TC Rear long travel hybrid. Possible?
Discussion in 'Long Travel Suspension' started by THExBUSxDRIVER, Apr 12, 2010.
So, what do you think about this idea?
Poll closed Jul 11, 2010.
  1. Yes, it is possible.
    6 vote(s)
    60.0%
  2. Don't try. Just wiat for something to be produced.
    1 vote(s)
    10.0%
  3. ....crazy
    3 vote(s)
    30.0%
  1. Apr 12, 2010 at 5:38 PM
    THExBUSxDRIVER
    THExBUSxDRIVER [OP] Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Well I've been lookin at LT kits and found some I like, but none offer much for the rear. except for leaf packs.
    I found a rear kit that TC produces with a shock hoop but it is only made for the 5 lug. I didnt think it would matter much but after asking around I found that the shackles and other parts differ between the 5-lug and 6-lug.
    Leaving the hoop from the TC kit the only part that I would be able to use(Thankfully they sell them separately)
    So I looked around for other companies that possibly made rear kits with hoops but found none, but came across a deaver leaf pack from Wheeler's Off-Road and started to wonder if I would be able to merge the 2 kits together.
    Here are the two kits. Granted the 5-lug's leafs are below the axle and the 6-lug leafs are mounted above the axle.
    I want to know what you guys think about the possibility of merging the two and what parts from both kits I would need.
    If you think I'm just plain crazy for thinking about it then thanks:)
    And if you guys have anything else to contribute please do:D
  2. Apr 12, 2010 at 6:29 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    dmz has a spring under kit that uses deaver, the deavers made for a tacoma don't fit if you want' lt. engage also has kits but you would have to pm them for price. making a shock hoop is not that big of a deal, getting the correct angles for the shocks is where you need to pay attention.
    I say you are crazy. total chaos ppppfffftttt;)
  3. Apr 12, 2010 at 6:31 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    ^^I dont wanna go with TC either
  4. Apr 13, 2010 at 12:07 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Hmm DMZ's work looks pricey
  5. Apr 13, 2010 at 12:21 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    its very pricey nice work though
  6. Apr 13, 2010 at 12:43 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Yea I like the rear spring under kit that moon mentioned but I'm iffy if I have to cut into my bed
  7. Apr 13, 2010 at 12:54 AM
    Dellosa89
    Brian
    Murrieta CA
    The problem is you will half to cut into your bed if you want to make it strong enough to hold up to long travel, i know a guy that bent his frame pretty badly from not doing a cross bar.
  8. Apr 13, 2010 at 3:27 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    As long as it doesnt take up too much room back there, I still wanna be able to haul from time to time
  9. Apr 13, 2010 at 6:22 AM
    bajamoon
    STEVE
    Whittier
    you will have to cut in the bed just to get the shock hoops in and the shocks, you would run a 16" shock that will reach you bed rail.
    look at this from engage, this truck is the same as mine just has the bed.
  10. Apr 13, 2010 at 6:58 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    ^^^ so sick!!!
  11. Apr 13, 2010 at 7:09 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Giant Motorsports makes a bolt-on spring-under long travel kit and bed cage for the late model Tacoma.
    http://giantmotorsports.com/content/view/84/104/
    Don't expect the installation to be easy with any of these kits (Giant, DMZ, Engage, etc.), but they work great when set up properly!
  12. Apr 13, 2010 at 8:09 AM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    TC FTMFW lol
    DMZ-way overpriced IMO ..great work though
    Engage-pretty cheap for the travel u get
    You CAN put he kit onto ur truck.... as proven in my Thread about this for the minis. i dont think it will be bolt on ...and u might have to drill holes in the fame.
    I WOULDNT recommend this because i know the minis have very diffrent things...such as drive shaft. i didnt have to have my driveshaft messed with. the 6 lug guys ahve to have the drive shaft extended i think or something like that.
    Just take it to a shop...it will be less headaches....i can already tell u u will run into problems trying to put this kit on a 6lug ...
    Try richer racing...they have a bolt in bed hoops! but pretty any shop can make ur shock hoops bolt in
  13. Apr 13, 2010 at 8:17 AM
    NakedTacoma
    West Covina
    why? lol
    ALSO!!!! no one has pointed out that u r 4x4....im guessing u dont have LT in the front? i know 4x4 lt has its limitaions in the front so i would make sure ur rear doesnt sit to high in the back ! ...kinda like mine :D
  14. Apr 13, 2010 at 8:24 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Love that pic! (Professional Driver on a Closed Course: Do Not Attempt - No children present)
  15. Apr 13, 2010 at 8:37 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    That pic of the truck is sick as hell
  16. Apr 13, 2010 at 8:40 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Urban Off roading!
  17. Apr 13, 2010 at 9:28 AM
    NakedTacoma
    West Covina
    the owner of that truck is a super cool guy ..... Helps out alot if u have problems in the dezert...and has every tool lol
  18. Apr 13, 2010 at 12:05 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    Dam right wish there were more people like him
  19. Apr 13, 2010 at 1:24 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    See I like that, the bed aint too hacked up.
    And yes I am a 4x4 so the front is limited...(I'd love me some lift spindles :frusty:)
    So I wont need much lift in the rear
  20. Apr 13, 2010 at 1:33 PM
    NakedTacoma
    West Covina
    any leafunder pack will sit high compared to ur front....i would get the LT in the front and go from there
