Tapping the Dash Lights Circuit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jadoiron, Feb 2, 2016.
  1. Mar 17, 2019 at 11:45 AM
    #61
    Donkeythekidd
    Donkeythekidd Well-Known Member
    Beaumont, CA
    2017 MGM Tacoma TRD Off Road Double Cab
    So I'm finally getting around to hooking up the illumination right now. I'm using posi-taps to splice into the rear diff switch. I tapped into the black for illumination ground and the black/white for illumination power. When I turn on my lights to illumate all my switches my garage door switch lights for a split second then goes out? Any ideas?
  2. Mar 17, 2019 at 2:06 PM
    #62
    Donkeythekidd
    Beaumont, CA
    So it seems like the red/white wire is illumination. I hooked it up to that wire and it works, now I just need to figure out which one is illumination ground, it's not the black one.
  3. Mar 17, 2019 at 3:21 PM
    #63
    Donkeythekidd
    Beaumont, CA
    Got it working right. Red/white was illumination power and the Black/white was illumination ground.
    bagleboy likes this.
  4. Mar 17, 2019 at 5:27 PM
    #64
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Congrats, so you've got dimming and switch function now? All switch leds have an associated resistor that prevents over current and being diodes aren't harmed by reverse polarity so it's sometimes just a matter of seeing what works. Toyota doesn't seem to follow any standard color scheme and changes colors on a whim. On mine green is illumination power and green/white illumination ground. Even your aftermarket garage switch doesn't use the same colors as ch4x4 save for black being illumination ground.
  5. Mar 17, 2019 at 5:41 PM
    #65
    Donkeythekidd
    Beaumont, CA
    Yup dimming works. :bananadance: The harness coming off the garage switch isn't from CH4x4. I bought a garage switch off ebay for $6 that came from China that stopped working correctly right after I hooked it up, I would have to push it 3-4 times for it to work. So I didn't bother hooking up the illumination. I finally got a new garage switch from CH4x4 that matches the light blue factory leds but kept the old harness since it was already soldered to my garage opener.
    #65
  6. Mar 17, 2019 at 6:06 PM
    #66
    bagleboy
    Scott
    Norcal, Santa Rosa
    The ebay and Amazon switches still have the same internal layout as ch4x4 and use the same connector plug, they just don't color code the wires the same as ch4x4 but should still be a simple swap. They're 5-pin connectors that don't use the center pin. I crunched one of mine by accident and opened it up to see how to change led color and intensity. Pretty simple stuff.
    #66
  7. Mar 17, 2019 at 6:28 PM
    #67
    banzaikid1
    banzaikid1 Well-Known Member
    A43B80EC-D2AA-42BA-8439-B5360A393CED.jpg I used an add a fuse on the TAIL FUSE and the lights on my switches come on when I turn the lights on
  8. Mar 17, 2019 at 8:19 PM
    #68
    bagleboy
    Scott
    Norcal, Santa Rosa
    Lots of ways to illuminate switches but this thread is specifically about tapping the dash circuit to keep Oem dimming on all switches. If you want yours to dim as well connect the switch ground to illumination ground, not the same as chassis ground as our trucks use a variable relative ground to achieve dimming. Every switch and panel that dims will have a dimmer ground wire. I accessed the circuit at the ac controls plug using the nite-eyze instructions since my two switch panels are below it.
  9. Jun 10, 2019 at 8:03 PM
    #69
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Thank you for this info. It helped me wire the way I really wanted to. FYI on the 2018 Tacoma, the pins you reference above are correct, but the negative wire is tan in color.
    I used a T tap with two wire slots, and a inexpensive blue backlight LED push switch that has two bulbs: one for the writing wired to dash lights, and the other bulb lights up when the LED bar is turned on.
    TacoSportTRD and dilbert[QUOTED] like this.
  10. Aug 1, 2020 at 8:37 AM
    #70
    kperatt09
    kperatt09 Well-Known Member
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    34's with all the fun attached
    Which switch panel did you use to get the 4 switches in?
  11. Aug 1, 2020 at 9:11 AM
    #71
    Donkeythekidd
    Beaumont, CA
    #71
    kperatt09[QUOTED] likes this.
  12. Aug 1, 2020 at 9:27 AM
    #72
    fishing4boulders
    fishing4boulders Well-Known Member
    AL
    2020 OR Tacoma 4x4
    So reading thru this, for the CH4x4 4-wire switches.....if I wanted to be able to dim the switch lights I tap red 2 to the green wire illumination (+) and the ground to the green w/ white wire as an illumination (-). If I didn’t care about the dimming capability I could run the illumination (+) to a add-a-fuse plugged into something like the taillight fuse to power the lights (so I could more easily reverse the switches if I wanted).
  13. Dec 14, 2020 at 5:17 PM
    #73
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    I know this is an old thread but Hoping you could help me out. I am trying to wire a illuminated switch for some heated seats. The heated seats came with a wiring harness that only has a positive for the switch illumination. The harness has a combined ground for the switch and the heating units. Based in your post here I’m assuming there is no way to wire the switch illumination to dim since the switch grounds are combined. Is this correct?
  14. Dec 14, 2020 at 5:25 PM
    #74
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Let’s see the back of the switch you have. Perhaps you can splice the ground wire (attached to the switch) out and run it to a variable ground that allows you to dim. You’d just put a cap on your bare end.
  15. Dec 14, 2020 at 5:33 PM
    #75
    TheTacomaInn
    Rob
    Littleton, CO
    here it is. There are 6 wires coming out of the switch. I’m not 100% sure what each one is. This harness is for a hi/low seat heater switch and it has 2 relays per seat which I thought was kinda strange.
  16. Dec 14, 2020 at 5:43 PM
    #76
    kmorgan3
    Kyle
    PNW
    Unless you have the pin map you’ll need to see where those two black wires run.
  17. Dec 14, 2020 at 6:02 PM
    #77
    TheTacomaInn
    Rob
    Littleton, CO
    Yeah that's what I figured. I don't have a pin map (the kit doesn't really even have instructions).
    I hooked up the switch to the panel circuit to test the brightness of the illumination and its noticeably brighter. Do you know of any way to make it dimmer possibly by adding a resistor inline?
  18. Dec 14, 2020 at 6:22 PM
    #78
    kmorgan3
    Kyle
    PNW
    Good ol solder and some very small resistors. You can try some of those load resistors but again you’d need something super small.
    If you’ve got the time you can cut the wire harness up and see where those black wires out of the connector run. One will probably be going directly to a ground and I’d guess that’s for the illumination. Hard to tell.
  19. Dec 14, 2020 at 8:00 PM
    #79
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’ve opened up every switch I’ve purchased plus a few of the oem switches and from what I’ve seen “impossible” is a relative term and depends on how much you want it. I installed the Besond seat heaters and swapped both color and resistance values as well as scraping the inside of the wheel so the white “level bar” gets illuminated. If you were willing to pull the white connector and open up the switch housing(every one I’ve seen so far just snaps together) and post a pick of the circuit board that has he switch and leds we can show you where to cut a trace and solder in an additional ground wire to connect to the variable ground that provides dimming. Usually there’s a resistor for each led that controls maximum brightness and even if you don’t add the wire you can change resistors to more closely match your oem switches.
  20. Dec 15, 2020 at 10:51 AM
    #80
    TheTacomaInn
    Rob
    Littleton, CO
    I will see if I can get it apart and shoot you a picture. Thanks in advanced for your help!
