Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Dec 16, 2019 at 12:44 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    I think only the man, ovtune, has the power to change this.
  2. Dec 16, 2019 at 2:14 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have never noticed that. I could see where that would be handy, though.
  3. Dec 16, 2019 at 7:15 AM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    It's not, you could be going down the road at 80 and kick it over to s mode and it'll scream up to 4th. I'm re gearing to 5.29 and it will be even worse, so any way to change it up, mod wise will be awesome. I havn't poked around in TS yet but just got my dongle for it the other day.
  4. Dec 16, 2019 at 3:58 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    well thats dumb. at least they did it right on the tundra (2010 model)
  5. Feb 29, 2020 at 7:49 AM
    Noch
    Noch Totally not a noob
    Taneytown MD
    '19 TRD OR DCLB Quicksand AT
    You search the mod-list, but don't find anything of interest.
    Anyone have any info on Techstream working on a 2019? All the cables and software I'm finding relate back to 16-18.. any info would be appreciated.
  6. Feb 29, 2020 at 7:56 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The version in my signature works for 2019s. Any compatibile cable will work with any year, although the Tactrix, or OVT Tactrix, is highly recommend.
  7. Feb 29, 2020 at 10:28 AM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    I just did a bunch of TS stuff on my 2020 using OVT’s cable.
    Nice to be able to tweak all the lighting setting, unlock/re locking functions, seat belt chime, turn signal count etc.
    FYI there was also an option to turn remote start on and off. I was able to toggle it “On”, but obviously it does nothing with the MT. I would have assumed it would have been greyed for the MT truck. It makes me suspect that ALL 2020 AT Tacoma’s are remote start capable, just needs to be turned on via TS.
    tonered likes this.
  8. Feb 29, 2020 at 10:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Did you use the version of TS linked in @lapoltba 's or my signature for that? I believe that up to now, we were assuming that version would only work through the 2019s.
    TeecoTaco and CdnSldr[QUOTED] like this.
  9. Feb 29, 2020 at 11:20 AM
    CdnSldr
    Canada Eh!
    It was a TS version through somebodies signature. Can’t remember who, but pretty sure it wasn’t yours.
  10. Feb 29, 2020 at 11:33 AM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    What version do you see when you do Help > About?
    Same question to you Tony
    CdnSldr[QUOTED] and tonered like this.
  11. Feb 29, 2020 at 11:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We're the only two AFAIK, so that is really cool.
    V14.20.019
    TeecoTaco[QUOTED] likes this.
  12. Feb 29, 2020 at 11:48 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    It will still work, but the newer features may or may not be supported. I don't know of any official release notes that says what is/isn't supported, but I also haven't looked.
    tonered[QUOTED] and TeecoTaco like this.
  13. Feb 29, 2020 at 11:50 AM
    TeecoTaco
    SW Ontario
    May have found a test pilot :thumbsup:
    tonered likes this.
  14. Feb 29, 2020 at 11:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With @CdnSldr being able to do customizations, that is pretty stellar.
    Of course, there might be other limitations.
    :cheers:
    TeecoTaco and CdnSldr like this.
  15. Feb 29, 2020 at 12:19 PM
    #35
    CdnSldr
    Canada Eh!
    I’ll check after work this evening.
    Any idea what wouldn’t be supported?
    The menus seemed pretty in depth. Can modify how aggressively auto climate control tries to achieve desired temp, how sensitive the light sensor is for auto headlights; both for how easily they turn on and off...just to give a few examples.
    I’ll take some screenshots of the various menus and post them.
    TeecoTaco[QUOTED] and tonered like this.
  16. Feb 29, 2020 at 12:28 PM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For V12, all that we could do on 2018s was the TSB tune because that didn't require launching TS, which wouldn't connect.
    So, just getting into TS on a 2020 is a big deal given our earlier assumption. I don't have any doubt that you would be able to do TSB updates.
    The only other thing would be diagnostics and monitoring. Pretty much the same function.
    If you import the datalogging list from the zip file, you should be able to see a bunch of live parameters with the engine running.
    One really neat thing to see in TS is the TPMS monitoring. Live at 0.01psi with temperature. Stuff like that makes info-whores like me happy.
    SouthFLTaco, C41n, Noch and 2 others like this.
  17. Feb 29, 2020 at 2:07 PM
    #37
    lapoltba
    CT - 06076
    Really? as far as I knew V12 should have been fully compatible with 2018s at least.
  18. Feb 29, 2020 at 2:17 PM
    #38
    TeecoTaco
    SW Ontario
    Nope v12 TS would not connect to 18s. Upgrade ECU firmware yes, but that is all
    tonered likes this.
  19. Feb 29, 2020 at 2:27 PM
    #39
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What @TeecoTaco said. I updated another TW'ers 2018 MT, but could only do customizations with Carista.
    TeecoTaco likes this.
  20. Feb 29, 2020 at 2:45 PM
    #40
    lapoltba
    CT - 06076
    EDIT*
    Nevermind I was confused and thought we were talking about V14 not v12 for some reason...... Yes, V12 doesn't work past 2017.
    TeecoTaco and tonered[QUOTED] like this.
