Tailgate ez down struts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808trdsport, Dec 5, 2008.
  1. Dec 10, 2008 at 6:05 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    From what I have read, it will not work because the torx bolt you have to remove doesn't exist on the '08 and up.
    Marc M
  2. Dec 10, 2008 at 6:08 AM
    Joe B
    Joe B Well-Known Member
    Thanks Marc,I almost ordered it.:)
  3. Dec 10, 2008 at 11:27 AM
    808trdsport
    808trdsport [OP] Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
    my 08 has the T-40 torx bolt. And my ez down fits. I still have to do something about the cable getting in the way.
  4. Dec 10, 2008 at 5:30 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    Maybe it's just the '09 then, I knew it didn't fit the newer trucks, mabye it's just the '09's.
    Marc M
  5. Feb 26, 2009 at 7:12 AM
    TRDfly
    TRDfly Well-Known Member
    Traverse City, MI
    Silver 07 DC, TRD off-road....it's the bomb!!
    DRL, Black Headlight mod, H.I.D's, Wet Ass Seatcovers, White instrument cluster, Illuminated 4x4 switch.
    I've had an issue with mine and I have 2007! I called the makers of EZdown and got the whole scoop. It appears later model Taco's have the problem of too little clearance for this to work. The lady I spoke with said it affects a mixed batch of Taco's, 50% work with no issues and others it won't work.
    Now, as for the torx screw on the tail gate, I had to have the dealer remove mine. it was impossible for me to do it at home, just didn't have the tools.
    I purchased mine from Redline along with the hood struts thru the group buy here months ago. I'm just getting to put these on and now I have to hope they will take the EZdown back. Crossing my fingers.
  6. Feb 26, 2009 at 7:34 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I've had mine on on my 08 since last September. It is tight, but I have no rubbing issues with the strut, or the cable. The only issue is the cable is bent very tightly when the tail gate is closed. The cable originally made a nice loop, but it now is pinched to a sharp angle. I would assume the cable will eventually wear from the pinching. I like the dampening effect, and will worry about replacing the cable when the time comes. The gate drops a bit faster than what they show on their video, but here in Canada, it gets really slow in the cold winter months. The strut is a little short, and the cable is just shy of taking the weight of the gate when it is open.
  7. Feb 26, 2009 at 7:54 AM
    txusa03
    txusa03 Well-Known Member
