taking it off
Discussion in 'Detailing' started by rik121, Aug 24, 2008.
  1. Aug 24, 2008 at 12:57 AM
    rik121
    rik121 [OP] Active Member
    Oregon
    [url=http://www.tacomaworld.com/gall
    want to remove my badging off my doors and tallgate whats the best way to do so​
  2. Aug 24, 2008 at 1:01 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    What i did was spray googone on 40lbs fishing string put it behind the badge and went in up and down you could use a heat gun just be careful dont put directly on truck can bubble paint, hair dryer works also. take your time no need to rush it.
  3. Aug 24, 2008 at 6:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 on the fishing line and taking your time.
    I used a spray on carnuba cleaner/wax for motorcycle paint and plastics to soften and clean the remaining putty off. Heat guns make me nervous...
  4. Aug 24, 2008 at 7:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mine were really easy to take off after the truck sat in the sun for a few hours and heated up......and fishing line works great for pulling under the emblems. a little goo gone afterwards, followed by a little wax and you'll be set.
  5. Aug 24, 2008 at 7:59 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u can also go to the local advanced or auto zone and get a can of sticker adhiesive remover and u can just wipe away the residue from the trd stickers and the stuff behind the emblems isnt too hard to remove either
  6. Aug 24, 2008 at 8:26 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    after you take everything off and youre left with residue... you can go to NAPA and get a "Stripe Off Wheel".. be sure you get the kit, and not the refill. Its basically a big rubber eraser wheel that you attach to a drill... and it heats up the gunk and makes it very easily removed.
    ive used mine on several trucks rather then blistering up fingers... the wheel itself will break down rather then damage your paint.
    Runs about $40.
  7. Aug 24, 2008 at 9:14 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    The best way I have found to remove the letters is to use a blow dryer & heat them up a little. When you get them nice and hot, just peel em off, it's that simple. After you get them off, take some rubbing alcohol to get off any left over glue. All you need to do now is wax the area real nice & you should be good to go! Works better if you have an orbital buffer if you have swirl marks in the paint.
