Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Dec 18, 2017 at 10:52 AM
    #301
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    yea...it acts like a heat sink
    helix66 likes this.
  2. Dec 18, 2017 at 11:52 AM
    #302
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    More resistance = less current (if voltage is the same).
    The problem is that there is actually 3 types of electrical load (resistance, capacitance, and inductive loads) and people are using the term "load" without specifying which type of load they are talking about. To add to the confusion, load is also referred to as power consumption (ex: in summer, the AC's put a heavy load on the power grid). So we just have to be careful and clarify the meaning of "load" sometimes (which I'm guilty of not doing too).
    Another problem is that the circuit is relatively simple until we add in the Turn as Tail module. Once we added that, we not only combined 2 circuits (the circuit for the brakes and the circuit for the turn signals), but we have now introduced a new sub-circuit in the middle of it all (the Turn as Tail module itself).
    Despite all of this, it's still a relatively simple system once you brake down each of the circuits...but it's not something that will be easy to explain on this forum either.
    I'm just guessing as to how the ECU is setup to detect a blown bulb, but it's probably just measuring the current draw to help it determine the resistance. Remember, the voltage is going to be relatively constant. So to find the resistance, it just needs to measure the current flow. It knows that the resistance of a bulb is within a certain range, so it knows what the measured current should be when the bulb is in place.
    Now when put in the LED's, they are much more efficient and do not require much current to produce the same amount of light. The problem is, the ECU is thinking that less current, means more resistance. When a bulb blows, resistance technically goes to infinity (and current goes to zero)...but the ECU is not programmed to hyperflash at an extreme point like inifity or 0 because it's not a plain vanilla circuit. Instead, Toyota programmed a value that would be fine for halogen bulbs, but not for efficient LEDs.
    So we have to add the resistor's in parallel to the turn signal LEDs so that the ECU see's the expected current & resistance for that circuit. But as I mentioned above, we've made this circuit a little more complex, so we are still trying to figure out what resistor value will reliably work for all of us. I believe 5 ohms works for some people, where others need 8, is because the resistors values can change slightly in different environments. The hotter a resistor, the more resistance it creates. So 5 ohms for me here in Hawaii might actually be more than it is for someone with that same resistor in a snow-covered driveway in NY.
    Now, I bet that we have not had any issues with the LED brake bulbs is because Toyota had to program a wider value (range tolerance) so as to cover the many different possible states (parking lights on or off, is the 3rd brake light included with the circuit, etc) that the turn signal does not have to worry about. I suspect that there are more bulbs in this circuit that introduce more variables that they need to account for.
    Sorry for the long post...hope it wasn't too confusing. lol o_O :rolleyes: :D
    Bastek, hirod, commbubba19 and 3 others like this.
  3. Dec 18, 2017 at 12:12 PM
    #303
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    But a resistor is adding "fake" current correct? It sends some to the bulb and then some to ground (through the resistor). It's still confusing how my situation ended up.
  4. Dec 18, 2017 at 12:43 PM
    #304
    ToyoDrew
    Texas
    There is no such thing as fake current.
    In this case, adding a resistor diminishes the current (through wasted heat).
  5. Dec 18, 2017 at 12:45 PM
    #305
    OdiN1701
    Colorado
    Hence the quotation marks around "fake" :p But wouldn't the current increase? The same amount of current has to get to the LED to power it, but then some also goes to ground via resistor. I thought this is what makes the truck think that there is enough. But as you said we don't know what it's measuring.
    ToyoDrew[QUOTED] likes this.
  6. Dec 18, 2017 at 12:57 PM
    #306
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    I'm too simple minded to understand all the nuances of electricity, but I'm hoping my complex issue will be resolved with a 8 Ohm resistor???
  7. Dec 18, 2017 at 12:58 PM
    #307
    OdiN1701
    Colorado
    Most likely it will.
  8. Dec 18, 2017 at 1:22 PM
    #308
    ToyoDrew
    Texas
    lol, I think you're going down the correct line of thinking.
    Think about it this way. Given the same current and voltage (aka the same "power" measured in Watts), an LED bulb's resistance will be less than that of the halogen bulb while still producing a similar output in lumens. You can actually feel that difference with how hot the halogen bulbs get compared to an LED bulbs. So in order for the ECU to see the resistance it used to see with the halogen bulbs, we are adding the resistor which does (slightly) effect the current flow...but within tolerances.
    Just remember that the resistor is being added in parallel (not in series), so it does not proportionally (linearly) change based on the amount of resistance we add. I think that's the part that may be confusing...
    I have a feeling that it'll work out for you. Of course, this assumes that there is nothing wrong with the Turn as Tail module itself. I had that problem initially, but the DD guys quickly fixed that for me (great customer support)!
  9. Dec 18, 2017 at 3:52 PM
    #309
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    @OdiN1701 - everything still working flawlessly on your truck now that you have 9 ohm total resistors in? I am just kind of waiting to make sure all the bugs were worked out by the ones who have already attempted it. I hope to do it this weekend.
    helix66 likes this.
