terrible rear end vibration after gray wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rhino, Jun 9, 2011.
  1. Jun 9, 2011 at 8:57 PM
    Rhino
    Rhino [OP] Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    so i done the gray wire mod and it worked great for one day..but then i was going down the road and when i hit 45-55 mph my rear end and on up my driveshaft vibrates and jumps like crazy so i undone the mod and re connected the gray wire but its still doing the jumping and vibrating does anyone know whats going on with my truck???:confused::eek:
  2. Jun 9, 2011 at 9:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    May not have anything to do with the grey wire mod......may be a bad u joint. Crawl under and heck to see if its loose or
    can be shaken back by the rear end.
  3. Jun 9, 2011 at 9:09 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    how do i check to see if its loose? that may be a dumb question but i have no knowledge at all of anything past the engine
  4. Jun 9, 2011 at 9:27 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    definitely has nothing to do with grey wire mod. check your carrier bearing too, bu getting underneath and seeing how far you can move the driveshaft within the carrier (middle support in midpoint of truck) shouldnt be more than 1/4 inch. Mine is pushing beyond 1/4 inch, but I do not have the vibration issues you have. Definitely also check u-joints.
  5. Jun 9, 2011 at 9:28 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    crawl under, grab your drive-shaft about a foot before it enters your diff and try to wiggle it back and fourth.
    There should be no play, if there is it could be your u-joint or your pinion bearing.
  6. Jun 9, 2011 at 9:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Its pretty easy to check, on level surface, in park. Crawl underneath your truck by the rear differential & note where the driveshaft connects to the flanged yoke on the diff, grasp the drive shaft firmly with both hands & "twist " the shaft clockwise/counter clockwise looking closely at the U joint for signs of damage, movement between the Ujoint & the flange its connected to, there should be no movement (shit, wish I had a pic to show you ) The other check is while still grasping the driveshaft try moving it vertically up & down, then horizontally side to side . There should be no sloppy loose movement either up & down or side to side....;)
  7. Jun 9, 2011 at 9:45 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    wait, were you driving on the pavement with the locker in?
  8. Jun 9, 2011 at 9:58 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    no the locker is disengaged when it vibrates and its only around 55 mph when i get past 55 it stops and when im slower its fine as well
  9. Jun 9, 2011 at 9:59 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    You weren't doing donuts on dry pavement with the locker on were you? :anonymous:
  10. Jun 9, 2011 at 10:03 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    no all i done was do the mod go crank the truck in my grass lock it in 2hi 4hi and 4low..then disengaged it put it back in 2hi and turned my truck off..it worked then but when i went to work this afternoon the vibrating started so i undone the mod in the parking lot with my boss put everything back factory and now it still vibrates
