Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Oct 21, 2020 at 3:26 PM
    #321
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Never used it, but there's this:
    https://www.vmware.com/products/fusion.html
    You can get a free home use license.
  2. Oct 21, 2020 at 3:33 PM
    #322
    Daville
    Daville Life's too short to drive ATs
    Nashua, NH
    2011 Quad Cab TRD Sport w/ MT
    Oh, well that's new! Didn't exist last time I looked which was a year ago. I'll give it a try.
  3. Oct 21, 2020 at 3:34 PM
    #323
    lapoltba
    CT - 06076
    Lol. I'll just sit here and act like I didn't just google that shit....
  4. Oct 22, 2020 at 11:30 AM
    #324
    Daville
    Nashua, NH
    Ok, so it turned out the problem was the Techstream software I was using. I tried 2 different versions of v15. The first came with my Amazon cable and the second someone posted in this thread, but neither of them showed the "customize setting" button. I then installed v14 from lapoltba's sig and it worked this time. Confirmed success using a $30 cable and 32 bit windows on VirtualBox.
    lapoltba and tonered like this.
  5. Oct 22, 2020 at 11:36 AM
    #325
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff!
    :cheers:
  6. Oct 22, 2020 at 11:41 AM
    #326
    WhiteYota06
    WhiteYota06 Active Member
    Why did the older version work but not the newer? All the sellers on eBay keep touting they’ve the latest version etc. is it that v15 won’t run on 32 bit?
  7. Oct 24, 2020 at 4:08 PM
    #327
    harpo1
    harpo1 Well-Known Member
    Anyone know if there is anyway on a 19 Off-road to set the door handle sensor to unlock all doors instead of just the drivers door? I've gone into wireless locks and door locks and change the settings but nothing seems to work.
  8. Oct 24, 2020 at 5:22 PM
    #328
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You can do that from the settings within headunit. I did it on my 2017 and my 2020 without issue.
    harpo1[QUOTED] likes this.
  9. Oct 24, 2020 at 5:26 PM
    #329
    djdanmatthews
    djdanmatthews Member
    San Francisco
    02 PreRunner double cab
    I am sure the experts here can tell you more .... What I have learned. From buying V2.0.4 (newest) vs. V1.0.4(?)[ - older] only CAN Bus ... V1.0.4 can work fine on newer model Toyotas that use CAN bus. It is the older models that have KLINE and need often Dual Bus. They cheap out basically on chips. After a terrible experience with VCI adapters please don't buy them unless your willing to take a risk of it not working. Seems it works for some and not for others. Buy a Tactrix (official) not a clone as it has the support and faster support /drivers. Otherwise, it's an exercise in hacked software and making an inferior Chinese copy work.
    I have V2.0.4 and it still crashes directly on my system not VMware and the guys at MHHH say I have a faulty/slow cable. Havr tried TIS:V10/V12/V14/V15 . VMWare and Directly on Win 10. Drivers is another issue. With Tactrix you get 64-bit Windows drivers. With the Chinese Clones you get registry hacks for Win 10 and if you VMWare (XP/ Win 7) your using Chinese provided drivers that may be faulty or old.
    TIS- Is version dependent according to MHHH Auto website as newer cars may do fine with V15 but older cars may need even V6 V8 of TIS to get features. Older versions do not have all the security registration stuff for use on older models. Newer V of TIS has higher requirements the cheap cables may not fulfill transfer times, specs but yes it does have more features for newer Toyota Models.
    I think if it's cheap $18-22 and you're willing to take the risk buy a V1.0.4 VCI from ebay and use the above linked V14 TIS. Sell it off if there is an issue.
    tonered likes this.
  10. Oct 24, 2020 at 5:56 PM
    #330
    harpo1
    Perfect, thanks!
  11. Oct 29, 2020 at 5:18 PM
    #331
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I've read this thread and dug through TS functions and cannot find anything so before I give up via TS I'll ask here: Does anyone know if/how to change teh climate control display units from *C to *F? I bought a Canadian imported Tacoma and have changed the units settings for all of the driver info/infotainment screens, but the climate control display shows temps in *C. Google and searches on this forum have found a bunch of owners with the same issue but no solutions. I was hoping that this could be changed in TS.
  12. Oct 29, 2020 at 5:49 PM
    #332
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I'm sure I've seen that in techstream, but I'm also sure I've seen that in either the head unit or dash MFD.
  13. Oct 29, 2020 at 6:37 PM
    #333
    GrundleJuice
    Michigan
    2016 TRD Bro
    In the dash/cluster and in the head unit there are options to change units from km/mile and *C/*F, but they only apply those changes to the cluster and head unit. Those ones I changed. The climate control display stayed in *C.
  14. Oct 29, 2020 at 6:43 PM
    #334
    CAG Gonzo
    2018 OR DCLB BarRed
    Oh I'm sorry. Missed the climate control part. I don't have that so haven't explored it. But I know I've seen options for changing temperature units in techstream but I don't recall if it was global or specific to components.
    tonered likes this.
  15. Oct 29, 2020 at 6:45 PM
    #335
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Manual control, FTMFW!
    CAG Gonzo[QUOTED] likes this.
  16. Oct 29, 2020 at 7:05 PM
    #336
    GrundleJuice
    Michigan
    2016 TRD Bro
    I could find some stuff under "air conditioning" and it showed some temperature fields, one of which was "room temp", and the units were listed in F, but I couldn't see how to change that.
  17. Oct 29, 2020 at 11:39 PM
    #337
    CAG Gonzo
    2018 OR DCLB BarRed
    Hm not sure where it is. Isn't there a Customization submenu? Or maybe that's a techstream function rather than a one of those sections you click on, like a/c. Next time I use techstream I'll dig around.
  18. Oct 30, 2020 at 6:28 AM
    #338
    GrundleJuice
    Michigan
    2016 TRD Bro
    I'm not sure. I am unfamiliar with TS, this was my first experience with it and I was also on battery only so I didn't spend a bunch of time digging around. I'll try looking more this weekend and if you get a chance to look, thank you in advance!
  19. Oct 30, 2020 at 10:15 AM
    #339
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    I downloaded and installed version 14.20.019 from this link a few weeks ago.... https://drive.google.com/file/d/1rHumlcFInkXdfAGgap0XS0KijFZumfSA/view
    It installed fine, but when I attempt to use it, it is asking for an old version of Java for which I can't find an installer (JRE v6 update 1.6.0_7+). I installed a later version of Java on my machine, but I still get the error message each time I start techstream. It turns out that I didn't need to use Techstream at the time because OVTune did everything I needed in terms of reading my ECU version.
    Now I actually will need to use Techstream to program new TPMS sensors, so I need to fix this issue.
    Is there a newer version of Techstream available (along with the necessary keys, etc...) that either doesn't use java or uses a newer version?
  20. Oct 30, 2020 at 10:18 AM
    #340
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Did you install the Java Runtime Environment (JRE) or some other version of Java? You need JRE and not JDK (Java Development Kit), as an example.
    C41n likes this.
