Tesla style head unit
Discussion in 'Audio & Video' started by arcenik, Sep 15, 2021.
  1. Jan 1, 2022 at 4:33 PM
    #641
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
  2. Jan 1, 2022 at 4:34 PM
    #642
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    Hard reset using the reset button on the bezel?
  3. Jan 1, 2022 at 4:48 PM
    #643
    Diabl0
    Tim
    Massachusetts
    Yes. Should rds and North American be selected or just NA?
  4. Jan 1, 2022 at 4:49 PM
    #644
    Diabl0
    Tim
    Massachusetts
    I’ll check the antenna wire tomorrow. It’s getting dark out
  5. Jan 1, 2022 at 4:59 PM
    #645
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    I only have north America
  6. Jan 1, 2022 at 5:20 PM
    #646
    Diabl0
    Tim
    Massachusetts
    Also when I’m connected to Bluetooth and 5G google doesn’t work.
  7. Jan 1, 2022 at 5:35 PM
    #647
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    Im not sure what you mean?
  8. Jan 1, 2022 at 5:37 PM
    #648
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Anyone know how to find the climate controls / get them back on the display after Sergey’s firmware ?
    Is there anywhere to see what all 50 themes look like other than loading and rebooting after each one ?
  9. Jan 1, 2022 at 5:41 PM
    #649
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    List of themes
    https://disk.yandex.com/d/IBlgtbD9jeGFEA
  10. Jan 1, 2022 at 5:50 PM
    #650
    Diabl0
    Tim
    Massachusetts
    When my phones connected to the unit should I be able to use the browser? How do I do this?
  11. Jan 1, 2022 at 5:53 PM
    #651
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    If you are connected through carplay, no
    If you create a hotspot with your phone and use wifi on the head unit to connect to it, yes.
  12. Jan 1, 2022 at 6:01 PM
    #652
    Diabl0
    Tim
    Massachusetts
    Oh I’m on an unlimited plan I can’t make hotspots. That sucks for me
  13. Jan 2, 2022 at 5:08 AM
    #653
    Diabl0
    Tim
    Massachusetts
    I took off the unit and found my antenna wire came loose. It’s not a tight fit and the local channels still don’t come in clear. I ordered an extension. I hope it tightens things up maybe mine needs a little more size. It fit my last HU fine. I hope this isn’t an on going issue.
  14. Jan 2, 2022 at 7:28 AM
    #654
    Diabl0
    Tim
    Massachusetts
    Update I got my extension and now it works great.
  15. Jan 2, 2022 at 12:00 PM
    #655
    Hypertaco
    Hypertaco Well-Known Member
    Kevin
    Garner, NC
    2012 tacoma x-runner
    2012 Toyota Tacoma X-Runner TRD Pro Grill Magnuson S/C with TRD Flash and HPTUNER Tune Innovate Dual Gauge (Boost,EFR) (Not installed) Innovate Oil Pressure/temp Gauge (Not installed) Scangauge II Ultra Performance Thermostat from URD (not installed) 255 Fuel Pump from URD (not installed) JBA Exhaust URD CAI URS SS 6 speed TRD Shift Knob Leather Interior Custom Gauge Face for Speedometer from Blackcatcustom with X-Runner logo Blue LED's in gauge cluster with White Needles Tesla Style PX6 Android 9 12.1" Radio Custom Stereo Enclosure with Opt7 Led's Sundown X8 subwoofer Rockford Fosgate Component's Rockford Two ways 2 Alpine X-Power amps Bluetooth Stereo with Rockford 2-way in bed 19x10.5 Varrstoen ES9's Black 285/35/19 Indy 500's Gaylord Speedsturr Bed Cover Feal Coilvers - removed XII lowering Leafs - removed QA1 rear shocks - removed Back to brand new factory suspsension Kenwood Motorcycle Mount Bluetooth Stereo in the bed with 400w amp and Rockford speakers Wireless phone charger thanks to ThreatLevelMidnight
    so if my 2012 only has XM antenna, but it's shark fin, can I still utilize the extension for GPS? probably not huh? I don't mind tucking the stock GPS antenna under the dash, but would love to use the shark fin instead.
  16. Jan 2, 2022 at 12:58 PM
    #656
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Hypertaco[QUOTED] likes this.
  17. Jan 2, 2022 at 2:33 PM
    #657
    sngdawgs
    sngdawgs Active Member
    Scott
    2005 Toyota Tacoma TRD Double Cab
    Even make sure you're not using Nova launcher.....I was and lost climate controls....removed Nova from default and climate controls were back.
  18. Jan 2, 2022 at 2:38 PM
    #658
    sngdawgs
    Scott
    Arc, what is tasker? Is that a app available form the store? Zlink is turned off in the droid settings, and yes that's what I'm experiencing....having to turn on and off hotspot to make it visible to the HU.
    Can anyone speak to the hotspot of a droid? Is the newer droid phones the same way? I'm due for an upgrade and need a reason to get away from this iphone....
  19. Jan 2, 2022 at 3:44 PM
    #659
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    I know the hotspot on an iPhone won't consistently broadcast the SSID this is a limitation with the iPhone. You will need to open the setting before it will broadcast.
    Tasker is an app for android, you can make it turn things on and off based on certain conditions. For example, once Bluetooth connects to a certain network it can turn on the hotspot of the android phone, then the radio should see the wifi and connect automatically.
  20. Jan 2, 2022 at 5:34 PM
    #660
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
