That >8,000 lb. winch is a waste of money.
Discussion in 'Recovery' started by TomHGZ, Aug 24, 2020.
  1. Aug 25, 2020 at 3:50 PM
    #261
    Grindstone
    Grindstone Requires Adult Supervision
  2. Aug 25, 2020 at 3:56 PM
    #262
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    Couple questions for you:
    • What would you be prussiking with?
      • Synthetic winch lines are extremely slippery, and while I've never tried it, my guess is you would have an extremely difficult time actually getting anything to grab. I imagine the effect is also there with steel cable, though maybe not as pronounced as with the synthetic.
      • I haven't seen a wire rope grab that's rated for the 6k lbs loads you're talking about putting on it, and I don't believe they would work well on a synthetic winch rope due to its construction.
      • You'd need ~6mm cord to hold 6k lbs when its doubled up. This will not work well as prussik cord as the diameter of the ATV winch rope is only 4.8mm for synthetic and 5.5mm for steel.
    • Did you account for the efficiency loss through the snatch blocks? Obviously it depends on what you buy, but I would guess the cheap ones are only 90%-95%. With 3 you're only getting 85% of your pull. There will also be losses in the progress capture device.
    • How are you mounting the ATV winch? It still needs to be secured to the vehicle in some way if not placed in a bumper.
    • Did you consider situations where a double line pull is necessary on the larger winch? You'd end up needing substantially more rope and snatch blocks with a smaller winch.
    • Have you fully considered the cost differences? Here's some info on a Warn VRX 35-S (3.5klb pull with 50' rope) vs a VR EVO 12-S (12klb pull with 90' rope)
      • MSRP $480 vs $940 ($460 difference)
      • Additional rope (100') ~$105
      • Snatch blocks (3 min) ~$50
      • Portable power wiring rated for 200 amps. Probably need ~20' of 4 gauge if you plan on using it off the back of the vehicle like you said. ~$100 for wire and connectors
      • I'd argue that a tacoma only really needs the 8klb winch (and some pulleys), which is only $790. So the difference would be less than $100. I'd gladly pay that for not having to take 20 minutes to set up a complicated system every time I need to winch; It's annoying enough to do already.
    You're getting a lot of flack as there's a reason most people run a 8-12klb winch; It works, and the alternatives are not worth the effort, time or savings. You're not the first person to have this idea, but you seem unwilling to accept that others have thought about it, evaluated it and determined it's not worth it. If you want to run it, go ahead, but accept that most others have come to a different conclusion than you regarding its utility.
  3. Aug 25, 2020 at 3:58 PM
    #263
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Another thought - If you want a true no-load FPM to no-load FPM comparison to back up your equivalency claim, then its only fair to include the the MA system. Therefore, to have as fast of no load speed as the slower of @US Marine 's winches, an ATV winch with a 4:1 system would need to be pulling in line at 152 feet per minute at the winch. Better bring some extra batteries in series and a tank of LN2 to keep it cool.
  4. Aug 25, 2020 at 4:02 PM
    #264
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You’re gonna start a civil war with all those bullets. How dare you bring facts to the equation!
  5. Aug 25, 2020 at 4:17 PM
    #265
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Looking on warns website, the fpm for an atv winch under full load is comparable to a full size winch under load. Their cheapest atv winch, the VRX 25, gets 6.8fpm under its max of 2500lbs. The zeon 10k gets 4.8fpm under 10klbs. I'm not a winch expert by any means, I dont even have one yet, but I figured I'd look up some specs. I agree with you guys on everything between the practicality, duty cycle, actual line capacity, etc, but I wasnt expecting the fpm to be so low for a full size winch. That being said, I'm sure the zeon has a much heftier duty cycle than the vrx. That's just a guess though, all I saw for duty cycle on their website was "intermittent".
    Gunshot-6A and US Marine like this.
  6. Aug 25, 2020 at 4:19 PM
    #266
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Or we could all do what you did and propose an impractical idea then gaslight anyone that disagrees. You provided no evidence that your solution was better than a properly sized winch while simultaneously insulting those who used 100 years worth of vehicle recovery data, physics, math and engineering to mount an impressive argument against your idea.
  7. Aug 25, 2020 at 4:20 PM
    #267
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What really changes it though is due to the MA, that line speed gets cut by 1/4. So the atv line becomes 1.7. Then gotta bring duty cycle into play as well.
  8. Aug 25, 2020 at 4:21 PM
    #268
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Letterkenny FTW
  9. Aug 25, 2020 at 4:22 PM
    #269
    Jojee117
    Joe
    MT
    Duh, I forgot about that despite it being the main idea here.
    EatSleepTacos[QUOTED] likes this.
  10. Aug 25, 2020 at 4:24 PM
    #270
    jowybyo
    Joe
    Baltimore, MD
    Stop using math and science. It’s all made up by people who get paid to make up shit people don’t understand.
  11. Aug 25, 2020 at 4:28 PM
    #271
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    whatstcp and Thatbassguy like this.
  12. Aug 25, 2020 at 4:37 PM
    #272
    0xDEADBEEF
    Man I wish that were a joke I could laugh at :(
  13. Aug 25, 2020 at 4:40 PM
    #273
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I find this whole discussion moot. My auto club membership is supposed to give me four free recoveries a year. I think they will even change my flat tire and send out an extra five gallons of gas too.
    Maybe I should get a group buy going.
  14. Aug 25, 2020 at 4:42 PM
    #274
    hoarder23
    Shay
    NJ
    Scratches
    How far off-road will they go? Some will go long ways, others stop where the pavement ends
  15. Aug 25, 2020 at 4:44 PM
    #275
    Taco-Obsessed
    I think he is joking around gents
    whatstcp[QUOTED] likes this.
  16. Aug 25, 2020 at 4:44 PM
    #276
    hoarder23
    Shay
    NJ
    Scratches
    That’s not allowed here, this is the internet
  17. Aug 25, 2020 at 4:45 PM
    #277
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I got high centered behind the Dick's Sporting Goods. It only took them 90 minutes to come out.
    DUSTYNEOJET, Vmax88, y=mx+b and 5 others like this.
  18. Aug 25, 2020 at 4:45 PM
    #278
    0xDEADBEEF
    Obviously, he didn't say anything about barbarians.
  19. Aug 25, 2020 at 4:46 PM
    #279
    hoarder23
    Shay
    NJ
    Scratches
    You could have set up a MA setup in that time and gotten it almost a full car length
  20. Aug 25, 2020 at 4:47 PM
    #280
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Barbarians proved to be too expensive. They like to be paid in local craft maple stouts. 50 cans of local will break your bank.
    synaps3, US Marine, hoarder23 and 2 others like this.
