Tapping Noise at Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by pokerb, Aug 25, 2007.
  1. Aug 25, 2007 at 3:06 PM
    pokerb
    pokerb [OP] Member
    Tacoma 4x4 TRD Extended Cab
    Camping cap
    Hi,
    Maybe it's been covered before but I searched and couldn't fina a thread.
    My 2000 TRD 4x4 3.4L has 98k and 5k ago I had the timing belt, water pump, and the other belts changed. Basically the 90k servicing.
    Now, 5k miles later I have developed a tapping that occurs only when I idle after driving 5+ miles. But the engine has no change in performance whatsoever and if I increase the tach on the engine (slowly) the tapping quickens then goes away.
    New garage I went to for oil change says it may be the timing belt tensioner. Is there any other characteristics that would point in that direction? I hate to have to get the engine ripped apart again. And I don't think the timing belt work is still under a warranty.
    Any advice...?? Hopefully it's some simple mechanical interference that won't affect anything..?? I'm sure it could be anything and I probably haven't described it well enough for a quick answer but what may be good is that there is no other performance issue with the engine at any speed.
    Thanks in advance for any help,
    --Bill
  2. Aug 27, 2007 at 11:49 AM
    FU_FJ
    FU_FJ Well-Known Member
    Toyota Whore!!!
    07 FJ Cruiser TRD SE 4x4, 01 Taco Dbl Cab SR5 TRD 4x4, 04 Celica w/Action Pkg, 97 4Runner LTD 4x4
    its the infamous 6 cylinder 'Toyota Tick'... nothing to worry about.
  3. Aug 27, 2007 at 2:18 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Have you had a valve adjustment?
  4. Aug 27, 2007 at 4:14 PM
    pokerb
    pokerb [OP] Member
    Camping cap
    Thanks for the replies guys...
    @FU_FJ....Can you give me some more info about this Toyota Tick thing?? Others have had it without problems? How common is it?
    @jrallan26..
    No I never did have valves adjusted...never came up before as routine maintenance. I guess now may be the time then???
  5. Aug 28, 2007 at 6:03 AM
    FU_FJ
    Toyota Whore!!!
    it seems to be a fairly common thing... some say its not the engine/valves that are ticking but something to do with the emmission controls... others say its the lifters... i donno, but a ticking Toy V6 isn't something to get all excited about. My 230k mile V6 4Runner had the tick from day one.\
    **Edit***
    You can always take it into a Toyota service center and have them check it out... which may not be a bad idea since you recenly did work on it.
  6. Aug 28, 2007 at 8:00 AM
    jrallan26
    Iowa
  7. Aug 28, 2007 at 5:45 PM
    pokerb
    pokerb [OP] Member
    Camping cap
    Thanks guys...
    I bought some Marvel Mystery Oil to try once I burn off a quart. The tapping is very very unpredictable and doesn't occur often. So I like the idea of leaving it alone and I also like the idea of taking it into Toyota for a look...hopefully it'll repeat when I get it there! Let them check the valve noises for me then.
    Thanks again,
    --Bill
  8. Aug 28, 2007 at 6:01 PM
    jrallan26
    Iowa
    How many miles?
    What year?
    motor?
  9. Aug 29, 2007 at 4:21 PM
    pokerb
    pokerb [OP] Member
    Camping cap
  10. Aug 29, 2007 at 8:28 PM
    jrallan26
    Iowa
    I would have a tech. have a look at it. It may be in need of a valve adjustment.
    Has the timing belt been replaced? Water pump?
  11. Sep 1, 2007 at 5:57 AM
    pokerb
    pokerb [OP] Member
    Camping cap
    Yep..has that done about 5k miles ago...new water pump and all of the belts incl. timing. I think next is the valve adjustment. What's that usually run??? I est. about $200?
  12. Jul 25, 2008 at 6:04 AM
    DANBROWN
    DANBROWN Member
    99 TACOMA EX-CAB 4X4 V6
    K&N FIPK KIT, WHEELS TIRES, HELIX POWER TOWER
    My 99 v6 has ticked since day one, tech says they all do it and he thinks its fuel injectors
  13. Jul 25, 2008 at 6:11 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i actualy saw a thread on this yesterday, i think it was on toyotanation. I will try and find it later and put on here for yall, its nothing to worry about though. under your engine cover, its hard to explain withou8t the pics, but there is a small valve/bolt you can take out and put a couple O rings on it and it is suppose to quite it way down.
  14. Jul 25, 2008 at 6:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
