tail lights gone out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bruwster88, Aug 14, 2013.
  1. Aug 14, 2013 at 5:31 AM
    Bruwster88
    Bruwster88 [OP] Member
    2006 tacoma sr5
    Help a helping driver shouted over to me last night, stating I had no tail lights. My brake and signals work but not the running lights. Any ideas would help. 2006 4dr taco sr5
  2. Aug 14, 2013 at 5:45 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Check the fuse first. I've had it happen a couple times. If I remember right its the top row third from left? Don't quote me on it. Just look at the panel and test them
  3. Aug 14, 2013 at 5:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Have you done any electrical lately, trailer harness, etc.? Definitely check the fuse, then check your bulbs. Crazy at it seems, I have had both go out at the same time.
  4. Aug 14, 2013 at 6:00 AM
    Bruwster88
    2006 tacoma sr5
    I replaced a headlight and front right turn signal last week, first headlight 3 weeks ago. Maybe they are all burning out at the same time. Just looked at the tail light for removal and no idea how they come out. Does that section of bed liner have to be removed to get at the mounting screws.
    I'm checking the fuse before doing anything else.
    THX
  5. Aug 14, 2013 at 6:01 AM
    Bruwster88
    2006 tacoma sr5
    Will do, I needed the location and that helps.
    THX
  6. Aug 14, 2013 at 6:03 AM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
  7. Aug 14, 2013 at 6:04 AM
    Bruwster88
    2006 tacoma sr5
    Any idea how to get at the bulbs? I would like to upgrade the tail lights, so it would be good the figure out the removal now.
  8. Aug 14, 2013 at 6:06 AM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    You have to remove the light and the bulbs come out the back. Just twist and they come out. Tails should be the middle one I think
  9. Aug 14, 2013 at 7:16 AM
    81shark
    81shark Well-Known Member
    get yourself a 10mm socket. i think there are two bolts that hold it in place.
  10. Aug 14, 2013 at 7:40 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  11. Aug 14, 2013 at 7:43 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    yeah 2 bolts that hold it in place and everything else is pretty much twist and pop. i had to replace 2 bulbs and a whole tail light because someone hit me. its pretty simple
  12. Aug 14, 2013 at 7:44 AM
    Bruwster88
    2006 tacoma sr5
    That is an excellent post. Thanks so much. As soon as I get this bulb issue fixed, I'm picking up some upgraded tail lights.
    B
  13. Aug 14, 2013 at 12:06 PM
    Bruwster88
    2006 tacoma sr5
    That was it, changed the fuse and that fixed it.
    Thanks for the help
  14. Aug 14, 2013 at 12:12 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I bought led replacement lights off eBay that are good for like 50,000 hours but I had to take a file and trim a little cuz the base was bigger than the incandescent. just a heads up
  15. Aug 14, 2013 at 12:15 PM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    :thumbsup:
