Tailgate theft?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Galileo7, Sep 25, 2022.
  1. Sep 25, 2022 at 4:04 PM
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    I was with you all the way until the bottom. So you do all that, but then just leave it unlocked. What is the sense in that?
    I do the hose clamp and face the head down, but only on the off chance that I FORGET to lock the tailgate, which I havent forgot yet.
    I get that locks can be picked, but if the scumbag has the knowledge and fortitude to pick the lock, I dont think the little hose clamp is going to be a problem.
    Galileo7[OP] likes this.
  2. Sep 25, 2022 at 5:41 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Wrong. The only person responsible for the safety of your person and property is you.
  3. Sep 25, 2022 at 6:35 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I have seen posts where owners put washers on the wire to keep it from being taken off. Does anyone know the size of these washers?
  4. Sep 25, 2022 at 6:46 PM
    Kllrbee
    Tim
    Bloomfield, WI
    Best thing to do is go to your local hardware store and find what works best. The size of the washer really isnt the issue, its that you'd need to find a spacer thats wider than the washer to fit between the bolt and the ID of the washer. Once you take the tailgate bolt off, youll see what I mean. Wont be an issue, just need to find what fits.
    The spacer would be so the washer wont get tight enough, so the tailgate cable still has the proper amount of free play.
    Galileo7[OP] and musicisevil like this.
  5. Sep 25, 2022 at 7:17 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Kllrbee is right. The larger washer is easy enough to find if you take the bolt with you, but the tiny washers are the hard part.
    A post I linked in the above comment calls for a “#12m fender washer” for the large one, whatever that is
  6. Sep 25, 2022 at 7:27 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I didn't go as far as you but I did use a hose clamp with a square drive and used some funky combo of extensions and a universal adapter to position the head as frustratingly as I dared but still removable at home should I need to like you.
    With my topper and dual swing outs there's already more steps to get to it vs someone with an open bed and standard bumper.
    Even still been considering coming up with some kind of lock bar for the swings but just never really felt the need.
    Most people I tell to go grab anything out of the back return with "how do I get into it?"
    Hopefully a thief would glance at it and think the same before moving along.
  7. Sep 25, 2022 at 7:42 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i've got a roll-up tonneau cover. and 6 years of ownership with convertibles.
    i'd rather they take the tailgate than slice the tonneau. because then i'm out the tailgate, and the tonneau. not that my cover is so expensive, i'd just rather not need to go through the hassle for both.
    i also don't keep anything of any value in the bed, but use the truck like a truck at random intervals. an electronic lock is a distinct possibility, but manually locking it presents extra difficulty in my use of the truck that i'm not willing to sacrifice.
    Kllrbee[QUOTED] and Key-Rei like this.
  8. Sep 25, 2022 at 7:50 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    this is a good option too and only 15-20 bucks
    mcgard the locking lug nut company
  9. Sep 25, 2022 at 7:52 PM
    Jes963
    Jes963 Well-Known Member
    Fontana CA
    2018 Tacoma Trd pro
    willtill likes this.
  10. Sep 25, 2022 at 7:53 PM
    RIX TUX
    i looked at that but i didnt know if there was enough room to fit a washer in there
  11. Sep 25, 2022 at 7:59 PM
    Key-Rei
    Key
    Florida
    They make other security products too.
  12. Sep 25, 2022 at 8:02 PM
    RIX TUX
    cool, tailpipe security
    Key-Rei[QUOTED] likes this.
  13. Sep 25, 2022 at 8:17 PM
    Kllrbee
    Tim
    Bloomfield, WI
    Makes sense. I think the electronic lock will also be on my short list. As I said, Ive been diligent with locking it manually multiple times daily. But thats going to get real old, real fast, pretty soon here.
  14. Sep 25, 2022 at 8:25 PM
    soundman98
    NW Indiana
    honestly, i really just don't want to run the wiring to the cab--i've got a lot of idea's for electronics in the bed and at the rear bumper, so trying to consolidate wiring runs instead of making 6 different pulls through the same routes is more of a priority.
    i'm also running a yotamd keyfob case, so my mechanical key is a lot harder to access and really just an emergency backup.
  15. Sep 26, 2022 at 3:44 AM
    #35
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    EXACTLY. My neighbor had her catalytic converter stolen and she had insurance. As you said, after deductible, etc, she STILL had to pay $1200 out of pocket! But the overall cost to replace her converter would have been $3000 if she had not had insurance.
  16. Sep 26, 2022 at 4:44 AM
    #36
    deadlifts and donuts
    deadlifts and donuts Well-Known Member
    '19 TRD OR DCSB MGM
    Has anyone done the remote locking tailgate install themselves? Been thinking about doing it but seems like a bit of work.
  17. Sep 26, 2022 at 4:51 AM
    #37
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    The OEM is easy to do. It's plug and play. Only hard part is lying under the truck for 15 minutes running a wire along the frame. I did it without jacking up the truck, just lying on a piece of carboard and I'm 73 years old.
    Note: It does not come with instructions. They can be downloaded though:
  18. Sep 26, 2022 at 5:00 AM
    #38
    oogielaflick
    Keith
    I have the original installations instructions from Toyota in a pdf file. I will attach them below. In my own case though, I did NOT install mine connected to the door unlock/lock system, but to a switch provided my PopNLock, that I could mount on my lower dash. I did not need to have my tailgate constantly locking and unlocking every time I got in and out of the truck! The switch totally works for me. But in any case, the installation instructions are below...
  19. Sep 26, 2022 at 5:05 AM
    #39
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    I got mine in red because I figure.....if they see it they'll walk away without trying to damage anything. I'm all for shooting thieves.
  20. Sep 26, 2022 at 5:11 AM
    #40
    '19 TRD OR DCSB MGM
    @grandpawmoses @oogielaflick thanks for the info! Did you order parts through Toyota? I asked our local dealer’s parts department and they gave me a funny look and said they had no idea what I was talking about.
