Technical Difficulties on 4runner. VERY confused...
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomarotto, Mar 11, 2011.
  1. Mar 11, 2011 at 3:49 PM
    tacomarotto
    tacomarotto [OP] "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    my buddy and i have been working on his 4runner for a good bit now and cant fix this clunking/ticking sound coming from his rear drive shaft.
    he just installed front/rear auto lockers and now his rear driveshaft is ticking/clunking we think is is unbalanced but we've tried several bolt up variations. at higher speeds ranging from 60-80 he has a low humming. its not LOUD but its easily noticeable and most likely is coming from the drive shaft.
    some other things you should know is that it only ticks/clunks when it is in drive or reverse and will IMMEDIATELY stop... weird huh??
    im stumped...
  2. Mar 11, 2011 at 4:06 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Bump for being lost myself :S
    I'm sure an off Road guy will chime in here shortly
  3. Mar 11, 2011 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    many auto lockers make ticking/clunking sounds when turning. As for the humming sound, it could be the gears making noise.
  4. Mar 11, 2011 at 4:13 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Damn.. my vote was on midgets with hammers..
  5. Mar 11, 2011 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That could be true as well.....hammer wielding midgets are notorious for that..
  6. Mar 11, 2011 at 4:14 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    That only explains the clinking, the humming is their mating call
  7. Mar 11, 2011 at 4:15 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    we just flushed his rear diff.
    still humming...
    the clunk is coming from the transmission output to the driveshaft yoke.
  8. Mar 11, 2011 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    U joint?
  9. Mar 11, 2011 at 4:16 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I had that clunk on my Old S-10 once, check for loose U-Joint
  10. Mar 11, 2011 at 4:16 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    yea... i thought they were the same thing...
  11. Mar 11, 2011 at 4:16 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    When you swap gears do you have to adjust any backlash between ring and pinion or do they usually come ready to go? If there is too much backlash there could be humming. But I've never swapped one out on a toyota.
  12. Mar 11, 2011 at 4:17 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    grrrrr......
    How on earth did you beat me to that... I bet you posted a few seconds later and just mod powered your way first....
  13. Mar 11, 2011 at 4:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Please...You dont get a stupid high post count like mine without having Super Fingers! :cool:
  14. Mar 11, 2011 at 4:20 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Thats true, this cold winters starting to slow these fingers
  15. Mar 11, 2011 at 4:45 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    so... we have figured out that the sound is coming from the u-joint and the output shaft.... i dont get what else we can do to fix it
  16. Mar 11, 2011 at 4:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Replace the U joint.
  17. Mar 11, 2011 at 4:54 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    hm...
    i wonder why the lockers would cause a replacement of the u-joint.
    i just put em on and he hasent even wheeled with them on yet
