Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Mar 26, 2023 at 4:51 PM
    #601
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    New quandry:
    I'm having a problem getting TS to successfully change the seatbelt warning tone for both the driver and passenger seatbelts.
    I've used version 16.20.023 and now have upgraded to 17.30.011 to no avail. The indications within the program seem fine and everything else I have tried to do with TS have taken effect properly, I've had success changing many other features using TS. Just can't get rid of that annoying tone when seatbelts are not on. The indications within TS act normally with highlighted fields and saving looks like it is completed within the program. 2021 Off Road access cab 55,000 miles.
  2. May 3, 2023 at 1:53 PM
    #602
    Spacemo
    Spacemo Member
    2020 Tacoma Sport
    None so far
    I am having an issue with logging onto Techstream V16.10.016. I got the registration key thru MHH auto but now it wants me to sign into my account with a username and password. I have no account and I didn't see any place to register for an account. Is there a way to bypass this or to get an account? thanks for any help.
  3. May 3, 2023 at 5:51 PM
    #603
    Toycoma2021
    Do not sign in, use the offline function.
  4. May 4, 2023 at 7:47 AM
    #604
    Spacemo
    Spacemo Member
    2020 Tacoma Sport
    None so far
    I think I got it. Thanks.
  5. Oct 1, 2023 at 2:54 PM
    #605
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    What cable is everyone using for 2nd gens? I'm not looking for ECU programming, I just want the ability to load the 8 or so modules for my 2015, program TPMS, read diagnostic and some of the VSC/ABS utilities. I've seen what appears to be a knock off Tactrix cable for pretty cheap here: https://www.obd2eshop.com/wholesale/tactrix-openport-20-ecuflash.html
    retardrabbit and MattiasdelTaco like this.
  6. Oct 2, 2023 at 7:02 PM
    #606
    Toycoma2021
    I use the "real" Tactrix as I wanted something I knew would work and I could get help with here..., however this thread seems to be somewhat inactive.
    MattiasdelTaco likes this.
  7. Jan 18, 2024 at 2:28 PM
    #607
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    Is this Tactrix openport 2.0 what you’re using currently $169? https://www.tactrix.com/index.php?option=com_virtuemart&page=shop.product_details&product_id=17&
    I saw someone here bought vxdiag and made it work with techstream.
    I’m wondering what the easiest/most reliable way to get a working copy of techstream going on an offline computer, for recent taco model years.
    A lot of info/posts seem possibly dated. All i want to do in the near term that i have not already is rotate wheels and update tpms, without using carista. Carista for $10 was not bad to do most settings. But techstream may be handy for other things in the future.
  8. Jan 18, 2024 at 5:28 PM
    #608
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I've been looking into this also. I lost my last version when my computer died and I'm going to need to change the trans fluid eventually
  9. Jan 18, 2024 at 6:19 PM
    #609
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I use 12.10 version (up to 2018 models). But I used it successfully to update settings on 2022 toyota. You don't need the highest version for basics.
    Tactrix is preferred if you are into a tunning. Otherwise, use whatever works with techstream
    On the same note, techstream is way better app for the data logging.
    Techstream has built-in functions to test/troubleshoot systems, but there are products that have the same capabilities. May cause a few hundreds.
  10. Mar 4, 2024 at 9:14 AM
    #610
    rettinger11
    rettinger11 Member
    23 MGM TRD Off-Road DCLB
    Leer 100xl JBA UCA Bilstein 6112/5160s w 650lb coils OME EL112r Heavy
    Has anyone been able to use techstream to change the safety protocols Toyota has put in the trucks from the factory. I.e the truck shutting off when the door is opened or unlocked after remote start used. Or having parking lights turn on when using the remote start. Any information would be helpful. Thanks
  11. Mar 4, 2024 at 5:03 PM
    #611
    AODRN
    STL
    There was definite talk that made me think there was no way to keep the truck running when the door opens.
    I'm still working on getting techstream to work again after switching computers. I'm going to have to figure out the new process cause my old stuff isn't working
  12. Mar 4, 2024 at 5:10 PM
    #612
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    musicisevil likes this.
  13. Mar 5, 2024 at 8:14 AM
    #613
    rettinger11
    rettinger11 Member
    Good to know, I’ll have to check that out. @AORDN you have to let me know what you end up doing I’m interested in using the software. Thanks
    AODRN likes this.
  14. Apr 18, 2024 at 5:02 PM
    #614
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Whats the newest version of techstream? Im trying to find it
