Temp Gauge Calibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knayrb, Mar 29, 2011.
  1. Mar 29, 2011 at 3:45 PM
    knayrb
    knayrb [OP] Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Usually in the early morning on the way to work I listen to our local news station. I work about a mile away from the actual broadcast studio where they also have weather equipment. On the radio every 15 minutes they announce the time and temperature at the station. I look at my temp gauge and it's about 2-5 degrees off. I have even deliberately driven by the station to check the trucks temp gauge with what they are saying. My Honda's temp gauge is usually right on or just a degree off.
    Also my garage is attached to my house so the temp in the garage is about 15 degrees warmer on colder 30 degree days. It takes a good 10 minutes of driving before the temperature drops closer to the actual temperature outside. My Honda will sense a change of air temp in about 30 seconds.
    Is my temp gauge whacked? Do others have the slow sensing time I have in my truck? Is there a known hack that re-calibrates the temperature gauge?
  2. Mar 29, 2011 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It all depends on where the temp station is located. Out here, Its normal for the temp to vary as much as 8 degrees or more from spot to spot.
