tbs and current ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by in2wks, Jun 9, 2008.
  1. Jun 9, 2008 at 12:45 AM
    in2wks
    in2wks [OP] Member
    forty fort pa
    o7 trd sport
    yakima rack with basket.....surf rod holder attached to basket....k&n filter......bed cover...cb radio.....
    I like my ride now on my 07 trd sport........will the tbs make it a lot different.?..I do get a bottoming out with light loads.....and if I get the tbs and my rear end is higher will it affect bushings and such?..........thanks jim:eek:...this is my first post for I am new here
  2. Jun 9, 2008 at 4:08 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Next time search, this has been covered thousands of times.
    The ride will be firmer. You will be able to carry loads like your supposed to. Most people only get .5" of lift out of the TSB springs after they settle.
  3. Jun 9, 2008 at 4:41 AM
    missileman125fw
    missileman125fw Well-Known Member
    Hey dude, my Tacoma sits 3/4 inch higher in the back. I love the new ride. It handles much better. I would think Toyota wouldn't do the TSB if it affected the bushings. Get it done, you won't be disappointed.
  4. Jun 9, 2008 at 4:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    Mine gained quite a bit of lift at first something like 3/4" but settled out to under 1/2. I would definately get it done. If you look it up on here make sure to look up TSB, as opposed to TBS.
  5. Jun 9, 2008 at 9:57 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Welcome Jim, and maybe it should be under TBS (Toyota BS) as they've known about this problem for awhile. Anyway you will like the end result as far as ride and not bottoming out.
