Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Feb 2, 2019 at 7:07 PM
    #1061
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Yeah that was a theory which it have not tried yet. Scratch that. Vaccum would be a good idea as well. I guess I’ve been spoiled with my ultrasonic knife, cuts through like hot butter and no chips.
    If anyone is afraid to do this mod, I can offer the service just pay the shipping round trip and send me your lights.
    $110 and $240 respectively:D
  2. Feb 2, 2019 at 8:00 PM
    #1062
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    is it possible to get just the harness itself?
  3. Feb 3, 2019 at 8:53 AM
    #1063
    Quimby
    Quimby Well-Known Member
    NYC
    2017 TRD OR AC
    Definitely in for a Stage 1 kit.
  4. Feb 3, 2019 at 9:22 AM
    #1064
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Great work Stew. Thanks for doing this. Looking forward to making a purchase soon.
    GaryLaurenLogan and HNLSFO1 like this.
  5. Feb 3, 2019 at 2:20 PM
    #1065
    Rewilliams
    Rewilliams Well-Known Member
    Robert
    2017 Tacoma
    With the stage 2 kit can I use your harness and use Triton red bulbs for the top 2 bulbs? If so do I need to use a step drill on them too.
    HNLSFO1 likes this.
  6. Feb 3, 2019 at 4:06 PM
    #1066
    reNeglect
    reNeglect Well-Known Member
    I made my own harness for a similar mod:
    Diode Dynamics tail as turn (DIY Kit)
    Bought 4x Plug n Play 7443 resistors (https://www.amazon.com/dp/B071JNHMP3)
    Bought 4X JDM AStar Red Led Bulbs.
    Instead of having to splice/tap into the OEM factory wiring, by using the plug n play load resistors I was able to splice and tap into that wiring instead.
    Currently, my tail lights top and bottom would serve as running lights (50%), brake lights, and turn signals. However, the DIY module from Diode Dynamics has this minor thing which I don't like.
    When Brake and turn signal is triggered at the same time, the rear tail light turn signal is off sync. Diode Dynamics response is that it is done so for safety reasons, however, I believe its some sort of issue with the chipset or whatever it might be.
    The benefit I guess for this version since the turn signal has been relocated to reverse lights this issue is alleviated...
    Victory likes this.
  7. Feb 3, 2019 at 4:41 PM
    #1067
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    I also trust MESO's work far more than my own for things like this. I'd somehow short the whole damn truck out :rofl::bananadead:
    quikandskinny, Ray1989 and CygnusX191 like this.
  8. Feb 3, 2019 at 7:33 PM
    #1068
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    The Triton will fit the upper two sockets without modifications. It is only the lower socket that is a smaller size, requiring the drilling and adapter. The Triton wiring adapters will allow you to “make it work”. But, a cleaner wire-up could be done... much like he has for the switchback, integrating the Triton harness.
  9. Feb 3, 2019 at 9:17 PM
    #1069
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    I'm using the Diode Dynamics DIY module, too, and I'm not having this problem. My LED brake/turn bulbs (I used 4x Endpage 7443 on Amazon) flash at exactly the same time as my front 7443 LEDs (also Endpage) and my side mirror turn signals (stock).
  10. Feb 3, 2019 at 9:19 PM
    #1070
    iampraneel
    iampraneel Well-Known Member
    2016 DCSB TRD Sport 2WD
    What do you mean off sync? Also, did the plug and play kit, you bought from Amazon, fit into the socket hole of the tail light?
  11. Feb 3, 2019 at 9:21 PM
    #1071
    reNeglect
    Off sync as in the fronts blink and the rears blink after its turned off.
    This only happens when the brake is depressed at the same time.
    It does not do this when no brakes are depressed, that’s why after it’s installed and you test the flashers it blinks at the same time and in sync.
  12. Feb 3, 2019 at 9:23 PM
    #1072
    BearWithMe
    Prior: '18 OR 6MT
    So you're saying it blinks one extra time (after you cancel the turn signal) if the brakes are applied? I'll have to test this tomorrow.
  13. Feb 3, 2019 at 9:29 PM
    #1073
    reNeglect
    No, like this is how the blinkers would be:
    Front Headlight - Blinks
    Side Mirrors - Blinks
    Rear Tail Lights - Not Blinking
    Front Headlight - Not Blinking
    Side Mirrors - Not Blinking
    Rear Tail Lights - Blinks
  14. Feb 3, 2019 at 9:39 PM
    #1074
    iampraneel
    How many resistors do you have total? If you bought 1 set of the plug and play for each side(drivers and passenger)that would mean you have 4 resistors, a total of 8.
  15. Feb 3, 2019 at 9:49 PM
    #1075
    MESO
    State of Jefferson
    It’s not about the QTY or load of resistors. It’s totally out of sync due to the way the tail as turn module works. For all other dedicated turn signals(headlight, mirrors,etc) they flash ON when turn is activated. With the brake lights already on, it has to turn them OFF in order to flash pattern. So although they are technically using the “brake light” as turn signal, it’s going to be 180° sequenced from all the others. Minor annoyance for OCD people.
    This kit will not have Tail as turn module.
    It will keep a dedicated BRAKE light, and add a whole new color for the turn signal. :)
  16. Feb 3, 2019 at 9:56 PM
    #1076
    iampraneel
    iampraneel=OCD
    Dude. When is your kit going to be avail? Do you have an ETA?
  17. Feb 3, 2019 at 10:32 PM
    #1077
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Well that takes the tat mod off the list then
  18. Feb 4, 2019 at 2:32 AM
    #1078
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Search Meso's posts in this thread
  19. Feb 4, 2019 at 4:18 AM
    #1079
    Rewilliams
    Robert
    2017 Tacoma
    @mesojdm when do you think the stage 2 wiring harness by it self will be for sell.
  20. Feb 4, 2019 at 8:58 AM
    #1080
    arexseven
    arexseven Well-Known Member
    Derek
    2018 Cement TRD Off Road
    RCI Skid Plate Bilstein 5100’s Spydertrax Spacers PIAA LED Headlights Cali Raised LED Fogs TRD Pro Tail Lights TRD Pro Grille Debadged with Black Tailgate Inserts
    I’m in for either Stage, whatever I can get my hands on!
