Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Nov 14, 2017 at 11:30 PM
    #121
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I just finished up changing over to LED’s for the tail lights and the backup lights. I went with Diode Dynamics Tail as Turn modules, Sylvania red LED’s 7443R for brake and turn, Sylvania 921 Super Bright 6000K LED’s for the backups and 6 ohm 50 Watt resistors to stop hyper flash. Definitely worth the money to have upper and lower acting as brake and turn signals plus the LED’s are brighter. Thanks ToyoDrew for your post, saved me looking that stuff up!
    DakoTaco and ToyoDrew like this.
  2. Nov 15, 2017 at 6:44 AM
    #122
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Just ordered the tail as turn and resistors from Diode Dynamics. Now I need to pick up some LED's for the tail and back up lights. Thanks for all the write ups in here because you guys make it look so easy.
  3. Nov 15, 2017 at 8:29 AM
    #123
    Captqc
    Tigard, OR
    It was easy! I soldered all of my connections and it only took an hour to do both sides, it would have been even quicker if I had used quick connectors but I prefer soldering these type of applications.
    Age315[QUOTED] likes this.
  4. Nov 15, 2017 at 8:53 AM
    #124
    Age315
    AJ
    Castle Rock, CO
    I'm debating on soldering or not. I'm the greatest at it but it really is better to do.
  5. Nov 15, 2017 at 8:55 AM
    #125
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Well then it should be cake!
    Skeou, 96ti, johnny6 and 2 others like this.
  6. Nov 15, 2017 at 8:59 AM
    #126
    Age315
    AJ
    Castle Rock, CO
    Hahaha! I meant not the greatest at it thanks for catching that. My skills are no where near yours. Man I need more coffee.
    ToyoDrew likes this.
  7. Nov 15, 2017 at 11:49 AM
    #127
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Glad to help out and give back to this great community. :cheers:
    ChadsPride likes this.
  8. Nov 15, 2017 at 4:43 PM
    #128
    Ray1989
    Ray1989 Well-Known Member
    SoCal
    3rd Gen Sport
    @mesojdm theres no Triton v3 so ima be as patient as i can and wait for the new v6
  9. Nov 16, 2017 at 11:08 AM
    #129
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    @mesojdm - weren't you considering making a kit to turn both lights into brake lights and move blinker down to reverse hole using a switchback for blinker and reverse? I'm trying to find that post, but I cannot find it.
  10. Nov 16, 2017 at 11:13 AM
    #130
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    This thread page 3 post #52.
    Edit: I too am looking for @mesojdm to produce them. I may try to find the plugs,switchbacks, LED's for the uppers, etc.... but I know he has the skills to do it right and make it a straight PNP.
    ratcityrain[QUOTED] likes this.
  11. Nov 16, 2017 at 11:14 AM
    #131
    ratcityrain
    Seattle, WA
    Exactly what I was looking for. I guess my memory thought it was in a different thread, not this one. Thanks for showing me where it is
    TC_Mic[QUOTED] likes this.
  12. Nov 16, 2017 at 11:28 AM
    #132
    ratcityrain
    Seattle, WA
  13. Nov 16, 2017 at 11:41 AM
    #133
    TC_Mic
  14. Nov 16, 2017 at 11:43 AM
    #134
    ratcityrain
    Seattle, WA
    Great thanks. I'm trying to decide between wiring both lights to be brake and signal or to go the route of mesojdm and move the blinker down to reverse section.
  15. Nov 16, 2017 at 11:56 AM
    #135
    Ray1989
    SoCal
    3rd Gen Sport
    @mesojdm post up ur wiring diagram for making both the top and stop light the bottom as a turn signal. Im waiting for the new triton v6 to come out since they dont have the v3 and im going to use rigid ignite flush mount for my reverse well thats the plan.
  16. Nov 16, 2017 at 11:56 AM
    #136
    Captqc
    Tigard, OR
  17. Nov 16, 2017 at 11:58 AM
    #137
    TC_Mic
    From my researching... The combining of the signals using the DD module is the cheaper and easier solution. That said you are cutting 2 wires and inserting the module. You could revert back to stock by removing the DD module and reconnecting the blinker and brakes as they were originally.
    @mesojdm suggested making a full PNP setup. So if I understand correctly... unplug the socket from the harness and plug it into his harness then his harness either plugs into the socket or replaces the socket, depending on how he builds it, then the LEDs go in for the top section. The switchback would require the reverse light hole to be expanded/enlarged to accomidate a T20 LED (in his custome made adapter) vs the current T10 socket holding the single white reverse light. This will make the diameter of the hole to large to revert back to stock.
    tonered likes this.
  18. Nov 16, 2017 at 11:59 AM
    #138
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  19. Nov 16, 2017 at 12:41 PM
    #139
    splashflash
    splashflash Vagabonding
    Art
    Timnath, CO
    17 DCSB 4x4 M/T Off-Road
    If you go this route, know that the wires you cut are too big for the small butt connectors. You will need to replace them with bigger 14awg blue ones or just solder them together. No one mentioned this beforehand unless their kit was different.
  20. Nov 16, 2017 at 1:17 PM
    #140
    ratcityrain
    Seattle, WA
    This is a good point and I do agree with you. I have always liked the way mesojdm's tail lights turned out when he did his led lights so if he went that route then I would assume the risk of enlarging the reverse hole.
    Thanks for letting me know. I most likely will solder since it's a better connection.
