Tapping wires instead of soldering for alarm install
Discussion in 'Technical Chat' started by NorCalTRD, Mar 31, 2013.
  1. Mar 31, 2013 at 11:23 PM
    NorCalTRD
    NorCalTRD [OP] Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    I was at walmart and saw a pack of plastic tappers that let you tap into one wire and run another wire off of it very simply. Would it be recommended to avoid these for an alarm install?
    I was just thinking DAMN that would really simplify the install. Instead of stripping, soldering, and wrapping/heat shrinking.
  2. Apr 1, 2013 at 9:05 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    They would work but I'd recommend soldering and heat shrinking so no problems occur later on down the road
  3. Apr 1, 2013 at 9:31 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Simplify the install, yes. Simplify things for the long haul, nope.
    Think in particular that you aren't just wiring up a set of fog lights that you can live without short term. If the alarm malfunctions you won't be able to start your truck.
    Even if it was all inside the truck I wouldn't use those vampire clips anyways, add to it that you're under the hood and will have some exposure to water..you'd be silly not to just solder and shrink it.
    The cheap usually comes out expensive.
  4. Apr 1, 2013 at 11:02 AM
    NorCalTRD
    Northern California
    Cool, thats what I was thinking.
    Thanks
  5. May 1, 2013 at 10:53 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Use shotchlok t taps, not the big blue ones that you find at walmart.
  6. May 1, 2013 at 10:59 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    solder solder solder
