Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Aug 9, 2018 at 6:48 PM
    #581
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Ya I have some. PM me
  2. Aug 10, 2018 at 3:17 AM
    #582
    agabriel78
    agabriel78 Active Member
    2018 Cement DCSB
    I also need a pair, I contact you before for the same, thanks
  3. Aug 10, 2018 at 6:10 AM
    #583
    dj0mladen
    dj0mladen Well-Known Member
    Milan
    New Hampshire
    '17 TRD Sport Double Bed
    I still have it.
    Bastek[QUOTED] likes this.
  4. Aug 10, 2018 at 9:09 AM
    #584
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    So after months of flawless operation my right turn signal is now hyper blinking when it's on and I'm stepping on the brakes. If i jut turn it on then it's fine but as soon as I step on the brake pedal they go hyper on me. I had 8 Ohm 50w resistors in there so I just order some 10 Ohm 50w ones to replace them and hope that fixes the issue.
  5. Aug 10, 2018 at 9:39 AM
    #585
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    This is kind of why i stopped messing with the LED's in the rear tails. Not reliable. Remember, too high of a resistance makes the truck think the bulb is out and cause hyper flashing as well.
    I'd love to just use standard bulbs and have full C brake and full C turn signal leaving the reverse lights alone. Simple but more effective at the same time and not having to deal with the resistance problems.
    Tullie D likes this.
  6. Aug 10, 2018 at 10:28 AM
    #586
    Age315
    AJ
    Castle Rock, CO
    Yeah I was worried about doing this in the first place because I didn't want to chop up the wiring harness and have to deal with hyper blinking but here we are. I'm going to try and fix it with a 10 Ohm and if that doesn't work maybe just put it back to stock. That or maybe change it to the C as brake and moving the turns to the reverse lights.
  7. Aug 18, 2018 at 1:10 PM
    #587
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Did you get things worked out yet?
  8. Aug 18, 2018 at 7:19 PM
    #588
    Age315
    AJ
    Castle Rock, CO
    No still waiting on them to get here
    ToyoDrew[QUOTED] likes this.
  9. Aug 19, 2018 at 4:21 PM
    #589
    PacotheTaco17
    PacotheTaco17 Shake 'n Bake
    Caleb
    GA
    2017 TRD S 4X4 DCSB MGM
    Finally got around to doing the turn-as-tail mod, the basic one not the switchback amber/backup mod. Used 9ohm 50w resistors so we'll see if I run into the hyperflash issue down the road. I hated the oem taillight setup so I'm very happy to have anything different. Thank you @ToyoDrew for the wiring diagrams, that made the whole process a lot easier.
    Now the funny part... I'm definitely a beginner when it comes to wiring/electrical and learn as I go, and that bit me in the ass today. I wasted a good 3 hours because I didn't realize the TaT setup would only work with the LED bulbs. I wired the driver's side light, and figured I'd test it out before I went any further. Well, I hadn't put the LED bulbs in yet. I could not for the life of me figure out what I'd done wrong. After rewiring everything twice, swapping TaT modules and resistors, and trying on the passenger side light as well I gave up and put it all back to stock. Then, standing there with a beer and looking at the TaT packaging on the ground, I finally read the part that mentions it's only or LED tail light setups. Figured I'd give it one more go WITH the LED bulbs and sure enough. Couldn't do anything but laugh at myself.
    Anyway, anybody with the TaT setup and 9ohm resistors that hasn't run into the hyperflash yet?
    mcharfauros and ToyoDrew like this.
  10. Aug 20, 2018 at 9:47 AM
    #590
    Age315
    AJ
    Castle Rock, CO
    Just a cautionary work to check where your product is shipping from. So I wasn't paying attention when I ordered my 10 Ohm resistors from Amazon and turns out they are coming from China and will be here in about a month. Did a little more research and found https://www.alliedelec.com/ohmite-850f10re/70023443/ from Texas so I just ordered up some from them. The hyper blinking is driving me crazy and I need to fix it. I hope the 10 Ohm fixes it for good.
    ToyoDrew likes this.
  11. Aug 20, 2018 at 2:36 PM
    #591
    ToyoDrew
    Texas
    Great find and thanks for this note for others (cause it's a question that has come up a lot - what resistor should I get)?
    Age315[QUOTED] likes this.
  12. Aug 20, 2018 at 3:57 PM
    #592
    Age315
    AJ
    Castle Rock, CO
    I thought the same thing when I first did and ordered the 6 Ohm ones only to see that people were having issues with them so I ordered up the 8 Ohm and they have been good up until a week and a half ago. So hopefully the 10 Ohms fixes it for good. Just waiting on the tracking number because these should be here on Wednesday.
    tcjacado and ToyoDrew[QUOTED] like this.
  13. Aug 21, 2018 at 6:25 AM
    #593
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Instead of dealing with all these resistors and TAT modules, couldn’t we just tap into the trailer wiring which already sends a tail/brake/turn signal to a single light?
    I guess we would have to do something to keep the front from hyper flashing though if rear blinkers were disconnected in favor of trailer blinkers.
  14. Aug 22, 2018 at 12:21 PM
    #594
    Age315
    AJ
    Castle Rock, CO
    Of course once I ordered the new resistors I get the other ones the same day so now I have 2 sets of 10 Ohm 50 watt resistors. I have an extra set if some one needs them and can't find them. I will be swapping out the 8 Ohm ones this afternoon and hopefully that fixes my issue.
    ToyoDrew and PacotheTaco17 like this.
  15. Aug 22, 2018 at 8:07 PM
    #595
    ToyoDrew
    Texas
    "But of course", says Murphy
    lol
    tcjacado and Age315[QUOTED] like this.
  16. Aug 22, 2018 at 8:09 PM
    #596
    ToyoDrew
    Texas
    lol, I thought of this, but I think there needs to be some sort of load on the original rear turn signal harness and plus you will have to run a bit more wire to do all of this.
    Pickupman2007 likes this.
  17. Aug 23, 2018 at 6:09 AM
    #597
    Age315
    AJ
    Castle Rock, CO
    So I put the 10 Ohm ones in and so far so good. Everything works as it should and no more hyper blink when stepping on the brake. If anyone needs a set of 10 Ohm resistors I have an extra set for $10 shipped just DM me.
  18. Aug 23, 2018 at 7:28 PM
    #598
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    I'm doing the triton switchbacks in the reverse and using the "C" for brake. I already have the wiring diagram from this thread. I was wondering what bulb recommendations anyone has on a good bulb for my brake/running lights. I guess I would need 4 bulbs.
  19. Aug 23, 2018 at 9:02 PM
    #599
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Anyone with the Tail-As-A-Turn mod done do you feel like the brake lights seem to bright? I've been behind some vehicles at night at a stop & feel like their lights are too bright & blinding me. I kinda hate that. I've been planning on this mod for awhile but just wondering...
  20. Aug 23, 2018 at 9:11 PM
    #600
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I never feel that tail lights are too bright when running down the road. Sitting behind a bright set at a long stoplight is annoying to me. Because of that, I shift into neutral and stay off my brakes when I can.
    I won't even get into overly bright headlights (like HIDs in reflectors or poorly aimed LEDs), fogs on all the time, or peeps running high beams all day and night.
