TC UCA hits icon coilover
Discussion in 'Suspension' started by surfrat, Mar 13, 2012.
  1. Mar 13, 2012 at 6:21 PM
    surfrat
    surfrat [OP] Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    Just noticed this today while looking over the truck. Theres a mark on both coil and UCA from contact do to down travel. Is there a way to stop this? The rust spot on the coil is where the contact is being made. I dont know what that grey scratch on the coil is. didn't even notice it until i looked at this picture.
  2. Mar 13, 2012 at 6:33 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I had to rotate the coils untill the UCA would come down and not hit the coils. theres a sweet spot when you rotate the coils where they wont hit...
  3. Mar 13, 2012 at 6:37 PM
    surfrat
    LI, NY
    thats what i was figuring. ill try 1 turn down. thanks man
  4. Mar 13, 2012 at 6:38 PM
    ETaco23
    Evan
    PNW
    No Problem..
  5. Mar 13, 2012 at 6:39 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I've noticed a slight scratch on mine, even a small springy thump.
    good to know aboot rotating them.
  6. Mar 13, 2012 at 6:41 PM
    ETaco23
    Evan
    PNW
    Yeah, I noticed it when I did the Install and kept rotating it untill it wouldnt touch the coils..
  7. Mar 13, 2012 at 8:44 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Are you meaning cranking them up, as in adding lift or are you rotating the whole spring unit itself? What's the easiest way to do that? I posted a few days back inquiring about the camburgs hitting and also discovered the TC's do too! Adding limit straps is an option but rotating them for clearance makes sense if they're not built as one piece?
  8. Mar 13, 2012 at 9:04 PM
    ETaco23
    Evan
    PNW
    Well its easier to just jack the truck up and spin the top collar as if you were going to add lift. this should also spin the coil. But your not spinning it alot, so you wont add or lose lift. Just enough to were the UCA's dont hit the coils.
    Hope that makes sense...
    (Also it doesnt really matter which way you spin it) I just prefered turning them up.. :D
  9. Mar 14, 2012 at 9:05 AM
    Dr. Sleep
    Dr. Sleep Well-Known Member
    Shane
    Colorado
    07 DoubleCab SR5 4X4
    Camburg UCAs and Icon coilovers do the same thing. Rotating won't always find a sweet spot. One option is just to occasionally put some rust stopping paint over the coil steel. Limiting straps seems overkill, but would definitively stop the problem if you get airborn enough to achieve complete droop often enough.
