The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Apr 6, 2018 at 8:35 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
    They were the stock wheels from my 2013 TRDORSB. 265/75/16.
  2. Apr 6, 2018 at 8:40 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    The truck had steelies on it. Not sure if there was any difference in offset. No rubbing, though.
  3. Apr 7, 2018 at 5:10 AM
    overado
    overado Well-Known Member
    2010 RegCab Tacoma
    Lifted, 285/70/17s, Referbished FJ rims, custom front bumper, snorkel
    That is an awesome piece of machinery!
  4. Apr 7, 2018 at 6:33 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Shift cable replacement, and while you got it off, maybe get the shaft out and lube it up? Unsure of the fix because most guys where taking the trucks back to the toyota dealership. There may be a tsb or recall out?
  5. Apr 7, 2018 at 12:16 PM
    Kick
    Kick Well-Known Member
    2013 base cab 4x4
    Jba uca's, bilstein's 6112 and 5125 Alcan 2" rear springs, wheeler's super bumpstops. Michelins defenders 265/75/16
    Now your ready to wheel and work.
  6. Apr 7, 2018 at 4:46 PM
    electricmarauder
    electricmarauder Well-Known Member
    2014 | Tacoma | RC | White | 4×4 | 5-speed
    Bonaventure Cemetery in Savannah, wish I had some better shots, pretty neat place.
  7. Apr 8, 2018 at 1:10 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Here's a few pictures of my rig on the beach near home in TX and Arkansas.
  8. Apr 8, 2018 at 6:52 AM
    Brewnmn
    Brewnmn Well-Known Member
    2014 4X4 Reg Cab
    Just picked up a 14 Reg. Cab 4X4 and wanted to get some opionions on what way to go to get it leveled out and maintain a good ride. It measures 1-1/2” low in the front.
    I think i have in narrowed down to Bilstein 5100 adjustables up front set at .85 which would get me pretty close or Bilstein adjustables set at “0” with OME 883 coil springs which according to the chart should bring it up a full 1-1/2”.
    PintSize likes this.
  9. Apr 8, 2018 at 6:57 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I would go with the 0 setting and 883’s. Not much more money, you got it tore apart already, better ride. Get ahold of Headstong Off-road, get them pre-assemble.
  10. Apr 8, 2018 at 12:55 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    3rd Gen suspension levels it out and lifts an inch- couple people here, including myself, have done it. Got complete set off 3rd Gen marketplace for 250 shipped.
  11. Apr 8, 2018 at 5:10 PM
    PintSize
    Texas
    I went with 884s on Bilstien 5100 on all four corners with headstrong progressive AAL. Overload leaf is still installed as well. I have BFG KM2 255 85 R16 tires with zero rubbing issues.
    I had removed a poly spacer that sort of leveled the front- but really it just gave it serious bro lean. Personally having a slight rake with my current lift is good, once I load up gear to go camping or fishing etc... it looks level. With just a level in the front the rear will only drop down more and the basic leaf pack regular cabs have can’t handle much weight at all.
  12. Apr 9, 2018 at 6:01 AM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    Ladder makes my truck look smaller than it already is D80A5C6B-45EF-482C-9981-1F7ABADD2E3E.jpg
  13. Apr 9, 2018 at 8:40 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Do any of you single cab owner have a Double Cardan Joint on your drive shaft? I recently bought a 98 reg cab that has a double cardan joint right behind the transfer case. It's looking like it needs servicing/rebuilding as it has grease flung out all over the place. Have any of you messed with rebuilding one of these? Any one know which U-Joints are used in rebuilding it? Any help is appreciated. Thanks.
  14. Apr 9, 2018 at 9:40 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    I have one that I plan on rebuilding the link I found to doing it is on my Ipad at home I'll send it to you later
    boostedka[QUOTED] and 05Taco4x4 like this.
  15. Apr 9, 2018 at 9:41 AM
    05Taco4x4
    2TR-FE Enthusiast
    I believe all three gens use 1330 series, my experience is documented here
    http://www.tacomaworld.com/threads/534480/#post-17168335
    boostedka[QUOTED] likes this.
  16. Apr 9, 2018 at 2:22 PM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    3rd gen won't quite level it. Mine lifted front and rear because I had a worn out 3 leaf pack that was replaced with a 4 leaf pack. I still have factory rake. Your experience may vary obviously.
    05Taco4x4[QUOTED] likes this.
  17. Apr 9, 2018 at 9:31 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    https://www.tacomaworld.com/threads/double-cardan-joint.273119/
    The second post from @jberry813 has good info about the rebuild
  18. Apr 11, 2018 at 10:21 AM
    Nomad_Pilot
    Clay
    Ft Collins
    Hey does anyone have their single cab seat laying around after a seat swap? I need the feet off of it if you do. I am doing a seat swap and can't find another single cab at the junk yard.
  19. Apr 11, 2018 at 10:37 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Edit... never looked that close at the bench rails, didn't realize the feet were just bolted on.
    You can have the set from mine. Shoot me a PM.
  20. Apr 11, 2018 at 1:12 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Decided to put the fishing boat in for the season today. It's a 16' Lowe jet tunnel hull with a 94 Mercury 60/45 short shaft jet outboard. It's a great boat for running shallow since the river is mostly rock where we are. The front deck is where I sit in the beach chair and "fish" while enjoying a beer. It's supposed to be in the 70's shortly and I'm ready for it. It was 45 degrees Monday and I was in shorts in the water past knee deep getting my dock put together.
