Temperature issue in my 98
Discussion in '1st Gen. Tacomas (1995-2004)' started by Submariner, Jun 25, 2012.
  1. Jun 25, 2012 at 4:26 PM
    Submariner
    Submariner [OP] Member
    Wayne
    Eagle Point, Or
    98 tacoma sr5
    air filter and custom headlights
    It seems that my temp gage moves alot while I am driving. Also it seems to take a long time to get warm.
    Any suggestions or thoughts?
    Thanks
  2. Jun 25, 2012 at 4:47 PM
    Madjik_Man
    Colorado Front Range
    By no means do you want me diagnosing your truck. I'm just taking a guess here and seeing if it's what the actual mechanically inclined guys think:
    Busted thermostat
  3. Jun 25, 2012 at 4:54 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Well, you have a problem, and we will need some more information to help find your problem. How many miles do you have on your Taco ? Have you changed your antifreeze ever ? Can you do your own repairs or do you take it to be repaired ?
    From your information that you have provided, you have a bad thermostat. Have you changed it in the past and how long ago did you change it ?
    When you reply with some more info, we will give you more help. Good Luck.
  4. Jun 25, 2012 at 6:24 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    I flushed the coolant and replaced the hoses and thermostat on my truck this spring and it needed it. none of which was hard. it was dirty so it was tiime consuming. anyway one word of advise, go to the dealership or go to NAPA and get a high quality thermostat to replace your. I'm sorry but the cheap ones at the parts stores don't compare
  5. Jun 26, 2012 at 9:06 AM
    Submariner
    Wayne
    Eagle Point, Or
    98 tacoma sr5
    My Taco has 150K on the truck. I just bought it a month ago. :)
    The coolant looks like coolant suppose to look like. I guess. It does not overheat. just takes a long time to get warm. could the thermostat be stuck open? :confused: :eek:
    I think that I can replace a therostat. I have done it in the past to my ford truck and to my jeep. Is there a trick to changing the Thermostat on a Taco.
    How hard is it to do?:rolleyes:
  6. Jun 26, 2012 at 9:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it's an easy fix.
  7. Jun 26, 2012 at 9:39 AM
    scocar
    scocar hypotenoper
    If the hoses are old and it gets hot at higher speeds, you could also have a collapsing hose. Might as well replace the top and bottom hoses while you are making a mess.
  8. Jun 26, 2012 at 10:50 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    well i got my truck last fall, and thank god we did not have a winter, and this spring I flushed her out.... just so I would know how new the coolant was and how clean the radiator was... and it took 2 days... flush, fill, and run, it was very dirty. but its easy to do, and your will save a bundle doing it your self.
    and remember like oil, auto parts stores are required to take back old anti-freeze.
  9. Jun 26, 2012 at 11:39 AM
    ferg79
    ferg79 Active Member
    Sachse, TX
    2010 TRD DC Tacoma DD, 1998 Tacoma Toy
    2010 Borla Exhaust, Indash Nav unit 1998 2.5 in Rancho lift(crap), 33x12.5 BFG's, Many more to come!!!
    I had the same problem with my 98. Gauge all over the place. Had and air bubble in the radiator. Bled it out and no more problems.
  10. Jun 26, 2012 at 11:51 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    My '95 PreTaco thermostat stuck open and took forever to warm up. Easy to replace.
  11. Jun 26, 2012 at 12:00 PM
    Blackcat10
    Blackcat10 Well-Known Member
    When you replace your thermostat there is a small hole with a brass piece in the hole located on the outer ring of the thermostat. This is a air bleed. Make sur this is positioned up.
    And yes it sounds as if your thermostat is sticking open.
  12. Jul 25, 2012 at 1:01 PM
    Submariner
    Wayne
    Eagle Point, Or
    98 tacoma sr5
    ok, here is an update,
    Change the thermostat. peice of cake.
    there was what looked like an o-ring stuck in the flow opening of the themostat which would not allow for the thermostat to fully close.
    I wonder how long it was that way./ PO jeessss
    everything works fine now. enging comes up to temp quick and maintains a steady temp on the gauge.
    All is good.............:):):yay:
  13. Jul 25, 2012 at 1:05 PM
    4Wheelin4Banger
    Randy
    Glad you got it fixed.
