Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Nov 21, 2017 at 9:12 AM
    #161
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Does anyone have a link to male and female adapters that I could use to wire up the Diode dynamics t as t module so that I don't have to cut/splice/solder to oem wires? I prefer, if possible, to make a harness so it's plug and play.
    Wero94 and BigWhiteTRD like this.
  2. Nov 21, 2017 at 10:56 AM
    #162
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Run a search on eBay,or Amazon. I saw some that I think will work.
  3. Nov 21, 2017 at 1:53 PM
    #163
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    If anyone is looking to do this mod Diode Dynamics is having a black friday sale. Use code BLACKFRIDAY for 20% off.
    ToyoDrew likes this.
  4. Nov 21, 2017 at 1:54 PM
    #164
    ratcityrain
    Seattle, WA
    Of course after I already purchased it lol
    Age315[QUOTED] likes this.
  5. Nov 21, 2017 at 7:01 PM
    #165
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I was thinking the same thing. I asked earlier in the thread and got no suggestions to build a no-cut harness. If you come up with anything please let me know.
    Right now I am trying to see if I can do a no-cut splice at the 7 pin trailer connector. I figure that a single male and female at this location gets all the rear light functions....
  6. Nov 21, 2017 at 7:03 PM
    #166
    Ray1989
    Ray1989 Well-Known Member
    SoCal
    3rd Gen Sport
  7. Nov 21, 2017 at 8:05 PM
    #167
    ratcityrain
    Seattle, WA
    I cannot find connectors for the socket connection, but was thinking the same thing in ordering a trailer kit that has the connectors
  8. Nov 22, 2017 at 5:14 AM
    #168
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    FWIW.. I bought a T harness from Amazon when I put on my tailgate bar. It was a M/F 7 that when between the stock harness and trailer plugs and had a 4 pin trailer plug on a tail. I belive this is the one I got, even though it does not say it works for Taco it does.
    https://www.amazon.com/Tekonsha-118...356317&sr=1-1&keywords=hidden+hitch+t+harness
    Good luck with your mods. I am still hoping @mesojdm , or someone, does a no cut harness with the switchback signal on the reverse bucket and full brake above in the near future. If not I will work a bit harder to find the proper plugs and make my own after March18 or so.
  9. Nov 22, 2017 at 7:37 AM
    #169
    ratcityrain
    Seattle, WA
  10. Nov 22, 2017 at 8:00 AM
    #170
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    "T"-ing off the trailer harness would work, but you are still in the same boat trying to source the male end connectors to go back into the tail light. I use the stock socket adapters and solder to the inside.
    tonered likes this.
  11. Nov 22, 2017 at 8:01 AM
    #171
    ratcityrain
    Seattle, WA
    That's a good idea to purchase oem sockets and solder to inside. I have emailed TRD Sparks to see if they would be able to sell just the connectors and awaiting an answer
  12. Nov 22, 2017 at 9:03 AM
    #172
    BigWhiteTRD
    Ted
    That would be great. OEM connectors from a dealer (assuming I pulled the right PNs) are all in the $8/connector range from what I have seen, and it's just too much for me to justify.
  13. Nov 22, 2017 at 9:11 AM
    #173
    ratcityrain
    Seattle, WA
    The turn signal connector part number is 90980-11020 that connects to the harness that was provided to me from TRD Sparks. Here is a link I found to that part
    https://www.sparksparts.com/oem-parts/toyota-housing-connector-f-9098011020
    So if I did the math right, it would be approx $60 for 4 of the above part to connect to the harness on both sides for the brake and signal and then for 4 socket parts to connect to bulbs.
  14. Nov 22, 2017 at 9:42 AM
    #174
    TC_Mic
    So for those of use waiting for your magic and skills.... you ARE making a no cut, switchback setup. Right @mesojdm
    :boink:
    :D
    ratcityrain and tonered like this.
  15. Nov 22, 2017 at 11:24 AM
    #175
    ratcityrain
    Seattle, WA
    I agree lol
  16. Nov 22, 2017 at 11:37 AM
    #176
    MESO
    State of Jefferson
    Maybe. Just not at the top of my mod list right now. There are 2 routes I need to brainstorm for a PNP setup.
    1) Source the male OEM Brake/Turn signal connectors so they would plug into the stock light bulb sockets that are mounted in the tail light
    (I have an abundance of the female connectors so that's not an issue.
    2)Replace both OEM bulb sockets(brake/turn) with a universal t20 socket adapter, thus not having to worry about finding the OEM male connectors.(although female factory connectors would still be utilized to plug into the vehicle side)
    Here is a picture showing how I adapt the Turn signal connector(black), how I solder to the brake connector(grey), and the 3d Printed cap I designed to plug the old hole at the top.(since I am running switchbacks at the bottom)
  17. Nov 30, 2017 at 4:52 PM
    #177
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    THIS is why I love TW! Thank you!!
    ToyoDrew[QUOTED] likes this.
  18. Nov 30, 2017 at 10:13 PM
    #178
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    I think I'll be making both tail lights as brake lights, and have switchbacks for reverse for the turn signal as well....I have access to OE Toyota parts so I'll eventually make a plug and play harness, hopefully there's enough room behind the taillight
  19. Nov 30, 2017 at 10:18 PM
    #179
    MESO
    State of Jefferson
    Ample room.
    the_dau[QUOTED] likes this.
  20. Dec 1, 2017 at 2:36 PM
    #180
    ratcityrain
    Seattle, WA
    Plan to wire mine up on Monday. I have heard mixed reviews, but should I put a resistor on blinker side to eliminate hyper flash?
