Tailgate Strength
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C_Teachout, Nov 8, 2009.
  1. Nov 8, 2009 at 4:25 PM
    C_Teachout
    C_Teachout [OP] Active Member
    Herkimer, NY
    09 Tacoma TRD Sport
    As winter approaches so does snowmobile season up here in the north. Therefore my question is how strong are our tailgates. Will i bend the tailgate with ramps on it when i drive my seld up in the back end. I've seen guys with wheelers in the back end so there about the same weight.
  2. Nov 8, 2009 at 4:56 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    There is a ton of info on this forum on the strength/weakness of the tailgate. Use the search and you will get an evenings worth of reading.
  3. Nov 8, 2009 at 5:02 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    I'd remove the tailgate and leave it at home.
  4. Nov 8, 2009 at 5:04 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    That'd be alot of weight for the tail gate to hold I think
  5. Nov 8, 2009 at 5:10 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I put a 7.5HP Ariens with home made ramps a few times last winter. No problems as of yet. The only problem is the long ass ramps I need to keep me at a good angle going up.
  6. Nov 8, 2009 at 5:11 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    You have a 2009. It doesn't have the same tailgate as the older ones that have the TSB for bending. I haven't heard of anyone bending an '09-'10 tailgate.
    That said, it's alot of weight for any tailgate :p
  7. Nov 9, 2009 at 9:08 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    After installing the pop & lock on my 09 I couldn't believe how much support the tailgate is lacking. This thing is weak. I's be nervous hauling a snowmobile on my gate. I hauled my atv a few times with no issues but the snowmobile might warp it where it sits towards the middle more.
  8. Nov 9, 2009 at 9:12 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    x2 They are too expensive.
  9. Nov 9, 2009 at 10:46 AM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    here is an idea....what if you got a good 2X10 and cut it the length of the belt (i think that is what it's called, i'm talking about the big drive thing that actually hits the snow for traction, like the back wheel).
    Once the 2X10 has been cut make sure it's under the belt when you pull the sled in the truck(lay the piece of wood length wise with the bed, then you will have that to evenly distribute the weight on both the bed and tailgate as well as just providing more overall survce area and even pressure.
    What do you do you guys think?
  10. Nov 9, 2009 at 11:30 AM
    grammy
    grammy Well-Known Member
    4x4 v6 X-Cab
    Well, it is called the track for starters, but I wouldn't say you see them too often in CA. The lenthwise 2x10 is a good idea, and I see people doing that. I have not used my 09 with the skidoo yet, but I used to haul my 08 Renegade in my 2001. After I loaded the machine in the bed, I would lift up the rear of the skidoo up and put a 2x4 widthwise in the grove where the tailgate meets the bed. That would keep the weight off the gate when going over the bumps, but keeps the tailgate on just in case you need it, as most new snowmobiles are 9feet+ long, so the longer the bed is the better.
    Another problem is the skidoos are a bit too wide to fit between the wheelwells (although some mountain machines may fit as they are narrow), so I built a small bracket just inside the wheelwells to keep the skis at the same level. This prevents the track from being tipped slightly, so it evens out the weight even more.
  11. Nov 9, 2009 at 4:20 PM
    C_Teachout
    Herkimer, NY
    09 Tacoma TRD Sport
    it's a 78 Moto-ski 440. they didnt make them like the monsters on the trail now. Im not to concerned with the constant weight while transporting. Its that begining weight when I drive the sled up in there. I think I will be pulling the gate off, just wanted to see if anyone else transported with these with luck. Even guys who have loaded wheelers with the tailgate. Its about the same weight.
  12. Nov 9, 2009 at 4:36 PM
    grammy
    4x4 v6 X-Cab
    My skidoo weighs around 700lbs+ with rider and fluids and I keep the tailgate on. Your moto-ski is around 390 without rider. I really dont think it will be a problem on your tailgate, it will fit between the wheelwells so it will be flat and most of the weight will be in the bed of the truck. But if you fell more comfortable with the tailgate on, I am sure it will be just fine, as it is not a long machine.
