your truck. I love it.
  15. Sep 17, 2008 at 7:33 AM
    rob99vmi04
    Fairfax
    SR5
    Hey can I just take that entire list in and say guess what fellows please fix EVERYTHING. I have that darn clutch pedal squeak as well.
  16. Sep 17, 2008 at 7:37 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I wouldn't. I'd only go in and ask for what you actually want/need. For instance, you might not be getting any wind noise, so I wouldn't ask for new weatherstripping.
  17. Sep 17, 2008 at 7:40 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Have to agree with Isocoee just bring your main concerns. Maybe spread them out if you have a few.
  18. Sep 17, 2008 at 7:44 AM
    rob99vmi04
    Fairfax
    SR5
    Pardon me cause I'm truck retarded...I'm one of those point A-B people living in suberbia.....
    Basically I obvioulsy want the Tail gate fixed.
    I want ask them about the rear suspension TSB
    and the squeaky pedal problem.
    I'm printing up the TSB's and going in with them. Is that pretty much the best way to do it?
  19. Sep 17, 2008 at 7:45 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    The TSB's won't be done by just any shop I had to go to 3 different ones before I found someone to do it. Yes they are supposed to but you would have to take them to court, because in some ways they have the right o refuse. It is just easier to check a few different shops. I would call ahead, make sure you have your Vin number ready that way they can check to see if your vehicle is within specs of the TSB, you will also have to have the TSB in hand to help them find what you need.
  20. Sep 17, 2008 at 7:55 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    one of the links I sent posted had people post where they had the suspension TSB done. Try to find one near you and get it done there. They're supposed to do the alignment, but they may not. You need to insist on getting the alignment report from them.
    If it is just those three issues, then go ahead and bring them in.
