Tear drop camper
Discussion in 'Sports, Hobbies & Interests' started by pipelayer_99, Jul 21, 2015.
  1. Aug 17, 2015 at 7:09 AM
    pipelayer_99
    pipelayer_99 [OP] Well-Known Member
    Aluminum roof is on. It was really tough to keep it from getting wavy but it came out good enough for me. The trim bent perfectly and I didn't have to cut any of it for the bends. I liquid nailed the center of the sheets and plenty of caulking on the seam and edge molding. The aluminum is dirty and I didn't want to clean it until the caulking dried to I can scrape excess off.
  2. Aug 19, 2015 at 7:37 AM
    pipelayer_99
    Got the back hatch aluminum skin on. I need to figure out props to hold it up but that will be easy. I also installed window screen and seals but didn't get a photo of those and its hard to see anyways. Next is finish up lower side trim, install fenders and lights.
  3. Aug 24, 2015 at 7:42 AM
    pipelayer_99
    Didn't get a whole lot done this weekend but I did get lights on and we took it for a test drive. We drove it around the neighborhood and got a lot of looks and compliments. It pulls good(a little bouncy) but should be Ok when loaded and nothing fell off, which is the best part. We need to finish the interior and seal it up a little better.
  4. Sep 2, 2015 at 7:02 AM
    pipelayer_99
    Started polishing the aluminum last night, installed trailer jack and put foam pads on the floor. Still working on it but not as much lately. Today is the safety inspection so I can get it registered. Hopefully lights don't quit on the way there and everything is tight.
  5. Sep 2, 2015 at 7:13 AM
    medic2230
    Murph
    Bama! Roll Tide
    Don't forget to put in some type of fan (Fantastic fan) to ventilate the trailer. Carbon dioxide buildup is nothing to play with and the tighter the trailer is sealed to more important it is, especially with 4 people in it at once.
    Trailer is looking good!
    Bennett707 likes this.
  6. Sep 2, 2015 at 8:29 AM
    pipelayer_99
    We will likely leave the door open and put screen over it. My wife isn't thrilled I tell everyone we need plenty of fart vents on the camper.
    Biscuits and medic2230 like this.
  7. Sep 8, 2015 at 7:29 AM
    pipelayer_99
    Put a piece of plywood and D-rings on the front to hold our cooler. I'm going to put a 1/2 inch carriage bolt through the plywood and metal cross beam so I can have the spare tire under the tongue.
  8. Sep 9, 2015 at 7:29 AM
    pipelayer_99
    Got the spare tire installed under the front storage area. I put the bolt through the plywood and metal cross beam. I used a wing nut to hold it and will put a pin in the bolt to keep the nut tight.
  9. Sep 9, 2015 at 9:56 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Great stuff!
  10. Sep 9, 2015 at 10:05 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Looks Good
  11. Sep 9, 2015 at 10:13 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Looks great. Nice job! :thumbsup:
  12. Sep 14, 2015 at 8:28 AM
    pipelayer_99
    Got in our first weekend and it worked out well. We went on a couple bad washboard roads and only lost a zerk fitting on the hub so I lost a little grease. Easy fix and I have extra bearing and seals on the way for emergency. The photo of the ruts is the road we had to take to our site and the trailer was fine on it. The photo of interior shows how its setup with 4 people and our sleeping bags.
    It wasn't really cold at night and we all slept in our bags unzipped so the camper didn't get too hot. Left the two windows open and there was a good breeze going through it. Drove on interstate around 65 to break it in and put about 150 miles on it with no issues. Its really nice having camp setup so quickly and being able to get into isolated primitive camp sites.
    trailbound likes this.
  13. Sep 14, 2015 at 10:07 AM
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    That came out great congrats and those are some great pics too!
  14. Sep 14, 2015 at 10:20 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    Really cool! Might have to make one this winter.
  15. Sep 14, 2015 at 10:27 AM
    #35
    T4RFTMFW
    I'm floored. Glad it has worked out so well. Didn't realize it slept 4!
  16. Sep 14, 2015 at 10:27 AM
    #36
    pipelayer_99
    If you do look for a used trailer on craiglist for cheap and you can stiffen it up and use a better axle. If I did it again I would go that route but I also had to wait a month to get it registered/licensed since it was a kit I had to assemble. I may go with a bigger axle down the road but it did Ok on this trip so we'll see.
  17. Sep 14, 2015 at 10:28 AM
    #37
    pipelayer_99
    My 3 and 5 year old daughter sleep up top. The loft is 5 feet long and my oldest is 4 feet tall so she has room to grow into it.
    T4RFTMFW[QUOTED] likes this.
  18. Sep 14, 2015 at 10:40 AM
    #38
    TexasIslandBoy
    Andrew
    South Texas. SPI
    Cool Did you feel it was a little heavy for the trailer?
  19. Sep 14, 2015 at 11:32 AM
    #39
    pipelayer_99
    I want a 5 lug rim that will fit a Jeep or Ford rim and 15 inch tire. The axle on this trailer is OK but bearings are metric so hard to replace if you break down as most places don't have that size bearing. I ordered a set of bearings and extra seals so I can have them greased and in the trailer if needed. $25 spent for those is well worth it if we break down in the boondocks.
  20. Mar 28, 2016 at 3:37 PM
    #40
    DukesTRD
    DukesTRD Member
    09 Tacoma off-road
    We are almost done with our teardrop and running into a sleeping pad problem. What are you sleeping on? Tough size to find one solid piece. Sweet build!!!
