Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Jan 22, 2013 at 1:05 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I work for a glass subcontractor
    Looks like yours is all bolted together. Seems like it could then be folded flat once removed for convenient storage.
  2. Jan 22, 2013 at 1:13 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I have actually been looking at a kit for that and thinking I would like to put it on my list. I'm not a big Brown Ale fan; but the last time I had Moose Drool it was pretty good.
  3. Jan 22, 2013 at 1:29 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Where can this be had in a size that fits the bed rails? I'm thinking you could use those with a bolt that has a knob on it that would allow for hand tightening. Would be pretty simple. I guess you'd need 8 for a setup like yours.
    We're on the same page here. That's what I was thinking. Could hang it on a wall or something and take up zero floor space. Looks like I'll be buying stock in metal cutting wheels. Then I'll need to get in touch with my Line-X friend.
  4. Jan 22, 2013 at 2:10 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    This thread has a bunch of info on the different kinds and where to get them
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/114001-bed-rails-attachments.html
    This one looks pretty good, then you can just use a nut to tighten it down
  5. Jan 22, 2013 at 3:06 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Clayton, thanks for the link. Those bolts look great! I have an idea for some attachment knobs too.
    I went to HD today to look at some steel and aluminum. Honestly, I think the boxed aluminum is probably plenty strong. But the natural overkill by nature side of me wants the steel....
    One thing I was wondering was lateral strength. The style you did looks strong front to back but what about lateral stability? Seems like the cross member is the only thing for lateral stability.
  6. Jan 22, 2013 at 3:07 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Edit: Nevermind....just saw the diagonal supports that touch the cross member. Didn't see those at first.
  7. Jan 22, 2013 at 3:13 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Just ordered 20 of those bolts. I figured I'd need them for something else too.
  8. Jan 22, 2013 at 3:17 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Awesome, thanks for the offer. I'll hit you up if I need it. I have an idea that might work without any welding but I'm not sure.
  9. Jan 22, 2013 at 4:29 PM
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Depending on the wall thickness of the alum., I'm thinking you wouldn't be able to put much torque on the bolts before you start bending the alum.
  10. Jan 22, 2013 at 4:41 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Good point. In my case the steel was cheaper as well
  11. Jan 22, 2013 at 5:17 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Right, I was considering using washers to spread the load over a larger area but I suppose the correct thing to use would certainly be the steel. It's just soooooooooooo much easier to drill aluminum. I guess I'll bite the bullet and go buy a few drill bits to throw away after I'm done so I don't screw up the ones I have.
  12. Jan 22, 2013 at 5:51 PM
    98cbtacoma
    98cbtacoma Well-Known Member
    Austin
    Boerne, Texas
    98 PreRunner white
    Cobra cb and 3' cb antennas, headache rack, bed rails, blacked out logos. Goodyear wrangler tires. Second gen Tailgate badge. Hella 500 series black magic lights and 500 series lights on top, led brake and turn lights on my headache rack. Custom Bumpers i built myself.
    Will say its cool going from the san antone area up to waco to see all new sea of tacomas! Couple of nice ones running around my campus (TSTC) including beau's. two others are first gens that look like chicks driving, one a 01-04 white ext cab, tinted taillights, pink browning sticker, stock 97-00 wheels painted black like on my truck with a blue circle painted in the middle. The second is a 01-04 red double cab lifted, bed bar with hella, ammo can, tire in the bed, and roxy stickers on it.
  13. Jan 22, 2013 at 9:00 PM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Anyone from Houston driving to Austin anytime soon? I need a pony expess for a LCA
  14. Jan 22, 2013 at 9:05 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Ok, this may be unmanly....but I've never used a step drill bit.
    I have basically every other size drill bit known to man. I have a set of forsner bits and I even have a hole saw. What's unique about a step drill bit and what's it best used on?
  15. Jan 23, 2013 at 4:28 AM
    tx_shooter
    Pretty much what he said; but step bits are often better for quick jobs in non-hardened materials. I know they do work in hard materials (we used a set to drill my kegs out) but regular steel or plastics are great jobs for step bits. They are a worth while investment; but that is a chunk of change.
  16. Jan 23, 2013 at 6:16 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Sure thing man, just PM me and I'll help you any way I can.
    Realistically I'll just need to drill out the holes for the fasteners on the setup. It would be nice to have a drill press one day but right now in an apartment (even with the garage) I don't have the space. My Hitachi LI drill works just fine for now. (love that thing:D)
  17. Jan 23, 2013 at 6:50 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Drill press... I know where one is
  18. Jan 23, 2013 at 2:46 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
  19. Jan 23, 2013 at 5:26 PM
    tx_shooter
    Sometimes no news can be good news.
  20. Jan 23, 2013 at 5:48 PM
    baconbits2_98
    baconbits2_98 Smurfette
    Becky
    Houston
    4x4 Money Pit
    Lifted, locked and ready to rock
    Because we love to listen to y'all complain?
