That Dude Tim Alignment
Discussion in 'Suspension' started by Nick54, May 24, 2011.
  1. May 24, 2011 at 5:24 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    After a Firestone missfire at an alignment I posted here and a TW guy stepped up, That Dude Tim who works for Premier Toyota of Amhurst Ohio got me straight. Props to you Timmy Boy. However as with sunshine comes a little rain. The alignment looks much better and I'm no longer concerned I'm going to run the $900.00 tires off the truck. Down side, I had to remove my front mud flaps and trim the bottom inside edges of the fender flairs - stink ! Well here are the numbers
  2. May 25, 2011 at 4:14 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Sorry about the rubbing, but that will get fixed.
    Will gladly redo the alignment for you. I felt bad with you going with them rubbing.
  3. May 25, 2011 at 4:22 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Read BJMoose thread on this and the LR UCAs. its a little bit down from here. I helped him solve his issues. When looking at your before caster numbers i see that you had a lot of extra caster. If you are like him you have the UCAs set at +2 or 3* of caster. When you dial in the caster at the top this moves your tires further back in the wheel well and then when the alignment guy adjusts the lower cam bolts to lower the caster and bring it back into spec then that moves your tire further back and causes more rubbing. I suggest you set your LRs to the 1* setting and then use the bottom stock cam bolts to get the caster right. this will throw out your camber and then use the slide camber adjustment on the LRs to get the camber back to spec. Setting the LRs at 1* of caster will help move your tire away from the back of the wheel well, then dialing in more positive caster at the bottom using the stock adjustments will move it even further back.
  4. May 25, 2011 at 4:35 PM
    That Dude Tim
    Elyria, OH
    That's exactly what we talked about today. Weird thing though is i didn't have to do that on mine. Same tires/size, DC, lifted, LR UCA's, aftermarket wheels.
  5. May 25, 2011 at 4:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nice alignment! YOu may be able to bump the Caster up to about .4*, and get more Caster (around 2.9*) and that will stop the rubbing.
  6. May 25, 2011 at 5:22 PM
    That Dude Tim
    Elyria, OH
    Not possible, if I remember correctly the front adjusters ended up being set to max to get those numbers. The back ones too I believe.
    Nick wasn't sure what backspacing he has, but when we looked at my truck his front tires stick out farther. Less backspacing yes?
  7. May 25, 2011 at 5:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If he is running the LR UCA's, you can easilly get Caster to about 3* or more.
  8. May 25, 2011 at 5:33 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This ^^
    LR UCA's have 2* of caster built in @ their neutral setting .
  9. May 25, 2011 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, the OP's "before" adjustments show over 4* of Caster, while Camber is only .2* off the mark on the left....SO.....Getting 3* should be within easy reach.
  10. May 25, 2011 at 6:40 PM
    That Dude Tim
    Elyria, OH
    Don't know what I was thinking there. I was aiming for lower caster without having to mess with adj caster on the UCA's. I ment I maxed out the adj to get caster were it is now.
    So if I get this right, by bumping up the caster with the factory adj, this will move the tire in the wheel well forward?
  11. May 25, 2011 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Using the factory adjustment cams. You shouldnt have to do anything with the UCA's.
  12. May 26, 2011 at 8:47 AM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    What makes this a nice alignment? I'm getting mine aligned right as I'm typing this. Am I looking to just hit factory specs or what? I'm on icon lift with down south UCAs and 4.5in BS hoss wheels.
  13. May 26, 2011 at 9:08 AM
    Blkturbo!
    Sean
    Henderson, NV
  14. May 26, 2011 at 9:22 AM
    PreRunnerSeth
    Apex, NC
    But, if you set the LR UCA to the +1* position you should be able to hit factory spec with the bottom and have the least amount of rub. if you are at + 3 or 2* on the LRs you will get the caster way up there with the factory adjustments. Doing both, Changing the UCA setting, then getting to spec with the lower factory adjustments will both help with clearance and keep you in spec.
  15. May 26, 2011 at 12:29 PM
    Nick54
    Nick
    Mentor Ohio
    I went over to the ProComp web site to look at the wheel backspacing for my 7033's it's 4.75, don't know how much difference this makes.
