Tapered 0.5" or 1" rear block
Discussion in '3rd Gen. Tacomas (2016-2023)' started by valdomero, Mar 10, 2019.
  1. Mar 10, 2019 at 11:53 AM
    valdomero
    valdomero [OP] Well-Known Member
    Valdo
    2017 Tacoma TRD 4x4 Offroad
    Plasti Dip Grille and Emblems Removed V6 badge
    I installed progressive add a leaf icon on my truck that gave 1.5" rear lift. I feel like I am a nose high even though I truck is just leveled.
    I like the little rake on my truck before thinking to add 0.5" or 1" tapered rear block.
    Anybody knows where can I buy it?
  2. Mar 10, 2019 at 11:55 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    What's in the front?
    You're rapidly running out of travel in the rear shock and could do damage
    valdomero[OP], tcjacado and mgmdclb like this.
  3. Mar 10, 2019 at 11:56 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not really. Unless he drops a tire or stuffs one, his shocks will be ok.
    valdomero[OP] likes this.
  4. Mar 10, 2019 at 12:00 PM
    tcjacado
    tcjacado Well-Known Member
  5. Mar 10, 2019 at 12:27 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    With the overload in, it will give you 2" of lift. Guessing you pulled overload? No tapered blocks under 1-1/2" that I know of.
  6. Mar 10, 2019 at 8:11 PM
    valdomero
    Valdo
    I took the overload.
    The instructions recommended to remove the overload.
    On the other hand, the clamps on both end of the overload leaf needs to be removed for it to be installed back because the progressive icon aal has it on both ends.
  7. Mar 10, 2019 at 8:13 PM
    T4RFTMFW
    Overload will add the half inch you’re desiring.
    Also, if you haul of tow it’s a benefit to reinstalling. 10% loss of payload without the overload installed.
  8. Mar 10, 2019 at 8:15 PM
    valdomero
    Valdo
    This looks great but I like it tapered.
    I had a non-tapered 1.5" block and I had a minimal vibrations at 15-20mph.
    I placed 1" spacer on my 6112 front shocks to give 3" lift.
  9. Mar 10, 2019 at 8:16 PM
    valdomero
    Valdo
    I have 3" lift after adding 1" spacer to bilstein 6112. I have 5160 rear shocks
    m603holden[QUOTED] likes this.
  10. Mar 10, 2019 at 8:19 PM
    valdomero
    Valdo
    I might just do that since I can't find any tapered block.
    Thank you
  11. Mar 23, 2019 at 6:23 AM
    BadCow
    BadCow Well-Known Member
    David
    2019 Tundra TRD PRO Super White
  12. Mar 23, 2019 at 9:53 PM
    Roddy13
    Roddy13 Well-Known Member
    Toytec has a 1/2” block that they call a “shim”... it will give you 1/2” lift out back
