Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Feb 25, 2014 at 7:43 AM
    #681
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    All yiu have to do is hit the spindle right near the ball joint and it will pop right out. Same with the tie rod. Just make sure not to hit the threads like i did on Greg's. That cost us an extra 30 minutes or so.
  2. Feb 25, 2014 at 7:45 AM
    #682
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    That's what I figured we would do. It worked on my daughter's boyfriends 94 integra & those were probably original by the looks of them.
  3. Feb 25, 2014 at 7:50 AM
    #683
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The one on the right (2 jaw) is like mine, although it's hard to tell from the pic, it looks a little larger than mine, but it'll probably do the job without too much banging on your UCA. :cool:
    Only difference is mine has a hex drive screw so you can put a regular socket on it.
  4. Feb 25, 2014 at 7:54 AM
    #684
    Taco No Baka
    Lee
    Tampa, FL
    If you go that route, leave the nut threaded on the end of the ball joint. That way if you do miss and hit the threads it won't screw them up. :cool:
  5. Feb 25, 2014 at 7:56 AM
    #685
    Toyota Tech31
    Debary, Florida
    I meant to add this to my post.
  6. Feb 25, 2014 at 8:01 AM
    #686
    Taco No Baka
    Lee
    Tampa, FL
    :thumbsup:
  7. Feb 25, 2014 at 8:06 AM
    #687
    sdoheny
    sdoheny Well-Known Member
    Seth
    Tampa, FL
    Sport
    N-Fab Text black 3 main tube, led interior lighting, sylvania ultra head lamps, led map/dome/license plate, rail mounted bed lights, trd skid plate, Aero Turbin muffler swap, MRBP Black Exhaust Tip, weather tech, fuel trophy, duratrac 265 70 17, plasti dip badges, Icon stage 4 suspension, TRD shift knob, AFE CAI, Raptor Light MOD.
  8. Feb 25, 2014 at 8:09 AM
    #688
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Loosen the nut then spin it on by finger flush with the bottom of the threads. Hit it with a hammer.
  9. Feb 25, 2014 at 8:24 AM
    #689
    Taco No Baka
    Lee
    Tampa, FL
    If you're willing to loan your torque wrench out, where abouts are you? I'll even let you hold on to my big'un, a MAC tools 30-250ft/lb 1/2 inch drive flex head while I've got yours. :cool:
  10. Feb 25, 2014 at 8:37 AM
    #690
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hell yea it counts, cept u have ur own CL so i'm not sure it does :notsure: but for the purposes of meets, hell yea it counts ;)
  11. Feb 25, 2014 at 8:46 AM
    #691
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Where are y'all meeting?
  12. Feb 25, 2014 at 8:48 AM
    #692
    nammer
    Nam
    Bradenton, Florida
    sprucetaco's over in clearwater
  13. Feb 25, 2014 at 8:55 AM
    #693
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Saturday?
  14. Feb 25, 2014 at 8:56 AM
    #694
    nammer
    Nam
    Bradenton, Florida
    sat march 8
  15. Feb 25, 2014 at 9:17 AM
    #695
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    What are we installing?
  16. Feb 25, 2014 at 9:18 AM
    #696
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    So far Nam's lift unless others have stuff to do.
  17. Feb 25, 2014 at 2:06 PM
    #697
    Taco No Baka
    Lee
    Tampa, FL
    March 8? Oh, okay, I was thinking it was this weekend for some reason. :rolleyes:
  18. Feb 25, 2014 at 2:56 PM
    #698
    nammer
    Nam
    Bradenton, Florida
  19. Feb 26, 2014 at 5:00 AM
    #699
    mr mike
    mr mike Member
    mike
    clearwater area
    07 trd sport 4x4 sr5 6 speed manual
    magnaflow exhaust
    when is yalls next meet? offroad!
  20. Feb 26, 2014 at 5:05 AM
    #700
    nammer
    Nam
    Bradenton, Florida
    hey there, we're getting together at sprucetaco's house in clearwater on march 8 at 10 am
