That >8,000 lb. winch is a waste of money.
Discussion in 'Recovery' started by TomHGZ, Aug 24, 2020.
  1. Sep 6, 2020 at 5:10 PM
    #401
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    But carry 300' of climbing rope in case you need it
  2. Sep 6, 2020 at 5:12 PM
    #402
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    300' of paracord would weigh less and you could double or triple it up to get the same strength.
  3. Sep 6, 2020 at 5:18 PM
    #403
    hoarder23
    Shay
    NJ
    Scratches
    Dental floss weighs even less and you could 10x it to get the same strength
  4. Sep 6, 2020 at 5:27 PM
    #404
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s absurdly heavy. What about human hair?
  5. Sep 6, 2020 at 5:33 PM
    #405
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I keep a jar of spiders in the back seat. They double up as a mosquito eliminator
  6. Sep 6, 2020 at 5:47 PM
    #406
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    What trail?
  7. Sep 6, 2020 at 5:49 PM
    #407
    Rome604
    Dave
    Alexandria, VA
    Do you even overland if you don't have trained spiders to help with recovery?
  8. Sep 6, 2020 at 5:50 PM
    #408
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Mmmm, 3rd gen 4runner.:yes::yes:
    EatSleepTacos[QUOTED] likes this.
  9. Sep 6, 2020 at 5:54 PM
    #409
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    22. The plan was to run it up to where you and I turned off last time, but it’s pretty impassable now. Huge rut/water hole. Only way through it would be to drag your passenger side against that dirt wall the whole way around the corner.
    ovrlndkull[QUOTED] likes this.
  10. Sep 6, 2020 at 6:46 PM
    #410
    G.T.
    G.T.
    CONUS
    Most don’t worry about synthetic line anymore as it loses kinetic energy very fast but when metal breaks it still flies as fast as usual. We’ve just taken to moving the line weight closer to the shackle on the vehicle being recovered.
  11. Sep 6, 2020 at 6:51 PM
    #411
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Who has actually had a winch line fail on them during a recovery? Did you have a blanket and was it heavy enough/in the right position to prevent damage?
  12. Sep 6, 2020 at 6:52 PM
    #412
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Closest thing I’ve had was a syn line failing during the initial spooling under a slight load. The bumper was chafing the line causing it to fail, and it dropped right to the floor.
  13. Sep 6, 2020 at 6:58 PM
    #413
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Wire rope is only prone to failure when the preventive maintenance isn’t done. I have seen one failure and that was corrosion related.
    Synthetic line is more prone to abrasion.
    Both need to be kept clean to het the maximum life span.
    JKU3000, VE7OSR and G.T. like this.
  14. Sep 6, 2020 at 7:32 PM
    #414
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah I heard. I've gotta get back out there want to run up to the far other side of the park and run up to the look outs where the devil's elbow trail is forget the name of that area.
  15. Sep 7, 2020 at 1:16 PM
    #415
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    Are the harbor freight models holding up ok?
    Who makes the light weight winch that is still strong enough for a taco to save a Jeep
    Thatbassguy likes this.
  16. Sep 7, 2020 at 1:18 PM
    #416
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I like mine so far, it is a tight fit shoving a 12k winch in there, but it's a lot lighter than my previous SuperWinch 8.5k
    CBrob[QUOTED] likes this.
  17. Sep 7, 2020 at 1:32 PM
    #417
    CBrob
    Rob
    not a single mod
    Are there off brands that are known to be junk?
  18. Sep 7, 2020 at 1:42 PM
    #418
    JEEPNIK
    Old saying, “you get what you pay for”. My Warn is over thirty years old. Still going strong. I also have a smaller Rule that’s almost as old.
    Why two. Because sometimes you need to lend one. And once or twice I used one on each end of my Jeep.
  19. Sep 7, 2020 at 2:37 PM
    #419
    G.T.
    G.T.
    CONUS
    There are formerly premium brands that have fallen off like Superwinch. They left Connecticut for Oregon and now all of their winches are made in SEA.
  20. Sep 7, 2020 at 2:46 PM
    #420
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I've had my badLands 12,000 lbs winch for just over three years, don't use it a lot, but it has worked flawlessly everytime I've needed it.
    G.T. likes this.
