thats a tiny filter.why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCalBlack08, Jan 11, 2010.
  1. Jan 11, 2010 at 4:56 PM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    what are these tiny filters used for under the hood? do they do anything?
  2. Jan 11, 2010 at 4:59 PM
    jandrews
    '09 FourDubDee TRD OR
    Filtering.
    DUH.
  3. Jan 11, 2010 at 5:04 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    ok other than filtering haha
    a breather for what?
  4. Jan 11, 2010 at 5:07 PM
    jandrews
  5. Jan 11, 2010 at 5:08 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Thats not a stock breather. Looks like someone added it on. I think that breather should go to the intake tube, or possibly PCV. I gotta look under my hood to be sure. Do you have a CAI on there?
  6. Jan 11, 2010 at 5:26 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    i have a intake. i was watching intake videos on youtube and saw someone with a small filter like this. the hose looks like the one i connected to the intake tube so i was wonder why ppl do this
  7. Jan 11, 2010 at 5:27 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    :rolleyes:
  8. Jan 11, 2010 at 5:30 PM
    shook0002
    Joe
    Philly
    Theres really no reason to add these filters, the PCV system is designed for a closed crankcase. I'm not sure about Taco's but on my mustang removing the vent tube that goes to the air intake actually causes a vacuum leak, thats also a closed crankcase design.
  9. Jan 11, 2010 at 7:37 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    That hose looks like its going into the valve cover. So, it looks like someone replaced a PCV valve with that goofy looking mini filter. It doesn't do anything but provide ventilation for the crankcase and keep oil vapor from leaking all over the engine.
  10. Jan 11, 2010 at 8:19 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    so its stupid?
  11. Jan 11, 2010 at 9:30 PM
    JKD
    JKD Well-Known Member
    Someone mentioned that it might be PCV...if you do not have a functioning PCV system, then you should shorten your oil change interval by a LOT. The oil will load up with blowby fuel and water vapor quickly if the crankcase vapors are not actively removed by the PCV system.
  12. Jan 12, 2010 at 4:08 AM
    shook0002
    Joe
    Philly
    Besides what was said above, the pcv also keeps your gaskets from blowing out from crankcase pressure. If the pcv is missing put one back on, these motors aren't like the 80's where you rip that stuff off and not worry.
  13. Jan 12, 2010 at 4:35 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    IT looks like a K&N key cahin? Probably don't belong there. ;)
