Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Aug 23, 2021 at 4:28 PM
    #541
    fczabala
    fczabala Well-Known Member
    Long Island, NY
    thank you!
    tonered[QUOTED] likes this.
  2. Sep 22, 2021 at 5:08 AM
    #542
    TifosiTuning
    TifosiTuning KDMax Authorized Pro Tuner
    Nick
    South Bend, Indiana
    2021 DC MGM TRD PRO
    KDMaxx tune, many interior mods, Wildpeaks A/T3W 265 75 R16’s,
    I have a 2021 pro and read somewhere that I can NOT use ver 14. Is this still true? Do I need to use ver 16? And if so how can I register it? Thanks
  3. Sep 22, 2021 at 5:26 AM
    #543
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. That is true. V14 will only allow you to do TSB updates, but you cannot connect to your Taco for diagnostics or Customizations. You need a newer version. The recent V16 version that was posted is good through the 2022s.
  4. Sep 22, 2021 at 5:31 AM
    #544
    TifosiTuning
    Nick
    South Bend, Indiana
    2021 DC MGM TRD PRO
    Do you use the same registration process as in ver 14?
  5. Sep 22, 2021 at 5:35 AM
    #545
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    As noted here and in the 1st Post of the ECU Update thread, it is very different. You need to find a source for the activation key.
  6. Oct 7, 2021 at 11:30 PM
    #546
    WalkerMatthews
    WalkerMatthews Member
    Has anyone used any sort of power supply/charger while doing an ECU Flash? Techstream is recommending using one for an ECU flash to avoid irreversible damage to my ECU but I have never seen anyone mention anything about this before. Do I really need a power supply or should I just pay Techstream and update it my ECU?
    I want to install KDmaxx with Vftune so I need that new ecu installed.
  7. Oct 8, 2021 at 3:40 AM
    #547
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I do it for my customers as added protection. I would use one the first time since updating and/or flashing is new to you.
    Most people use battery chargers, and some use battery chargers that can act like a 12v source. Haven't seen any complaints from either so take your pick.
  8. Oct 8, 2021 at 11:38 AM
    #548
    WalkerMatthews
    Gotcha. I’ll go pick up one of those jumpstart/charging kits for this first go round. Appreciate it.
  9. Oct 8, 2021 at 3:43 PM
    #549
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    If it's an option for you, I personally just jumper cable to another car. Takes all of five minutes so no big deal to idle a car for that long.
  10. Oct 8, 2021 at 4:51 PM
    #550
    gForceDude
    gForceDude Well-Known Member
    Here's a good one:
    https://www.amazon.com/NOCO-GENIUS10-Fully-Automatic-Temperature-Compensation/dp/B07W3QT226?th=1
    Made in America, Built like a Brick, Works great!
    (This model has a '12 volt supply mode' which is what you need)
    TacoManOne likes this.
  11. Oct 8, 2021 at 6:38 PM
    #551
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    That's the exact same one I have as well, lol
    gForceDude[QUOTED] likes this.
  12. Oct 12, 2021 at 10:12 AM
    #552
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    4 years I have owned my truck and wanted to dabble in the ECM side of things, so I decided to downloaded Techstream and give it a try. Unfortunately my OBDLink MX won't work with it so I finally broke down and ordered the Tactrix Openport 2.0 dongle. Might upgrade my laptop soon too...
    From experience I can tell you bricking an ECM during a recal is not fun. I recently bricked one on a vehicle at work after a localized power failure. I forgot to plug in the PC's back up battery and it shut down. An expensive piece of equipment down is never a good thing. Luckily it was a quick call to Cummins and a new OEM recalibration code and it was up and running. Experience like this though makes me cautious with my truck.... my truck my dime, work vehicles, someone else's dime.
  13. Oct 12, 2021 at 10:16 AM
    #553
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Both vF and TechStream do not require much HP on the computing side. Just about anything that you can buy with a Windows or Mac OS will work. You just need a USB port really.
    The Recovery feature in the vF software has become very robust. I know of several folks that have unbricked with it, and it is said that it will now even recover if a TS Update fails.
    Big note, all of the supported Stock files are in the installation directory:
    C:\Program Files (x86)\vF Tuner\
    vF Tune files are purchased separately.
  14. Oct 12, 2021 at 10:39 AM
    #554
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Thank you for the information. Once I have the dongle in hand, I will familiarize myself with Techstream before I get into doing the tuning side, but that is definitely where I want to go with this. I appreciate all the posts that you have made and the posts of others that have supplied such great information on the subject.
  15. Oct 12, 2021 at 10:40 AM
    #555
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    I appreciate the compliment!
    Reach out with any questions.
    :cheers:
    Speedfreak[QUOTED] likes this.
  16. Nov 23, 2021 at 9:12 PM
    #556
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Anyone have TIS in SoCal region? For some reason I dont have TIS anymore and need to get a new version.
    I am having a TPMS issue, I would like someone to scan my vehicle and give me the voltage readings for each sensor. If anyone can help I would appreciate it.
  17. May 10, 2022 at 12:46 PM
    #557
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    @tonered Does TS V16 work on Windows 10? I assume so, but Toyota's website only mentions Windows 7 and 8.
    tonered likes this.
  18. May 10, 2022 at 12:47 PM
    #558
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It works on both Win10 and Win11.
    Matt Sierra[QUOTED] likes this.
  19. May 10, 2022 at 12:49 PM
    #559
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Why do you need TIS? You can get TechStream here:
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    Everything you need is in the 1st Post.
  20. May 10, 2022 at 12:52 PM
    #560
    Matt Sierra
    NorCal
    2020 TRD Pro MT
    Awesome, thanks!
