Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Mar 10, 2019 at 3:00 AM
    Totall4285
    Totall4285 [OP] Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Wanted to see what other folks are doing with Techstream. I did the customary seat belt alarm turn off, TSB update, and have cleared ECU/TCU memory (vehicle will need to learn trims/transmission learning again, takes some driving). I know there's logging capabilities, DTC reading and clearing, PIDS to monitor. Anybody else do anything different with techstream? Below is the version I'm running with instructions. I'm no expert, so can't help much with troubleshooting. I'm using the openport 2.0 tactrix cable that I use for ovtune software.
    http://blog.obdii365.com/2017/12/03/toyota-techstream-12-30-017-download-and-install/
    This is exactly what I did. Scroll to techstream 12-20-024 cracked. Download that version and follow the install instructions (exactly as written) a little lower under TS install windows 7, works for other windows versions. Make sure after installed you click setup>select vim>select obd cord you're using. Get that far and should be good.
    Spike Strip likes this.
  2. Mar 10, 2019 at 3:14 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Nothing really much you can do with a techstream. Now if you have a Mercedes and a multiplexer then you have unlimited modifications at your disposal.
  3. Mar 10, 2019 at 3:15 AM
    Totall4285
    Palm Harbor, Fl.
    Kind of the vibe I got when clicking around as well. Was hoping for something I missed.
  4. Mar 10, 2019 at 8:02 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    You can program your TPMS sensors if needed. You need the codes, of course.
    G.
    sgirt likes this.
  5. Mar 10, 2019 at 8:06 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I had fun doing the compression test. Kind if gimmicky, but it was interesting.
    Starting the truck with the TS was neat.
    Other than that. The above reasons where why I got it.
  6. Mar 10, 2019 at 11:33 AM
    koditten
    Kirk
    Central Michigan
    Yes it does, but my net book was working hard . The processer needed a bit more RAM, but it did work, but slow.
    It still amazed me that the best machine fif running TS, was Windows Vista .
    Boghog1[QUOTED] likes this.
  7. Mar 10, 2019 at 11:41 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I changed half click blinkers from 3 to 7. Techstream wasnt what I was hoping it was.
  8. Mar 10, 2019 at 12:48 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I use it for troubleshooting almost exclusively (4wd actuators, and similar)
    koditten likes this.
  9. Mar 24, 2019 at 2:33 PM
    Kodthree
    Kodthree Active Member
    Kody
    North Idaho
    2021 DCLB TRD OR SUPER WHITE
    AVS vent visors. 3M Chip Guard. Spiker hood struts, Pro grill with amber Raptor lights, and Baby Yoda start button all incoming. Rek Gen flaps and Bak Flip X4S next on list. Kryptek Ballistic Tactical seat covers in November during their big sale. Tim at Heavy Metal Off Road going to use my truck as a mule for development/fitment/ design of the long bed version of his EXCELLENT rock sliders! His bed rack, ditch brackets, and bed stiffeners will be going on as well.... Awesome products, fantastic service! He is worthy of your attention!
    Can TS be used to dial the cruise control setting down so it will activate at 20mph or 25 mph? I can activate mine at 30 and drop it down to 28 before it shuts off now.
  10. Mar 24, 2019 at 3:06 PM
    chriscamilo
    chriscamilo Well-Known Member
    2018 Tacoma DCSB Sport
    Any particular cable you guys are using?
  11. Mar 24, 2019 at 3:13 PM
    valeyellow46
    valeyellow46 Well-Known Member
    Christopher
    Tacoma SR5 Cavalry Blue
    Just don't be like that dummy on Youtube who used OBDEleven and facked up his entire car with the tool lol
  12. Mar 24, 2019 at 6:11 PM
    skonie
    skonie Well-Known Member
    Las Vegas, NV
    2019 TRD Off Road - DCSB - Cement
    Can it turn of the "open driver door" alarm? I have Carista but it doesn't seem to be able to turn off that alarm.
    NorrinRadd and bassmusic like this.
  13. Mar 24, 2019 at 10:57 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I used mine to update my ECU calibration to 04b04 for my OV Tune.
    Also, will program my Lexus key card sometime this week.
  14. Mar 24, 2019 at 10:59 PM
    koditten
    Kirk
    Central Michigan
    Yes it can.
  15. Mar 25, 2019 at 3:59 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Where is that option? I tried looking for that but couldn't find it.
    NorrinRadd and OriginalMan like this.
  16. Mar 25, 2019 at 4:02 AM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    It doesn't have that option.
    Deucer01[QUOTED] likes this.
  17. Mar 25, 2019 at 4:28 AM
    koditten
    Kirk
    Central Michigan
    Look under key chime. You door only dings when the key is in the ignition.
    If I recall correctly, there is 3 settings. You can turn it down to the quietest. They come from the factory set the loudest.
  18. Mar 25, 2019 at 4:37 AM
    Deucer01
    North Georgia
    Thanks, I'll look there.
  19. Dec 15, 2019 at 8:46 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Any idea if it can be used to change the default S mode gear from 4th to say 5th or 6th?
  20. Dec 16, 2019 at 12:35 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Pretty sure this is speed dependant? It was in my tundra. If i was on the interstate it went to 5th, around town it went to 4th
    dutchcontractor likes this.
