Take-off shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by obxfishn, Feb 9, 2008.
  1. Feb 9, 2008 at 5:03 PM
    obxfishn
    obxfishn [OP] Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    Is this the "shudder" that everyone is talking about, very noticeable when you first take off? Will the Tom Woods shaft take care of this?
  2. Feb 10, 2008 at 5:59 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I only get the "shudder" when I dog it, I don't think the drive shaft will fix that.
  3. Feb 10, 2008 at 8:22 AM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    Is it a shudder or more of a vibration. i get a metallic sounding vibration when I let the clutch out in first or second and when I start to backup. Sounds like the exhuast pipe vibrating against the frame. Its not that as the pipe is to far from the frame. Any ideas out there????
  4. Feb 10, 2008 at 8:57 AM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    Yeah thats the shudder I have, looking into possible solutions for it right now. Since Toyota seems to think there is nothing wrong.
  5. Feb 10, 2008 at 5:37 PM
    obxfishn
    Eastern Virginia
    There is a YouTube video out there somewhere that shows the Carrier Bearing shaking violently when you first take off and I was wondering if this is the same thing that is happening to my truck. I will try ti get it on vodeo some how some way this week. If this is the case then the Tom Woods shaft would definitely rid this problem huh!
  6. Feb 10, 2008 at 6:38 PM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    I would be very interested in seeing this video..
  7. Feb 10, 2008 at 7:20 PM
    Tug
    Tug Active Member
    4X4 Access Cab
    Stock
    I have the same problem, when I first take off in first gear the truck kind of jerks, same thing happens when I shift from first to second or when I back up.
    I originally thought it was my clutch, than earlier this evening I went for a ride and for the first time since I bought the truck I put it in 4 high and it ran perfect.
    Im not hearing any metal against the frame type sound though.
  8. Feb 11, 2008 at 8:21 AM
    obxfishn
    Eastern Virginia
  9. Feb 11, 2008 at 11:48 AM
    5862007 Active Member
    2007 Toyota Tacoma Regular Cab 4x2
    My 2007 Tacoma has a strange shudder/vibration effect that only lasts a half second when I put the truck in Drive and it first starts to move. It's difficult to put it in words exactly what happens, but it's almost as if the truck is parked with a small barely-noticeable speed bump just ahead of the front tires that the truck goes over just as it starts to move forward. Just a split-second shudder/grind/vibration effect that doesn't happen again for the rest fo the time that I'm driving the truck. I haven't really worried about it and just assumed the phenomenon as just being one of those unfamiliar vehicle idiosyncracies that doesn't damage anything.
  10. Feb 11, 2008 at 1:11 PM
    Mike_72
    Mike_72 Member
    Tacoma SR5
  11. Feb 11, 2008 at 1:17 PM
    obxfishn
    Eastern Virginia
    Thats what I am beginning to think!
  12. Feb 11, 2008 at 1:26 PM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    Hum, now how to get Toyota to foot the bill??
  13. Feb 11, 2008 at 1:28 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I thought Tom Woods was really only important when you get a lift.
  14. Feb 11, 2008 at 2:13 PM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    Under normal circumstances yes, however when there is something wrong with the 2 piece OEM unit that makes your truck shake itself apart it is also important.
  15. Feb 12, 2008 at 6:04 PM
    Tug
    Tug Active Member
    4X4 Access Cab
    Stock
  16. Oct 30, 2008 at 2:22 PM
    1bad03snake
    1bad03snake Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    How much does a 1 piece driveshaft cost?
  17. Oct 30, 2008 at 2:27 PM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    i dont think this is the same shudder people experience with a 6" lift
    SWS Inc. likes this.
  18. Oct 30, 2008 at 2:29 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    is it just me or does that driveshaft in the vid look like its been bent toward the axle side of the carrier(one to front 'left' in vid)?
  19. Oct 30, 2008 at 2:51 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i was just going to find that video and post it. my 4wd guy (ralph at meadowlands 4wd in rutherford nj) swears its the front diff not being dropped enough.i think its the combo of driveshaft,front diff/axles, and beating the snot out of your truck.
  20. Oct 30, 2008 at 2:55 PM
    Zach
    Zach Well-Known Member
    Phoenix, AZ
    08 DC Prerunner SR5
    Window tint...more to come
    5862007, i have the same as you, though, only when the truck has sat overnight, or during the day while i am at work. I thought it might be something with the brake line, or ABS, or perhaps a weird toyota gremlin....