  10. Dec 18, 2017 at 3:53 PM
    #310
    OdiN1701
    Colorado
    Yup I've had no issues since then.
    ratcityrain[QUOTED] likes this.
  11. Dec 18, 2017 at 5:08 PM
    #311
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    Hell YEAH!! :goingcrazy: I'd be all over this if you do it just like this: v v v v v
    This is EXACTLY what I have been wanting. Unfortunately, I can't afford your beautiful custom versions. Thanks, Stew. :bowdown:
    BTW... Once you post these kits, if you want me, I'll be camping that "Purchase Now" PayPal button.
    02Duck likes this.
  12. Dec 18, 2017 at 5:15 PM
    #312
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I'll revisit this mod offering after the first of the year and all my other little mods are done
  13. Dec 18, 2017 at 7:41 PM
    #313
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    I have a feeling that it'll work out for you. Of course, this assumes that there is nothing wrong with the Turn as Tail module itself. I had that problem initially, but the DD guys quickly fixed that for me (great customer support)![/QUOTE]
    @ToyoDrew. I've had a tough time with the DD guys. I'm hoping things will change quickly. I'm getting FAR more support here than DD. As to the TT module working, the fact that it works now when I do not have the resistor in place mean anything?
    I also wanted to ask you and @Double Phister. Why do I get no light output at all on my turn signal ( IN FACT, NO TURN SIGNAL ON MY DASH OR FRONT SIGNALS)when I do have the resistor hooked up?
  14. Dec 18, 2017 at 7:44 PM
    #314
    MESO
    State of Jefferson
    I also wanted to ask you and @Double Phister. Why do I get no light output at all on my turn signal ( IN FACT, NO TURN SIGNAL ON MY DASH OR FRONT SIGNALS)when I do have the resistor hooked up?[/QUOTE]
    I've posted my findings before. But our flasher relay is hyper sensitive. Either too LITTLE or TOO much resistance will both cause issues. Either hyperflash like crazy, or the opposite(what you are encountering) signals flash once and then go dead completely(have to turn truck off and back on to reset it). The trick is finding the happy medium.
    toyomaniac71[QUOTED] likes this.
  15. Dec 18, 2017 at 7:46 PM
    #315
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    I've posted my findings before. But our flasher relay is hyper sensitive from my findings. Either too LITTLE or TOO much resistance will both cause issues. Either hyperflash like crazy, or the opposite(what you are encountering) signals flash once and then go dead completely(have to turn truck off and back on to reset it). The trick is finding the happy medium.[/QUOTE]
    Always appreciate your input @mesojdm ! I'm still waiting for you to release the 3rd brake light mod!
  16. Dec 19, 2017 at 7:45 AM
    #316
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    My truck is new to me. I'm still in the pre-mod research phase. I'm just posting with general knowledge.
  17. Dec 19, 2017 at 11:13 AM
    #317
    ToyoDrew
    Texas
    @toyomaniac71 What do you currently have installed now? 4 rear LEDs (2 brake lights and 2 turn signals) and the TT module?
    Do you have any LEDs on the front turn signals?
    Also, what LEDs did you buy? I ask because some LEDs have more resistance than others and some people do not need to add resistors...but they aren't using the TT module either
    When I was testing things out, I noticed this as well. Too little resistance caused the hyperflashing and too much resistance caused it to signal once and then go dead.
    So when I was testing, I wanted to see if it was worth keeping the stock bulbs as a backup (in case an LED died on me). I had the Turn as Tail module installed with the 5 ohm resistor and LEDs and everything was working fine. Then I swapped out one of the LEDs for a the OEM halogen bulb and it flashed once and then went dead (and yes, nothing on my dash or front signal either). Not sure why the ECU reacted so weird, but it's obviously due to too much resistance. I was just happy that it still worked once I restarted the truck. lol
    I felt like I was dealing with my youngest child...he can be an overly picky eater sometimes. :p
    Anyways, those OEM bulbs are now in the trash. :)
  18. Dec 19, 2017 at 11:30 AM
    #318
    OdiN1701
    Colorado
    Probably worth it to pick up a spare set of LED's.
  19. Dec 19, 2017 at 11:35 AM
    #319
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I was just thinking and how are you guys with issues connecting everything? Could an issue lie in the way it's connected? I soldered mine because I wanted a solid connection. I could be completely talking out my ass but it was just a thought I wanted to throw that out there you never know. Had mine in for just over a week with 8OHM resistors in each side with no issues so far so good. Oh and I did relocate the resistors to the black metal piece behind the taillight like in the previous post.
  20. Dec 19, 2017 at 11:37 AM
    #320
    OdiN1701
    Colorado
    Doubt it. I did have and issue with one of the butt connectors on the DD module, so I removed those and replaced all with spade connectors. For the three wire point I soldered. While not an electrician, I'm pretty good with wiring.
