Thanks in advance.
Discussion in 'Technical Chat' started by BREEZ7OHYEAH, Sep 5, 2011.
  1. Sep 5, 2011 at 3:20 PM
    BREEZ7OHYEAH
    BREEZ7OHYEAH [OP] New Member
    2WD Tacoma
    What does the battery symbol lit on the dash mean??
  2. Sep 5, 2011 at 3:25 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    with engine running? check your battery voltage should be around 14volts at idle.
  3. Sep 5, 2011 at 3:47 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ^^this. battery voltage is low. probably either bad connections, weak battery, or weak alternator.
    EDIT: or take it to an advanced auto/autozone and have them do a battery/alt test for free.
  4. Sep 5, 2011 at 5:06 PM
    BREEZ7OHYEAH
    2WD Tacoma
    Thanks Folks.
    The truck sat for 2 weeks and I had never seen that display before.
