That >8,000 lb. winch is a waste of money.
Discussion in 'Recovery' started by TomHGZ, Aug 24, 2020.
  1. Oct 23, 2020 at 4:36 PM
    #541
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Thatbassguy and tcjacado[QUOTED] like this.
  2. Oct 23, 2020 at 4:42 PM
    #542
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    Maybe OP is still stuck out on the trails somewhere? We should gather a bunch of us saps with >8000lb winches to go do some search and rescue.
  3. Oct 23, 2020 at 4:53 PM
    #543
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I was about to say the same thing. He probably got stuck somewhere trying to use their solution in the real world, and it failed.
  4. Oct 23, 2020 at 5:30 PM
    #544
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Redirect and pulley this thread together, to gain mechanical advantage with the least amount of effort. Let me run some synthetic, low stretch ropes out virtually through the muck in my mind, and might be able to get unstuck.
    mac_2_nite, kbp810 and doublethebass like this.
  5. Oct 25, 2020 at 12:57 AM
    #545
    Clarky4545
    Clarky4545 Member
    Jeff
    SW Ohio
    2018 DCSB SR
  6. Oct 25, 2020 at 1:11 AM
    #546
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I would but I just found out that my 8000lb winch is useless and now I can't let my rig be seen in public. :facepalm:
  7. Oct 27, 2020 at 10:56 PM
    #547
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    My 8000 lb winch got a good workout yesterday
    I also got a good workout
  8. Oct 27, 2020 at 11:00 PM
    #548
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I went with a 12k as I got one hell of a deal. Almost the price of the 10k version but in retrospect the 10k would have been the better choice then found out my truck weights 7k+ lbs.
  9. Oct 28, 2020 at 12:09 AM
    #549
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    That 3500lb winch is a waste of money, you need to find one around 2000lb and it'll be much lighter and cheaper.
  10. Oct 28, 2020 at 7:09 PM
    #550
    crucescrawler9
    crucescrawler9 Well-Known Member
    Gary
    2001 Tacoma Cre 4x4
    Plenty of Odds and Ends
    I’ve spent way too much time waiting for solenoids to cool down to go any less than a 9000 pound winch and carry a fair lead with me and some rigging. I’ve got to warn 8274 on my Rockcrawler that I just love to death but I have some other winches that get the job done also
    Thatbassguy likes this.
  11. Oct 30, 2020 at 6:46 PM
    #551
    Taco-Obsessed
    @TomHGZ been a while. Could you provide an update or an estimate on when you'll do your video?
  12. Oct 30, 2020 at 6:48 PM
    #552
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    More like a good wood-out
  13. Oct 31, 2020 at 3:21 AM
    #553
    Clarky4545
    Clarky4545 Member
    Jeff
    SW Ohio
    2018 DCSB SR
    If you were in a pinch and had all the gear. The guy has a ton of videos like that.
    whatstcp[QUOTED] likes this.
  14. Nov 8, 2020 at 3:23 PM
    #554
    VT_TACOMA
    VT_TACOMA Well-Known Member
    2015 Tacoma DCSB TRD Sport
    @TomHGZ Still a chance of a video before New Years?
  15. Nov 9, 2020 at 10:59 AM
    #555
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    He's probably been winching himself out this whole time and hasn't gotten back home to upload the video.
    Thatbassguy and doublethebass like this.
  16. Nov 9, 2020 at 11:21 AM
    #556
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Excellent video. Learned lots.
    Curious as if to what weight rating the rope has to have to pull that out.
    I'm assuming 3400+ lbs...
    But yeah, in General, I like the idea of a plate mounted winch that sits in the garage the 95% of the time the truck is being used in town.
  17. Nov 15, 2020 at 5:07 PM
    #557
    Taco-Obsessed
    @TomHGZ would you mind checking in and providing an update?
  18. Nov 15, 2020 at 5:11 PM
    #558
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
  19. Nov 15, 2020 at 10:41 PM
    #559
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    My gawd. The original post and it's fill up defenses, all delivered with know-it-all certainty, are pretty much the dumbest effing thing I've read in a long time.
  20. Nov 18, 2020 at 6:19 AM
    #560
    ResearchMonkee
    Derrick
    KCMO
