Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Nov 19, 2018 at 11:18 AM
    #761
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Depending on the power your lights need you may be able to tap directly into the wire at your driver's side foot well. This is exactly what I did for my bed lights which are low power LED. For me this works perfectly, your MMV.
    However, if you need MORE POWER <Tim Taylor grunt-grunt> you will have to use a relay and have the cab switch output as your trigger. Be aware that this may cause chatter (Rapid on/off cycling) at the relay resulting is strobe effect at the lights.
    To avoid strobe a member here @DSIM makes a mod that will link into the dome circuit allowing it to turn lights on and off like your dome with the proximity of your key, open door, switched. You can also mod it to pull it's trigger from that cab light switch rather than the dome. He may be able to advise on the proper wiring.
    Good luck!!
    NoOne likes this.
  2. Nov 19, 2018 at 3:43 PM
    #762
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Tbh you guys have went over my head. I was just thinking I could simply find a connector to attach to the existing plug (let’s say has 4wires for argument sakes, 2 for brake and 2 for dome) pin 4 matching wires into the connector then run them to the back and hook up the caps brake light and the dome light. So essentially the caps third brake light will function as the trucks third brake with cab switch controls intact.
    As I sit here typing this I can see how the caps dome would be solely dependent on the switch in the cab. I was already thinking of putting a switch on the rear glass to turn on when opened but I see now I would have to tie into the door ajar function… maybe this is what you guys are talking about or hinting at? I’d definitely prefer this route. It might be a little bit more than I thought at least for the dome light/door ajar function.
    I don’t have any dome lights as of now installed. I’m thinking of just 1 strip on the backside of the third brake light facing down and in will be sufficient for my needs
  3. Nov 20, 2018 at 2:33 AM
    #763
    TC_Mic
    OK.. now I think I understand what you want. To be sure, this is what I understand you want... 1. a light inside you cap that will come on with the Cargo/cab light via the switch to the left of the steering wheel. 2. The bake light in the cap to light up when you hit the brakes.
    #1 pull lower left dash for access to the switch. Run BOTH wires from your LED mounted inside your cap under the truck, through a grommet to said switch. Unfortunately I do not recall which 2 wires I tapped for my bed lights. I did use google to find a schematic and a meter to verify google was correct to determine these. I can pull my lower dash after Thanksgiving to see which ones I tap and let you know if you like but it will not be prior to Saturday. Once tapped the light will come on when the switch is in the "auto" (doors opening and closing) position, and can be switched on at any time as well.
    #2 Simple matter of using a tap to pick up power from the brake light, either right or left at the tailgate. See wire schematics in this thread for exactly which wire to tap. There are several screws in the tail light area that can be used for grounding. Problem solved 3rd brake light will now work.
    If I understand your wants correctly, your answer is there. If not please help us understand so we can help you more effectively. Either way there is NO need to use the plug to the cab mounted brake and cargo light. to do so you would also have to pull the headliner and make a LOT more work for yourself than using the method as @tonered and I have suggested and explained.
    Good luck!!
    NoOne likes this.
  4. Nov 23, 2018 at 3:12 PM
    #764
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
  5. Dec 4, 2018 at 8:57 AM
    #765
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Hey man, you still working on this? @mesojdm
  6. Dec 4, 2018 at 6:58 PM
    #766
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Yup! Finishing up the first set of test harnesses
    I also have another development going on for the switchback reverse bulb. I’m working with an LED company to manufacture a T10(921) size that will pop right into the lower reverse bucket. So ZERO modifications to the tail lights will be necessary. 100% plug and play dual brake/switchback reverse kit.
  7. Dec 4, 2018 at 7:20 PM
    #767
    Captbrad88
    Captbrad88 Well-Known Member
    Brad
    2018 Tacoma trd offroad
    You planning on making anymore of those third brake lights or interior lights again?
  8. Dec 4, 2018 at 7:24 PM
    #768
    MESO
    State of Jefferson
    I’m always making more. But I jump around on production so if it’s not in stock, just wait until I make my way around to that particular mod again:)
  9. Dec 4, 2018 at 7:50 PM
    #769
    MESO
    State of Jefferson
    Not sure yet, still in development stages and price/distribution sourcing. I think I am going to do a full LED conversion kit(double brake, switchback bottom, T harness) full plug and play.
  10. Dec 4, 2018 at 7:51 PM
    #770
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Awesome! When is Christmas? Are you still going to make your led taillights?
  11. Dec 4, 2018 at 8:53 PM
    #771
    Eticket
    Eticket Well-Known Member
    Thomas
    Holly Springs, NC
    2016 Tacoma TRD Sport 4x4
    Stewart, I know I’m in for a set when your ready.
    Thanks.
    savethewheels likes this.
  12. Dec 4, 2018 at 10:06 PM
    #772
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Looking good!
  13. Dec 4, 2018 at 10:14 PM
    #773
    baldbeardedtaco
    FL
    Sorry for the confusion but I just don’t want to tap/splice into the factory wires just yet. I’d rather find connectors/plugs for the time being.
    I know it’s being “extra” and adds more work/cost but it’s the route I want to try and go for as long as possible
  14. Dec 5, 2018 at 5:07 AM
    #774
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Got another future sale right here
  15. Dec 5, 2018 at 5:46 AM
    #775
    Riderfan
    Riderfan Active Member
    Doug
    RCI Sliders / Fox 2.5 + Fox 2.0 /
    Add me to the future sale list too!
  16. Dec 5, 2018 at 6:21 AM
    #776
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    :drool::drool::drool:
    ...and that's all I have to say about that.
    tonered likes this.
  17. Dec 5, 2018 at 6:24 AM
    #777
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    Please and thank you :bowdown:
    tonered likes this.
  18. Dec 5, 2018 at 6:42 AM
    #778
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Your mama taught you right. :cheers:
    savethewheels[QUOTED] likes this.
  19. Dec 5, 2018 at 7:45 AM
    #779
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    +1 for full LED conversion kit.
  20. Dec 5, 2018 at 3:34 PM
    #780
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    @mesojdm jopefully you will consider selling DIY connector parts like you have for some other pieces.
