Thanks to All, OME 3" lift with AAL Installed, What I learned
Discussion in '2nd Gen. Tacomas (2005-2015)' started by House Doc, Jan 31, 2011.
  1. Jan 31, 2011 at 5:58 AM
    House Doc
    House Doc [OP] Active Member
    Thanks to everyone on the forum, lots of great posts, sticky's, and replies to my ?'s. I installed the 3" OME kit from Toytec on my son's 07 DC Prerunner.
    A friend who runs a garage had his guys swap the front coils and shocks out using a wall mounted spring compressor. I would not want to use a cheap compressor for this. The springs are stout.
    Anyway, here are a few things I did to make it work for me. Still took about 8 hours total, did the front 1 day, AAL on Sunday. My son helped, he know knows about torque wrenches, air tools, etc. We crawled around the garage floor, a lift would have been nice! On the front. I did not remove the sway bar completely. I disconnected it and moved the bar forward and rotated it out of the way. I could not get enough leverage to get the new shock/spring compressed enough to install the lower shock bolt. I was working alone. What I did was partially screwed in the lower ball joint bolts till only the non-threaded portion of the bolt was showing. This extra inch allowed me to get the shock bolt in, then tighten up the lower ball joint to finish it up.
    On the AAL on the rear, I cut about 1 1/2 inches off the bolt that holds the springs together. I could not get enough separation between the axle and the springs to get the total length of the new bolt in. I still had plenty of length and cut the bolt off after getting the springs all tight and torqued. A recip saw really works great here.
    I am very glad I researched the lift choices and did not use spacers. My son's truck has 87K on it so all 4 shocks that came in the kit was a plus as I was going to replace them soon anyway.
    Thanks again,
  2. Jan 31, 2011 at 6:20 AM
    Natetroknot
    Natetroknot Def Leppard Sucks!
    Nate
    Dubuque, IA
    '11 Black Access Cab
    Billy's @ .85, 1.5 Progressive AAL, Leer 100xl, BFG KO2's
    Congrats on the lift!
    A pointer for you: check the u bolt torque for a few days after you drive. My AAL install settled, which loosens up the u bolt nuts in severe cases. Then the goddamn AAL gets out of line with the leaf pack.
    Maybe it was just my luck, but one side loosened up pretty good, I'd say 20-30 ft lbs.
    Lets see pics!
  3. Jan 31, 2011 at 11:05 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I would like to see some pictures post-lift. A little pointer for the rear bolt that you had trouble getting in.....since your rear axle is loose you can slide the axle far enough forward to get the bolt to go straight in without cutting it.
    What part of Bama are you from? I'm in NW AL.
  4. Jan 31, 2011 at 1:15 PM
    House Doc
    I will get some pic's when my son stays home long enough to take them:)
    I followed some advice and only unbolted one side of the axle at a time, leaving the other side still connected via the U-Bolts. That may have limited my axle travel but I felt it helped keep things in fairly close alignment. He is due for tires soon and will get the alignment checked. I will post some pic's ASAP.
  5. Feb 5, 2011 at 6:19 AM
    House Doc
  6. Feb 5, 2011 at 6:29 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    :thumbsup: nice job, looks great and i bet your son loves it!
  7. Feb 5, 2011 at 8:17 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2!
  8. Feb 5, 2011 at 8:25 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Roll tide! nice to have another lifted truck from down south. Congrats on a job well done!
  9. Feb 5, 2011 at 8:39 AM
    Indian Shifter
    Indian Shifter Well-Known Member
    Ashil
    Oregon
    2011 White DC TRD Sport 4x4 Manual
